    Foundation Plugin
    451 Posts 15 Posters 562.3k Views 15 Watching
    • medeekM Offline
      medeek
      I've been talking to a few other contractors out there and most of them don't pay alot of attention to the orientation of the J-bolts into the concrete, they let the concrete set up a bit and then stab them in.
      I'm adding in the custom materials, stemwall foundation below is an example:
      http://design.medeek.com/resources/images/foundation_su24_800.jpg
      I will need to roll another revision probably tomorrow to get this update out there.
      I was wondering about adding in the option for vents in the stemwall, for foundations with crawlspaces. Any thoughts on this and what is standard construction in your locale as well as what type/brand of foundation vents/inserts are used.
      Nathaniel P. Wilkerson PE
      Medeek Engineering Inc
      design.medeek.com
      • medeekM Offline
        medeek
        The ICC codes call out a minimum of a one vent within 3 feet of each corner. It shouldn't be to much trouble to create the openings in the stemwall and place some vents:
        http://design.medeek.com/resources/images/foundation_su25_800.jpg
        For a rectangular building (4 sides) should I place 4 vents or 8 vents? Provide only the openings or also provide a generic foundation vent (lightweight geometry?)
        Moving an opening is actually very easy within SketchUp, when it comes to a solid wall like this.
        What is the typical header thickness between the top of the vent hole and the top of foundation?
        Vent size seems to be 16"x8" for most vents I've seen.
        With regards to vents there are the cheap plastic ones you can get a Home Depot or Lowes and and then there are a whole ton of more expensive louvered metal manufacturers of vents and flood vents.
        design.medeek.com
        • medeekM Offline
          medeek
          I've been slowly plugging away at the polygon stemwall tool, but as I was driving to work this morning I realized it would also be useful to have a simple linear or line tool as well for creating straight segments.
          design.medeek.com
            MtnArch
            What I usually do is provide a solid wood header within the floor framing and suck the vents up tight to the top of the stem wall.
            As to size, it will vary depending on the topography of the site, total size of the underfloor area, etc. Also, here in California if you are in the "SRA" (State Responsibility Area, which is where fire protection is provided by state forces such as Cal Fire) you have to use approved ember-resistant vents which are further limiting.
            Highest Regards,
            Alan T. Hendry, RA
            Architect
            • medeekM Offline
              medeek
              I've seen them dropped down and some installed at the top of the wall. I guess I will just need to add another input which allows the user to adjust the location vertically.
              design.medeek.com
              • medeekM Offline
                medeek
                The options for the crawlspace vents (if this option enabled) will be:
                1.) Width (in.)
                2.) Height (in.)
                3.) Corner Distance (ft.)
                4.) Top Fnd. Distance (in.)
                5.) Max. Spacing (ft.)
                6.) Location: All Walls|Left/Right Walls|Front/Back Walls
                7.) Vent Insert: NONE|PLASTIC|METAL
                The Max. spacing variable will determine whether to insert intermediate vents along the wall line. The module will always place two vents per wall (if wall line selected), one at each corner and then equally space vents along wall line based on the Max. spacing variable.
                design.medeek.com
                • medeekM Offline
                  medeek
                  The vent module seems to be working fairly well:
                  http://design.medeek.com/resources/images/foundation_su26_800.jpg
                  If you set the top distance to zero the vents are right up to the sill plate:
                  http://design.medeek.com/resources/images/foundation_su27_800.jpg
                  Notice the top bar is clashing with the vent cutouts.
                  design.medeek.com
                  • medeekM Offline
                    medeek
                    Version 1.0.8 - 03.23.2017
                    • Added crawlspace vent option to stemwall foundations.
                    • Added a "Materials" tab within the global settings; Auto material assigment (colors and textures) is now an option.
                    • Enabled materials for all foundation types.
                    http://design.medeek.com/resources/images/foundation_su28_800.jpg
                    design.medeek.com
                    • jujuJ Offline
                      juju
                      I have not used this extension in a while (and not on any modeling thus), updated again (as I always do when new versions come along) today from the Medeek site, version 1.0.8.
                      Strange, I can't seem to get any of the functions to work. The "slab" and "slab on grade" functions are probably the main reasons I got this extension and dev is standing still on "slab", licence update/renewal due within a few months, not a killer amount though but I was hoping these functions would receive some love.
                      Another long time problem is under settings, the "trial version" indication does not go away even when I enter my licence information.
                      Any ideas?
                      • medeekM Offline
                        medeek
                        What is the error you are getting in the Ruby console? Please also send me your OS and SU version.
                        I will get to work on the slab tool next. I've been concentrating on the Truss and Wall Plugins and just got back to this one after a hiatus.
