    Foundation Plugin
    451 Posts 15 Posters 614.5k Views 15 Watching
      MtnArch
      @medeek said:
      What is the typical header thickness between the top of the vent hole and the top of foundation?
      What I usually do is provide a solid wood header within the floor framing and suck the vents up tight to the top of the stem wall.
      As to size, it will vary depending on the topography of the site, total size of the underfloor area, etc. Also, here in California if you are in the "SRA" (State Responsibility Area, which is where fire protection is provided by state forces such as Cal Fire) you have to use approved ember-resistant vents which are further limiting.
      Highest Regards,
      Alan T. Hendry, RA
      Architect
      • medeekM
        medeek
        I've seen them dropped down and some installed at the top of the wall. I guess I will just need to add another input which allows the user to adjust the location vertically.
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM
          medeek
          The options for the crawlspace vents (if this option enabled) will be:
          1.) Width (in.)
          2.) Height (in.)
          3.) Corner Distance (ft.)
          4.) Top Fnd. Distance (in.)
          5.) Max. Spacing (ft.)
          6.) Location: All Walls|Left/Right Walls|Front/Back Walls
          7.) Vent Insert: NONE|PLASTIC|METAL
          The Max. spacing variable will determine whether to insert intermediate vents along the wall line. The module will always place two vents per wall (if wall line selected), one at each corner and then equally space vents along wall line based on the Max. spacing variable.
          design.medeek.com
          • medeekM
            medeek
            The vent module seems to be working fairly well:
            http://design.medeek.com/resources/images/foundation_su26_800.jpg
            If you set the top distance to zero the vents are right up to the sill plate:
            http://design.medeek.com/resources/images/foundation_su27_800.jpg
            Notice the top bar is clashing with the vent cutouts.
            design.medeek.com
            • medeekM
              medeek
              Version 1.0.8 - 03.23.2017
              • Added crawlspace vent option to stemwall foundations.
              • Added a "Materials" tab within the global settings; Auto material assigment (colors and textures) is now an option.
              • Enabled materials for all foundation types.
              http://design.medeek.com/resources/images/foundation_su28_800.jpg
              design.medeek.com
              • jujuJ
                juju
                I have not used this extension in a while (and not on any modeling thus), updated again (as I always do when new versions come along) today from the Medeek site, version 1.0.8.
                Strange, I can't seem to get any of the functions to work. The "slab" and "slab on grade" functions are probably the main reasons I got this extension and dev is standing still on "slab", licence update/renewal due within a few months, not a killer amount though but I was hoping these functions would receive some love.
                Another long time problem is under settings, the "trial version" indication does not go away even when I enter my licence information.
                Any ideas?
                • medeekM
                  medeek
                  What is the error you are getting in the Ruby console? Please also send me your OS and SU version.
                  I will get to work on the slab tool next. I've been concentrating on the Truss and Wall Plugins and just got back to this one after a hiatus.
                  design.medeek.com
                  • jujuJ
                    juju
                    Sending via PM
                    • medeekM
                      medeek
                      Also be sure to let me know if you are using a metric or imperial template.
                      design.medeek.com
                      • medeekM
                        medeek
                        I think I've fixed the bug, download version 1.0.8 again and reinstall, the previous version is broken.
                        design.medeek.com
                        • facerF
                          facer
                          Suggested Template for reporting issues/anomalies
                          via PM to Medeek. (private Message - refer pic attached)
                          Anomalies Report - Medeek Foundation
                          01 SketchUp Version (Skp_ _ _ _ _ )
                          02 Operating System (OS_ _ _ _ _ _ ) W10 for example
                          03 Are you are using a metric or imperial template?
                          04 Ruby console report
                          (locate on Skp horizontal drop down functions: Window > Ruby console)
                          ** Note open Ruby console BEFORE running plugin.
                          05 Screen capture (if appropriate or helpful in explaining issue)
                          PM - Private Message
                          • facerF
                            facer
                            Medeek Foundation Plugin - v 1.0.8 Mar 25, 2017 11:45 am
                            Working Okay!
                            Thank you for your effort.
                            01 SketchUp Version (Skp 2016)
                            02 Operating System (W10 32 bit)
                            03 Using a metric template?
                            • medeekM
                              medeek
                              • Added a joist pocket option for stemwall foundations.
                              http://design.medeek.com/resources/images/foundation_su29_800.jpg
                              I've been putting off the joist pocket feature for a while but figured I could spend my Friday night and knock it out. I doubt it will get much use except for certain builders in the State of Oregon.
