    Implications of end of google earth
    70 Posts 25 Posters 39.8k Views 25 Watching
    • G
      glenn
      @tyler miller said:
      Hey guys -
      Nothing to fear here in regards to SketchUp's Add Location feature. SketchUp uses the Google Maps API, not the Google Earth API. Google Earth the application is not going away.
      Google's announcement that they are ending the Google Earth browser plugin ("Google Earth API") is a natural consequence of tightening browser security models. Most modern browsers are dropping support for any form of plugins over the next couple years.
      Fortunately, much of the functionality of the Google Earth plugin has now been incorporated into Google Maps using more modern browser capabilities like WebGL. This is the same technology we use to do 3D views of SketchUp models on the 3D Warehouse, and it does not require a browser plugin.
      So, nothing to fear here and it is all a natural progression of technology.
      Thanks,
      Tyler
      Seems that we should have been worried. You guys knew about a 5year grace period, but didn't mention that to the users until 2 months before the change.
      Upcoming Change to Add Location
      https://forums.sketchup.com/t/upcoming-change-to-add-location/40953
      Tyler thanks for the misdirection,
      Glenn
        Glenn, the discontinuation of a variety of Google-related links to SketchUp was announced when Google sold Trimble. It's Google that has decided to turn off the access. It wasn't Trimble deciding to discontinue it.
        • andybotA
          andybot
          D'oh!! No aerial map will be available? Anyone know of other options that we can use after this cutoff?
            slbaumgartner
            Trimble is already working with other sources to provide terrain and overhead images when the Google API is discontinued. Time will tell how the coverage and quality compare with Google Earth.
            • andybotA
              andybot
              @sketch3d.de said:
              according to the FAQ it will be OSM for the maps and DigitalGlobe for the satellite imagery and terrain data.
              Thanks! I saw the part about OSM, but it seemed they didn't have anything available for aerials. Glad to see it's in the pipeline. I will be interested to see the quality.
              • panixiaP
                panixia
                +1
                • sketch3d.deS
                  sketch3d.de
                  according to the FAQ it will be OSM for the maps and DigitalGlobe for the satellite imagery and terrain data from Trimbles own sources.
                  • bmikeB
                    bmike
                    I use a relatively cheap (and easy to use) app for hiking / adventure / bike routing - is uses various servers for aerial images, as well as topo maps, etc... as far as I know access to many of these is free or relatively cheap. I know there are pros that use this for trail mapping, etc.
                    http://topofusion.com
                    Can SketchUp integrate with the maps / topo in a similar way?
                    Here are all the map sets / imagery that is available in TF:
                    http://topofusion.com/features.php#imagery
                    • pbacotP
                      What's really good for quick studies is the geo located aerial imagery. That way one can quickly locate new work relative to existing features, good enough for initial planning and presentation. The actual "terrain" model (that I've seen) is only so useful at the site scale. Topo maps might be better, lacking a survey.
                      • bmikeB
                        bmike
                        Agreed that the usefulness of the imported 3d data isn't always as useful, but its usually close enough for early stage work, until a survey is done or can be found / imported / created.
                        • sketch3d.deS
                          sketch3d.de
                          Update 4/4/2017: The new data layers are now available in SU 2017. This means that Pro users will see two new layers in add location: "DigitalGlobe Satellite" and "Trimble Map". Make users will now see a "Trimble Map" layer. Google Satellite will remain as the default layer for a few more weeks.
                          • G
                            glenn
                            digitalglobe imagery is terrible compared to google satellite.
                            Image is blurry, typically older.
                            But at least Trimble didn't wait until the last minute to address this issue.
                            • pbacotP
                              And if we stick to 2016 we'll still have the same functionality as before? (I haven't seen a change)
                              • sketch3d.deS
                                sketch3d.de
                                SketchUp 2016 (Pro or Make) and older versions of SketchUp
                                At this time, there is no feasible way to update these versions of SketchUp to use the new geodata service. The Add Location and Photo Textures features will no longer function.
                                22.05.2017
                                • pbacotP
                                  Understandable. Still I find that statement to be disingenuous (corporate). They don't WANT to update anything. You paid for it but it will no longer work.
                                  • B
                                    blackdogsketch
                                    The quality of the DigiGlobe is dismal...just a bunch of fuzziness. And the Trimble Map is nothing but extremely basic street maps...almost zero detail. Worthless to me.
                                    This is REALLY a serious setback for those of us that use crisp ortho imagery in presentations on a daily basis. Completely frustrating. Trimble buys this fuzzy mess? It doesn't seem worth anything.
                                    Not a happy camper.
                                      You should be frustrated with Google. It's they who are removing the option to use their imagery.
                                        AcesHigh
                                        If imagery for the US is bad, I can only imagine the quality for it in South America, Africa and Asia!
                                        • B
                                          blackdogsketch
                                          Digital globe probably does have high quality imagery...but why isn't Trimble offering it to the customer base?
                                          We are used to a fairly high level of resolution from Google, and new we get this fuzzy crap to work with. (I encourage everyone to go and examine the difference between the two before the May 22 deadline). As a professional, I'm fine if they need to charge for the highest resolution. But to not offer customers ANY good options is infuriating...and it's going to really affect my work and presentation for the worse. I'm surprised that there is not way more discussion about the issue here.
                                          UPDATE: from reading Trimble's statements on the actual SketchUp forum, they claim that they are providing the highest level of resolution available from DigitalGlobe. They claim the problem is that DG captures imagery via satellite, and so resolution is inherently lower than that from GE, who uses planes. As I user, I could care less if they use drones or oil tankers...I just need high quality data...and DG is NOT!
                                            alpro
                                            Totally agree, not only is it not as high of a resolution it's old, working on a site now that has a fairly new building on it which I can see on Google maps but not on the DG imagery.
                                            I think it's fair to be frustrated with Trimble, I'm losing a feature that I consider valuable and that I paid for and it's being replaced by an inferior product, will my SU license cost less ? I don't understand why Trimble couldn't work out a deal with Google and pay for their map data like a lot of apps do. Or even Bing maps like Autodesk did. DG to me is pretty useless.
                                            • 2 / 4
