    Foundation Plugin
    451 Posts 15 Posters 614.5k Views 15 Watching
    • pbacotP
      If there's a rim jst., don't use a 2x4 plate. Some builders, I am sure, work out a lot of this beforehand, especially if the general is also the framer. And in some other jobs such coordination may be impossible. If the bolt lands on a stud, I suppose extra studs can be added and the stud needed for attachment can be headed off at the bolt. Now some mechanically fastened bolts are approved for anchor bolts. Some innovation in technology is in order to be sure.
      • medeekM
        medeek
        The 1/2" and 5/8" anchor bolts, washers and some standard nuts.
        https://3dwarehouse.sketchup.com/warehouse/getpubliccontent?contentId=471d6963-9bbc-410e-b78b-b613db0fd3f7
        View models here:
        3D Warehouse
        (3dwarehouse.sketchup.com)
        Nathaniel P. Wilkerson PE
        Medeek Engineering Inc
        design.medeek.com
        • medeekM
          medeek
          Version 1.0.7 - 03.19.2017
          • Added 1/2" and 5/8" Dia. Anchor Bolt option to stemwall and slab on grade foundations.
          • Anchor bolt lengths are nominal 10", 12" and 14", square washers are 2"x2" or 3"x3".
          http://design.medeek.com/resources/images/foundation_su22_800.jpg
          View model here:
          3D Warehouse
          The anchor bolt, washer and nut are three separate files that are loaded in as components. Then the nut and washer components are inserted inside the bolt component and exploded so only the solid group(s) remain. Its pretty amazing what you can do with a robust API and a little bit of Ruby code.
          It took me most of today to figure out how to do all of this since I'm in uncharted territory but now that I've got it kind of figured out it opens up the possibility for a host of other things (holdowns, windows, doors, vents etc...) for this plugin and the others I'm working on.
          design.medeek.com
          • medeekM
            medeek
            The cosmetic threads actually render quite nicely as does my rebar material/texture. I just realized I have not added any custom materials into the foundation plugin.
            http://design.medeek.com/resources/images/foundation_su23_800.jpg
            As you can see from the image the orientation of the J-bolts is the same regardless of the wall, however it would not be a couple more lines of code to orient them all facing in or facing out or some other combination. Curious how the contractors actually install these, is the orientation important?
            I tried to put the 25 degree incline on the rebar grooves but there are some difficulties with extruded circular shapes and materials so the best I can do is the concentric rings as shown.
            design.medeek.com
            • facerF
              facer
              Orientation of J-bolts
              I would think parallel to the wall to give maximum concrete cover
              surrounding the J-bolt ends.
              • medeekM
                medeek
                I've been talking to a few other contractors out there and most of them don't pay alot of attention to the orientation of the J-bolts into the concrete, they let the concrete set up a bit and then stab them in.
                I'm adding in the custom materials, stemwall foundation below is an example:
                http://design.medeek.com/resources/images/foundation_su24_800.jpg
                I will need to roll another revision probably tomorrow to get this update out there.
                I was wondering about adding in the option for vents in the stemwall, for foundations with crawlspaces. Any thoughts on this and what is standard construction in your locale as well as what type/brand of foundation vents/inserts are used.
                design.medeek.com
                • medeekM
                  medeek
                  The ICC codes call out a minimum of a one vent within 3 feet of each corner. It shouldn't be to much trouble to create the openings in the stemwall and place some vents:
                  http://design.medeek.com/resources/images/foundation_su25_800.jpg
                  For a rectangular building (4 sides) should I place 4 vents or 8 vents? Provide only the openings or also provide a generic foundation vent (lightweight geometry?)
                  Moving an opening is actually very easy within SketchUp, when it comes to a solid wall like this.
                  What is the typical header thickness between the top of the vent hole and the top of foundation?
                  Vent size seems to be 16"x8" for most vents I've seen.
                  With regards to vents there are the cheap plastic ones you can get a Home Depot or Lowes and and then there are a whole ton of more expensive louvered metal manufacturers of vents and flood vents.
                  design.medeek.com
                  • medeekM
                    medeek
                    I've been slowly plugging away at the polygon stemwall tool, but as I was driving to work this morning I realized it would also be useful to have a simple linear or line tool as well for creating straight segments.
                    design.medeek.com
                      MtnArch
                      What I usually do is provide a solid wood header within the floor framing and suck the vents up tight to the top of the stem wall.
