    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 213.9k Views 85 Watching
    • jim smithJ Offline
      jim smith
      I loaded Dimitri's fix to replace the expired files, re-booted SU opened a model, selected create section and got the section box to appear on the model. I haven't time to experiment with it but apparently it will at least open on a PC (I am running an ASUS pc with i7, 16GB).
      I hope pgarmyn has not lost interest because of "skalp". I am sure many people would like the option to use this free plugin.
      "Out of clutter find simplicity,
      from discord find harmony,
      In the middle of difficulty lies opportunity"
      Albert Einstein
        Dimitri972
        Most of Skalp section materials are free on 3d warehouse. You can combine them with this plugin for amazing result. And don't forget to make group or component before taking section.
        Actually this plugin is crashing in many situation but it is still usefull plugin.
          piyanan
          Hello any one
          I install plugin for sketchup 2015-64 bit for windows and saw tool in sketchup is OK
          then I click 1st tool is (Create RechSection)and I did my model it is notthing to happen.
          and same other tool
            lippo
            Hi, I have unloaded the plugin, but I don't succeed in making him/it work... I make click on the icon it creates richsection and it doesn't happen anything. I use SUpro2015 64bit 😳 😳
              Mike8P
              It doesn´t seem to work on SketchUp 2015...
              Any issue?
                @Skalp
                2 trivial questions 😄
                Does the Skalp material can be used as normal material for any facades surfaces ?
                Does SKalp is existing in French ?
                • SkalpS Offline
                  Skalp
                  @pilou said:
                  @Skalp
                  Yes Skalp materials can be used like normal SketchUp materials.
                  At this moment there isn't a French version. But we are working on translations at this moment.
                  The Skalp Team
                  Skalp
                  http://www.skalp4sketchup.com
                  • SkalpS Offline
                    Skalp
                    Skalp section materials are intended to be used with Skalp. Skalp materials are much more then just textures.
                    The Skalp team
                    Skalp
                      antoinelepoutre
                      does not work in SU2016 on WIN7
                        Ader89
                        Hi, I put this aap on my sketchup 2015, every bottom is working including the menus, but when i tried to use create richsection its don´t work, the section plane just don´t appear on screen, what can i do to solve it? the app ins´t compatible with sketchup 2015? Thanks
                        • romboutR Offline
                          rombout
                          @dimitri972 said:
                          I fixed time expired problem. Here it is:
                          http://www.mediafire.com/download/brjzmnqzbcv38fp/RichSectionv0.5.8FULLByDimitri.zip
                          Author was't answering question for months. I tried to fixing expired issue and fixed. If this isn't wanting thing in this forum, you can delete my post. I don't know forum rules.
                          It sort of works when im doing a single group, crashes when there is more than 1 though.
                          osx 10.11.2
                          su2015
                          • E Offline
                            Ekon
                            I don´t get it to work properly on Win 10 and SU 2016 64bit pro. I get a simple section but no materials, no options dialog and if I do a second section it does it like native SU.
                            None of the other buttons work. It says select Rich Section first, but my section is already selected.
                            Some help would be appreciated.
                            thanks
                              RBCADDSVCS
                              I've tried and tried to get this to work.
                              I've installed, uninstalled, and reinstalled, and nothing works.
                              I'm running Sketchup Pro 2014.
                              The toolbars shows up, and the drop-down menu shows up, but when I click on them nothing happens at all.
                              The log file says my license is expired.
                              I didn't think it needed a license.
                              What's up with that?
                              • H Offline
                                Haddal88
                                Hello!
                                I am trying this plugin after I saw the amazing videos.
                                When I press the button to create the section, nothing happens.
                                Running Pro trial on Sketchup 2017 Make.
                                Any reasons?
                                Running Windows 7, Intel i7.
                                Thanks in advance!
                                  Run it with the Ruby Console open.
                                  There might be incompatibilities with v2017 ?
                                  It is two years without an update...
                                  • jujuJ Offline
                                    juju
                                    IIRC this has been turned into a commercial plugin, namely SKALP, support / updates to this will then have ceased.
                                      ahdims
                                      Just wondering if this extension is supported in sketchup 2017 or it will be supported for sketchup 2017
                                      • jujuJ Offline
                                        juju
                                        please read the two posts directly above yours
                                        • zooenZ Offline
                                          zooen
                                          December : 2015
                                          @skalp said:
                                          @pilou said:
                                          @Skalp
                                          The Skalp Team
                                          June 2018 : Does Skalp is existing in French ?
                                            Bandika
                                            It is not working in 2015, when I click on the icon,nothing happens. V0.5.8
                                            Any idea?
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 19 / 20