                        design.medeek.com
                        • jujuJ Offline
                          juju
                          Sending via PM
                          • medeekM Offline
                            medeek
                            Also be sure to let me know if you are using a metric or imperial template.
                            design.medeek.com
                            • medeekM Offline
                              medeek
                              I think I've fixed the bug, download version 1.0.8 again and reinstall, the previous version is broken.
                              design.medeek.com
                              • facerF Offline
                                facer
                                Suggested Template for reporting issues/anomalies
                                via PM to Medeek. (private Message - refer pic attached)
                                Anomalies Report - Medeek Foundation
                                01 SketchUp Version (Skp_ _ _ _ _ )
                                02 Operating System (OS_ _ _ _ _ _ ) W10 for example
                                03 Are you are using a metric or imperial template?
                                04 Ruby console report
                                (locate on Skp horizontal drop down functions: Window > Ruby console)
                                ** Note open Ruby console BEFORE running plugin.
                                05 Screen capture (if appropriate or helpful in explaining issue)
                                PM - Private Message
                                • facerF Offline
                                  facer
                                  Medeek Foundation Plugin - v 1.0.8 Mar 25, 2017 11:45 am
                                  Working Okay!
                                  Thank you for your effort.
                                  01 SketchUp Version (Skp 2016)
                                  02 Operating System (W10 32 bit)
                                  03 Using a metric template?
                                  • medeekM Offline
                                    medeek
                                    • Added a joist pocket option for stemwall foundations.
                                    http://design.medeek.com/resources/images/foundation_su29_800.jpg
                                    I've been putting off the joist pocket feature for a while but figured I could spend my Friday night and knock it out. I doubt it will get much use except for certain builders in the State of Oregon.
                                    The options for the joist pocket option are:
                                    1.) Pocket Width
                                    2.) Pocket Height
                                    3.) Pocket Depth (into the stemwall)
                                    4.) Pocket Spacing (default is 16" o/c, but can be set to any value)
                                    If you use joist pockets with either the brick ledge feature or the crawlspace vents you need to realize that the geometry must be such that the various item don't clash. For example the stemwall must be thick enough for a brick ledge and the typical 2.25" depth of the joist pocket.
                                    With vents and pocket joists there must be enough vertical clearance between the two otherwise the header will be too thin for the overlying floor joist. One solution to this problem is to have the vents only on the front and back walls while the joist pockets are on the left and right walls.
                                    The number of options and inputs is now a bit mind boggling and the code is also at a new level of complexity. Taking all of this to a polygon shaped foundation will be a challenge but that is where it needs to go next.
                                    design.medeek.com
                                    • medeekM Offline
                                      medeek
                                      Version 1.0.9 - 03.25.2017
                                      • Added slab foundation type (rectangular outline only).
                                      • Enabled full and partial width interior thickened slab footings.
                                      http://design.medeek.com/resources/images/foundation_su30_800.jpg
                                      View model here:
                                      3D Warehouse
                                      (3dwarehouse.sketchup.com)
                                      design.medeek.com
                                      • medeekM Offline
                                        medeek
                                        The push/pull feature of SketchUp makes things like popping holes and creating extrusions really easy. The garage door shown below is a good example of this. I've boxed out a section in the stemwall for the door and also extruded a piece of the slab out over top of the stemwall.
                                        http://design.medeek.com/resources/images/foundation_su31_800.jpg
                                        The problem arises when the top rebar runs through the door opening. Basically I need to create an opening tool that will remove the rebar as well as the concrete. A virtual concrete saw cutting tool, too bad the boolean operations are not standard with SketchUp Make, this would make my life easier.
                                        design.medeek.com
                                        • medeekM Offline
                                          medeek
                                          Note that the polygon tool does not create interior holes, there will be a separate tool just for that, similar to my trim and extend tools.
                                          With the rebar in stemwalls, interior footings and edge footings the issue shown above is not a problem, it is just the slab reinforcement that has me stumped at the moment.
                                          design.medeek.com
                                          • medeekM Offline
                                            medeek
                                            Finally got some time to work on the polygon tool in the foundation plugin, starting with the easy one which is the basic slab.
                                            I've got it working for the concrete but the problem is the slab rebar or mesh, see image below:
                                            http://design.medeek.com/resources/images/foundation_su32_800.jpg
                                            The only way I can see to create the rebar is to use the solid boolean tools (ie. Subtract), however that is only available in the Pro version of SketchUp so the polygon tool would really only be useful or workable in the Pro version of SketchUp. Unfortunately, I don't have enough extra cash at my disposal to even purchase the pro version so I am now at a standstill on this since I can't test or debug it further.
                                            You can literally draw any shape you like but the rebar is configured to always align (parallel) with the edge created by the first and second points.
                                            design.medeek.com
                                            • 22
                                            • 23
                                            • 5 / 23
