    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 213.9k Views 85 Watching
      Run it with the Ruby Console open.
      There might be incompatibilities with v2017 ?
      It is two years without an update...
      • jujuJ Offline
        juju
        IIRC this has been turned into a commercial plugin, namely SKALP, support / updates to this will then have ceased.
          ahdims
          Just wondering if this extension is supported in sketchup 2017 or it will be supported for sketchup 2017
          • jujuJ Offline
            juju
            please read the two posts directly above yours
            • zooenZ Offline
              zooen
              December : 2015
              @skalp said:
              @pilou said:
              @Skalp
              Does SKalp is existing in French ?
              At this moment there isn't a French version. But we are working on translations at this moment.
              The Skalp Team
              June 2018 : Does Skalp is existing in French ?
                Bandika
                It is not working in 2015, when I click on the icon,nothing happens. V0.5.8
                Any idea?
                  gnlmrc60b22f205v
                  Unfortunately I can not load the plugin on SketchUp 2018.
                  This is the error warning on startup:
                  Error: #<Win32::Registry::Error: Impossibile trovare il file specificato.>
                  C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/win32/registry.rb:288:in OpenKey' C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/win32/registry.rb:429:in open'
                  C:/Program Files/SketchUp/SketchUp 2018/Tools/RubyStdLib/win32/registry.rb:540:in open' c:/users/agnol/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/piga_richsection/richsection.rbs:430:in userFileLocations'
                  c:/users/agnol/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/piga_richsection/richsection.rbs:546:in <module:RSection>' c:/users/agnol/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/piga_richsection/richsection.rbs:90:in module:PiGa'
                  c:/users/agnol/appdata/roaming/sketchup/sketchup 2018/sketchup/plugins/piga_richsection/richsection.rbs:89:in <main>' C:/Users/agnol/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:32:in eval'
                  C:/Users/agnol/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:32:in require' C:/Users/agnol/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:32:in <top (required)>'
                  C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in require' C:/Program Files/SketchUp/SketchUp 2018/Tools/extensions.rb:197:in load'
                  C:/Users/agnol/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/PiGa_RichSection.rb:36:in register_extension' C:/Users/agnol/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/PiGa_RichSection.rb:36:in module:PiGa'
                  C:/Users/agnol/AppData/Roaming/SketchUp/SketchUp 2018/SketchUp/Plugins/PiGa_RichSection.rb:14:in `<top (required)>'
                    It might not work in newer versions.
                    I'm unsure if it's still supported.
                    How did you download it and then install it ?
                    It seems to be missing an RBS file in its subfolder...
                    As specified in the error message.
                    If it's there it might not get read if you haven't installed v2018 properly !
                    To try and fix a bad installation do the following...
                    Close SketchUp if it's open.
                    Find the v2018 installer's exe file - probably in your Downloads folder ?
                    Select its icon > right-click > context-menu > "Run as administrator"
                    When prompted choose 'Repair'.
                    Restart SketchUp to see if that has helped...
                      pibuz
                      Hi all! I know this is a very old plugin but seems like it's the only one capable of making dashed lines projections of what is upper than the section plane 🤣
                      I get the same message as the last user reported, but Su is correctly installed, and the plugin too..
                      Can anybody give some pieces of advices to get it work or is it impossible?
                      Or, is there a newer plugin making the same thing (dashed projections of sections)?
                      many many thanks in advance!
                      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
                      • jujuJ Offline
                        juju
                        IIRC Rich Section went on to become SKALP.
                          pibuz
                          OHHH I see! Thanks!
                          • 16
                          • 17
                          • 18
                          • 19
                          • 20
                          • 20 / 20
