    [Plugin] FloorGenerator ( Updated 6-Apr-2017)
    331 Posts 109 Posters 341.4k Views 109 Watching
    • sdmitchS Offline
      sdmitch
      @mumbus said:
      First off let me say that this plugin is amazing and I use it often. I do have a question about it. Often times when I am generating a floor with a wood material already attached to the surface, it rotates the texture 90 degrees when it completes the floor. So the texture ends up running perpendicular to the board. I have tried various solutions like rotating the texture 90 degrees before running the plugin, reinserted the texture, etc. Any thoughts on this?
      The plugin doesn't do any UV mapping of the existing material so each "board" is treated as an independent face with the material applied to each just as if you did it manually.
      http://sdmitch.blogspot.com/
        mumbus
        Perhaps I am not explaining myself properly. I have attached an animated .gif as an example. I use this to randomly distribute the texture around the boards.
        • sdmitchS Offline
          sdmitch
          If you want the "Wood" pattern to look just like the face with the material applied then you have to map the texture to each face that is created by FloorGenerator.
            devrimimar
            I downloaded several times but It does not work? Any idea ?
            • sdmitchS Offline
              sdmitch
              No, but if you want to provide a little more information like Sketchup version, where you are downloading from, where are you downloading to, Ruby Console output when trying to use, etc., I might be able to help.
              • Mousa_SAM Offline
                Mousa_SA
                Hello Sdmitch,
                Firstly thanks for this great plugin, it is very useful, I have a feature request and I would be appreciated if you can add it to your plugin.
                V-ray 3.4 for Sketchup have a features is called MultiSubTex and TriPlanar, these features will add a ability to random the texture for the same component after rendering (in V-ray Frame Buffer), so it will be great if your plugin have an option to make similar tiles as component, that will reduce the file size in some cases, Note it will put the tiles which have been cut (by the face boundary) in one group, So what so you think ?
                • sdmitchS Offline
                  sdmitch
                  Sorry, but I think not.
                  • deaneauD Offline
                    deaneau
                    @Mousa_SA is this a post rendering effect?
                    I think a good way is to provide the developers with pictures. not all dev´s have all plugins on the disk. vray is really a little bit special. i like that some render engine developer provide sketchup. what do you think about to ask the vray developer,too?
                    @sdmitch i must repeat me by myself... your "small" plugins will be every time helpful. some plugins i use every time when i have a project with sidewalks etc. or when i have an other problem 😉
                    some plugins i will never missing. nice that you have now an email contact address.
                    i will tell you a thank you.
                    Dean
                    • Mousa_SAM Offline
                      Mousa_SA
                      Dean
                      Yes Dean, you can say that, in Sketchup 2017 it's has an object IDs Feature, so Chaos group will implement MultiSubTex, you can read more about it here:
                      https://docs.chaosgroup.com/display/VRAYSKETCHUP/MultiSub+Tex
                      And Ithil made this tutorial for the TexTriplaner Feature:
                      https://www.youtube.com/watch?v=VVD_UfJA5Hc
                      sdmitch, maybe that deserve another look !
                      • yourpasswordisY Offline
                        yourpasswordis
                        I saw it posted on the first page of this plugin, a LAP setting would be AMAZING.
                        I'm in Architectural Visualization and material properties don't allow for accurate displacement maps. A plugin like this is tantalizingly close to creating the repeating clap/lap siding which our pro-user group needs. Sketchup has been blessed with rendering engines but this modelling aid is missing!
                        The difference between good enough and awesome is huge
                        • sdmitchS Offline
                          sdmitch
                          I did try to develop a clapboard option several years ago but never produced a satisfactory one. Perhaps it would be worth another look.
                            seghier
                            hello
                            where is the link ?
                              You will find Floor Generator here! 😉
                              http://sdmitch.blogspot.fr/
                                meegg
                                Your plugin is amazing. Thank You.
                                Is there a possibility to make some additional options in octagons pattern? Option to give the size of two tiles: the big one and the smaller one. It would be very helpful.
                                • sdmitchS Offline
                                  sdmitch
                                  Have you looked at the "Hopscotch" patterns?
                                  • sdmitchS Offline
                                    sdmitch
                                    A basic "Clapboard" option has been added.
                                      peerman
                                      That is great!! Thank you for the LAP addition!
                                      iMac i7 4,2GHz, 32GB RAM, OS X 10.13.5, Sketchup 2018 Pro, ArchiCAD 21, V-Ray 3.6
                                        meegg
                                        "Hopscotch" pattern doesn't fit 😉
                                        It must be octagonal pattern but with specific dimensions of two tiles: the big one - octagonal and smaller one - square tile.
                                          rogalxxx
                                          I'm having problems with the plugin in SU 2017. Su 2015 seems to be working fine.
                                          Using even stock settings I get a lot of random tiles missing.
                                          • sdmitchS Offline
                                            sdmitch
                                            Once again SU2017 is acting in a different way than previous versions. Maybe there is a solution but I doubt it.
                                            • 16
                                            • 17
                                            • 4 / 17