                              The options for the joist pocket option are:
                              1.) Pocket Width
                              2.) Pocket Height
                              3.) Pocket Depth (into the stemwall)
                              4.) Pocket Spacing (default is 16" o/c, but can be set to any value)
                              If you use joist pockets with either the brick ledge feature or the crawlspace vents you need to realize that the geometry must be such that the various item don't clash. For example the stemwall must be thick enough for a brick ledge and the typical 2.25" depth of the joist pocket.
                              With vents and pocket joists there must be enough vertical clearance between the two otherwise the header will be too thin for the overlying floor joist. One solution to this problem is to have the vents only on the front and back walls while the joist pockets are on the left and right walls.
                              The number of options and inputs is now a bit mind boggling and the code is also at a new level of complexity. Taking all of this to a polygon shaped foundation will be a challenge but that is where it needs to go next.
                              design.medeek.com
                              • medeekM
                                medeek
                                Version 1.0.9 - 03.25.2017
                                • Added slab foundation type (rectangular outline only).
                                • Enabled full and partial width interior thickened slab footings.
                                http://design.medeek.com/resources/images/foundation_su30_800.jpg
                                View model here:
                                3D Warehouse
                                (3dwarehouse.sketchup.com)
                                design.medeek.com
                                • medeekM
                                  medeek
                                  The push/pull feature of SketchUp makes things like popping holes and creating extrusions really easy. The garage door shown below is a good example of this. I've boxed out a section in the stemwall for the door and also extruded a piece of the slab out over top of the stemwall.
                                  http://design.medeek.com/resources/images/foundation_su31_800.jpg
                                  The problem arises when the top rebar runs through the door opening. Basically I need to create an opening tool that will remove the rebar as well as the concrete. A virtual concrete saw cutting tool, too bad the boolean operations are not standard with SketchUp Make, this would make my life easier.
                                  design.medeek.com
                                  • medeekM
                                    medeek
                                    Note that the polygon tool does not create interior holes, there will be a separate tool just for that, similar to my trim and extend tools.
                                    With the rebar in stemwalls, interior footings and edge footings the issue shown above is not a problem, it is just the slab reinforcement that has me stumped at the moment.
                                    design.medeek.com
                                    • medeekM
                                      medeek
                                      Finally got some time to work on the polygon tool in the foundation plugin, starting with the easy one which is the basic slab.
                                      I've got it working for the concrete but the problem is the slab rebar or mesh, see image below:
                                      http://design.medeek.com/resources/images/foundation_su32_800.jpg
                                      The only way I can see to create the rebar is to use the solid boolean tools (ie. Subtract), however that is only available in the Pro version of SketchUp so the polygon tool would really only be useful or workable in the Pro version of SketchUp. Unfortunately, I don't have enough extra cash at my disposal to even purchase the pro version so I am now at a standstill on this since I can't test or debug it further.
                                      You can literally draw any shape you like but the rebar is configured to always align (parallel) with the edge created by the first and second points.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        http://design.medeek.com/resources/images/foundation_su33_800.jpg
                                        As can be seen in this polygon shape the rebar could be potentially cut in multiple places. The subtraction method makes the most sense but since I don't have that luxury I am working on a different algorithm for putting the rebar only within the concrete and so that it has at least 3" of ground clearance on the sides.
                                        design.medeek.com
                                        • facerF
                                          facer
                                          Go Medeek!
                                          You are teasing us with these progressive screen shots of
                                          the evolving "polygon" feature. πŸ˜„ πŸ˜„ πŸ˜„
                                          • medeekM
                                            medeek
                                            Haven't figured out the best way to deal with the slab reinforcement yet but I've moved on to start putting together the polygon tool for the Slab-on-Grade. Since the offset line tool is not exposed in the API I've decided to try and use TIG's SmartOffset plugin as a starting point. Unlike the rectangle tool I probably won't have a bend radius on the footing bars, at least not initially. At some point I would like to figure out a plugin or some code that will automatically apply a radius or fillet to two lines/edges, I'm surprised that this functionality is not already built into SketchUp.
                                            The way I will create the SOG is extrude the slab and then use the follow me tool for the footing, then union the two solids together, fairly simple. Any shape or size of SOG will be possible. The basic input (Non-Graphical User Interface) will only allow the entry of one internal footing however I am planning on implementing a Webdialog GUI that will allow the user to create as many interior footings as required and also allow them to even cross each other in grid patterns (ie. X-dir and Y-dir). Things are going to get interesting with this plugin.
                                            The GUI will allow the user to better preview the location and start and end points of the interior footing(s) which will make the entire process much more intuitive and easier to use.
                                            Anchor bolts along the perimeter of the SOG will also be implemented. Hoping to have all of this done by the end of the week, and as time allows. I may have to simply disable the slab mesh/rebar until I can figure out a way to trim it without forcing the user to SketchUp Pro.
                                            design.medeek.com
                                            • 22
                                            • 23
                                            • 5 / 23
