    šŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 146.6k Views 85 Watching
      @Skalp
      2 trivial questions šŸ˜„
      Does the Skalp material can be used as normal material for any facades surfaces ?
      Does SKalp is existing in French ?
      • SkalpS Offline
        Skalp
        @pilou said:
        @Skalp
        Yes Skalp materials can be used like normal SketchUp materials.
        At this moment there isn't a French version. But we are working on translations at this moment.
        The Skalp Team
        Skalp
        http://www.skalp4sketchup.com
        • SkalpS Offline
          Skalp
          @dimitri972 said:
          Most of Skalp section materials are free on 3d warehouse. You can combine them with this plugin for amazing result. And don't forget to make group or component before taking section.
          Actually this plugin is crashing in many situation but it is still usefull plugin.
          Skalp section materials are intended to be used with Skalp. Skalp materials are much more then just textures.
          The Skalp team
          Skalp
            antoinelepoutre
            does not work in SU2016 on WIN7
              Ader89
              Hi, I put this aap on my sketchup 2015, every bottom is working including the menus, but when i tried to use create richsection its don“t work, the section plane just don“t appear on screen, what can i do to solve it? the app ins“t compatible with sketchup 2015? Thanks
              • romboutR Offline
                rombout
                @dimitri972 said:
                I fixed time expired problem. Here it is:
                http://www.mediafire.com/download/brjzmnqzbcv38fp/RichSectionv0.5.8FULLByDimitri.zip
                Author was't answering question for months. I tried to fixing expired issue and fixed. If this isn't wanting thing in this forum, you can delete my post. I don't know forum rules.
                It sort of works when im doing a single group, crashes when there is more than 1 though.
                osx 10.11.2
                su2015
                • E Offline
                  Ekon
                  I don“t get it to work properly on Win 10 and SU 2016 64bit pro. I get a simple section but no materials, no options dialog and if I do a second section it does it like native SU.
                  None of the other buttons work. It says select Rich Section first, but my section is already selected.
                  Some help would be appreciated.
                  thanks
                    RBCADDSVCS
                    I've tried and tried to get this to work.
                    I've installed, uninstalled, and reinstalled, and nothing works.
                    I'm running Sketchup Pro 2014.
                    The toolbars shows up, and the drop-down menu shows up, but when I click on them nothing happens at all.
                    The log file says my license is expired.
                    I didn't think it needed a license.
                    What's up with that?
                    • H Offline
                      Haddal88
                      Hello!
                      I am trying this plugin after I saw the amazing videos.
                      When I press the button to create the section, nothing happens.
                      Running Pro trial on Sketchup 2017 Make.
                      Any reasons?
                      Running Windows 7, Intel i7.
                      Thanks in advance!
                        Run it with the Ruby Console open.
                        There might be incompatibilities with v2017 ?
                        It is two years without an update...
                        • jujuJ Offline
                          juju
                          IIRC this has been turned into a commercial plugin, namely SKALP, support / updates to this will then have ceased.
                            ahdims
                            Just wondering if this extension is supported in sketchup 2017 or it will be supported for sketchup 2017
                            • jujuJ Offline
                              juju
                              please read the two posts directly above yours
                              • zooenZ Offline
                                zooen
                                December : 2015
                                @skalp said:
                                @pilou said:
                                @Skalp
                                The Skalp Team
                                June 2018 : Does Skalp is existing in French ?
                                  Bandika
                                  It is not working in 2015, when I click on the icon,nothing happens. V0.5.8
                                  Any idea?
                                    gnlmrc60b22f205v
                                    Unfortunately I can not load the plugin on SketchUp 2018.
                                    This is the error warning on startup:
                                    Error: #<Win32::Registry::Error: Impossibile trovare il file specificato.>
                                    C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/win32/registry.rb:288:in OpenKey' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/win32/registry.rb:429:in open'
                                    C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/win32/registry.rb:540:in open' c:/users/agnol/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/piga_richsection/richsection.rbs:430:in userFileLocations'
                                    c:/users/agnol/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/piga_richsection/richsection.rbs:546:in <module:RSection>' c:/users/agnol/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/piga_richsection/richsection.rbs:90:in module:PiGa'
                                    c:/users/agnol/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/piga_richsection/richsection.rbs:89:in <main>' C:/Users/agnol/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:32:in eval'
                                    C:/Users/agnol/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:32:in require' C:/Users/agnol/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:32:in <top (required)>'
                                    C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in load'
                                    C:/Users/agnol/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/PiGa_RichSection.rb:36:in register_extension' C:/Users/agnol/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/PiGa_RichSection.rb:36:in module:PiGa'
                                    C:/Users/agnol/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/PiGa_RichSection.rb:14:in `<top (required)>'
                                      It might not work in newer versions.
                                      I'm unsure if it's still supported.
                                      How did you download it and then install it ?
                                      It seems to be missing an RBS file in its subfolder...
                                      As specified in the error message.
                                      If it's there it might not get read if you haven't installed v2018 properly !
                                      To try and fix a bad installation do the following...
                                      Close SketchUp if it's open.
                                      Find the v2018 installer's exe file - probably in your Downloads folder ?
                                      Select its icon > right-click > context-menu > "Run as administrator"
                                      When prompted choose 'Repair'.
                                      Restart SketchUp to see if that has helped...
                                        pibuz
                                        Hi all! I know this is a very old plugin but seems like it's the only one capable of making dashed lines projections of what is upper than the section plane 🤣
                                        I get the same message as the last user reported, but Su is correctly installed, and the plugin too..
                                        Can anybody give some pieces of advices to get it work or is it impossible?
                                        Or, is there a newer plugin making the same thing (dashed projections of sections)?
                                        many many thanks in advance!
                                        WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                                        • jujuJ Offline
                                          juju
                                          IIRC Rich Section went on to become SKALP.
                                            pibuz
                                            OHHH I see! Thanks!
                                            • 11
                                            • 12
                                            • 19
                                            • 20
                                            • 10 / 20
