[Plugin] FloorGenerator ( Updated 6-Apr-2017)
@deaneau said:
@Mousa_SA is this a post rendering effect?
I think a good way is to provide the developers with pictures. not all devยดs have all plugins on the disk. vray is really a little bit special. i like that some render engine developer provide sketchup. what do you think about to ask the vray developer,too?@sdmitch i must repeat me by myself... your "small" plugins will be every time helpful. some plugins i use every time when i have a project with sidewalks etc. or when i have an other problem
some plugins i will never missing. nice that you have now an email contact address.i will tell you a thank you.
Dean
Yes Dean, you can say that, in Sketchup 2017 it's has an object IDs Feature, so Chaos group will implement MultiSubTex, you can read more about it here:
https://docs.chaosgroup.com/display/VRAYSKETCHUP/MultiSub+TexAnd Ithil made this tutorial for the TexTriplaner Feature:
https://www.youtube.com/watch?v=VVD_UfJA5Hcsdmitch, maybe that deserve another look !
I saw it posted on the first page of this plugin, a LAP setting would be AMAZING.
I'm in Architectural Visualization and material properties don't allow for accurate displacement maps. A plugin like this is tantalizingly close to creating the repeating clap/lap siding which our pro-user group needs. Sketchup has been blessed with rendering engines but this modelling aid is missing!
I did try to develop a clapboard option several years ago but never produced a satisfactory one. Perhaps it would be worth another look.
hello
where is the link ? -
You will find Floor Generator here!
http://sdmitch.blogspot.fr/ -
Your plugin is amazing. Thank You.
Is there a possibility to make some additional options in octagons pattern? Option to give the size of two tiles: the big one and the smaller one. It would be very helpful. -
Is there a possibility to make some additional options in octagons pattern? Option to give the size of two tiles: the big one and the smaller one. It would be very helpful.Have you looked at the "Hopscotch" patterns?
A basic "Clapboard" option has been added.
That is great!! Thank you for the LAP addition!
"Hopscotch" pattern doesn't fit
It must be octagonal pattern but with specific dimensions of two tiles: the big one - octagonal and smaller one - square tile. -
I'm having problems with the plugin in SU 2017. Su 2015 seems to be working fine.
Using even stock settings I get a lot of random tiles missing.
Once again SU2017 is acting in a different way than previous versions. Maybe there is a solution but I doubt it.
So have 2015, 2016, 2017 is a good thing!
(and that divide by 3 number of plugins (if distributed) for a more speed launch)
so, no cure for this bug? any chance It will be patched?
Any other plugin that can generate nice tiles? -
Protrude by Jim + Lattice Maker by TIG + FredoScale by Fredo?
I have that same problem.Is there a solution?
Murat
You could always do a work-around by saving the SKP in 2016 version, open SU2016, do what you want there with the plugin, save and open in 2017 again. I know, far from ideal.
Who has any experience with Oob Layouts? It also reports only compatible up to 2015, but I have often had where extensions say that and work fine in the later (supposedly incompatible) SU version. Anybody willing to trial it?
I have tested FloorGenerator in SU2017 and had no problem with missing tiles.
Could you post your model so I could test it myself?
here, Floor generator on stock settings, two identical planes-second one with tiles applied.
looks like geometry has some random lines and faces, even though I have set no random parameter.
I confirm, this issue is happening with me too,although there are no other plugins are active with it.
With your input, this post could be even better ๐