                      As to size, it will vary depending on the topography of the site, total size of the underfloor area, etc. Also, here in California if you are in the "SRA" (State Responsibility Area, which is where fire protection is provided by state forces such as Cal Fire) you have to use approved ember-resistant vents which are further limiting.
                      Highest Regards,
                      Alan T. Hendry, RA
                      Architect
                      • medeekM
                        medeek
                        I've seen them dropped down and some installed at the top of the wall. I guess I will just need to add another input which allows the user to adjust the location vertically.
                        design.medeek.com
                        • medeekM
                          medeek
                          The options for the crawlspace vents (if this option enabled) will be:
                          1.) Width (in.)
                          2.) Height (in.)
                          3.) Corner Distance (ft.)
                          4.) Top Fnd. Distance (in.)
                          5.) Max. Spacing (ft.)
                          6.) Location: All Walls|Left/Right Walls|Front/Back Walls
                          7.) Vent Insert: NONE|PLASTIC|METAL
                          The Max. spacing variable will determine whether to insert intermediate vents along the wall line. The module will always place two vents per wall (if wall line selected), one at each corner and then equally space vents along wall line based on the Max. spacing variable.
                          design.medeek.com
                          • medeekM
                            medeek
                            The vent module seems to be working fairly well:
                            http://design.medeek.com/resources/images/foundation_su26_800.jpg
                            If you set the top distance to zero the vents are right up to the sill plate:
                            http://design.medeek.com/resources/images/foundation_su27_800.jpg
                            Notice the top bar is clashing with the vent cutouts.
                            design.medeek.com
                            • medeekM
                              medeek
                              Version 1.0.8 - 03.23.2017
                              • Added crawlspace vent option to stemwall foundations.
                              • Added a "Materials" tab within the global settings; Auto material assigment (colors and textures) is now an option.
                              • Enabled materials for all foundation types.
                              http://design.medeek.com/resources/images/foundation_su28_800.jpg
                              design.medeek.com
                              • jujuJ
                                juju
                                I have not used this extension in a while (and not on any modeling thus), updated again (as I always do when new versions come along) today from the Medeek site, version 1.0.8.
                                Strange, I can't seem to get any of the functions to work. The "slab" and "slab on grade" functions are probably the main reasons I got this extension and dev is standing still on "slab", licence update/renewal due within a few months, not a killer amount though but I was hoping these functions would receive some love.
                                Another long time problem is under settings, the "trial version" indication does not go away even when I enter my licence information.
                                Any ideas?
                                • medeekM
                                  medeek
                                  What is the error you are getting in the Ruby console? Please also send me your OS and SU version.
                                  I will get to work on the slab tool next. I've been concentrating on the Truss and Wall Plugins and just got back to this one after a hiatus.
                                  design.medeek.com
                                  • jujuJ
                                    juju
                                    Sending via PM
                                    • medeekM
                                      medeek
                                      Also be sure to let me know if you are using a metric or imperial template.
                                      design.medeek.com
                                      • medeekM
                                        medeek
                                        I think I've fixed the bug, download version 1.0.8 again and reinstall, the previous version is broken.
                                        design.medeek.com
                                        • facerF
                                          facer
                                          Suggested Template for reporting issues/anomalies
                                          via PM to Medeek. (private Message - refer pic attached)
                                          Anomalies Report - Medeek Foundation
                                          01 SketchUp Version (Skp_ _ _ _ _ )
                                          02 Operating System (OS_ _ _ _ _ _ ) W10 for example
                                          03 Are you are using a metric or imperial template?
                                          04 Ruby console report
                                          (locate on Skp horizontal drop down functions: Window > Ruby console)
                                          ** Note open Ruby console BEFORE running plugin.
                                          05 Screen capture (if appropriate or helpful in explaining issue)
                                          PM - Private Message
                                          • facerF
                                            facer
                                            Medeek Foundation Plugin - v 1.0.8 Mar 25, 2017 11:45 am
                                            Working Okay!
                                            Thank you for your effort.
                                            01 SketchUp Version (Skp 2016)
                                            02 Operating System (W10 32 bit)
                                            03 Using a metric template?
                                            • 22
                                            • 23
                                            • 5 / 23
