    [Plugin] QuadFaceTools
    680 Posts 116 Posters 745.0k Views 116 Watching
    • jo-keJ
      jo-ke
      I would like to use this plugin to texture a curtain.
      3D Warehouse
      (3dwarehouse.sketchup.com)
      I tried to convert the mesh but it doesn't work.
      What did I wrong?
      same with that one:
      3D Warehouse
      http://www.zz7.de
      • jo-keJ
        jo-ke
        I really don't know how to convert the mesh, to let the texturing tool work.
        anybody has got an idea?
        http://www.zz7.de
          alamin
          any pdf manual?
          • BoxB
            Thomthom, any chance of adding a selection option where you can step the ring/loop selected?
            So, instead of adding or subtracting, each click moves the selection one loop over and deselects the one you are on.
            Edit: I'll just add this gif to help explain what I mean,I have a workaround but it would be helpful to have.
              No French UI version ❓
                @cmoreink said:
                How do you import an .obj file?
                It crashes every time I try ---> file, import, select .obj file "oops, an error occurred 😞" a message displays (box) askes me if I want to send a report.
                The tool bar displays ok
                Any idea why?
                Can you share this obj file please? (You can PM me if you don't want to share the file publicly)
                  That's a good idea. Logged it in the issue tracker: https://bitbucket.org/thomthom/quadface-tools/issues/107/shift-loop
                    No. ...not yet that is... I just set up a Crowdin project for this extension. πŸ˜‰
                    But give me some time to localise SUbD and move to my new home. πŸ˜„
                      Thx for the info, i had believed that i Miss something! 😎
                      About the Crowdin, seems you must save after every new each line item input
                      else seems that is not save as general input for several items! ❓
                        I'm sorry, I don't follow..?
                          No problem it's just for the use of Crowdin who seems curious with the Save of new translation! πŸ˜„
                          • cmeedC
                            cmeed
                            Hi Thom Thom
                            I'm getting an error box when ever I open SU heres and image of the box that appears.
                            its seems to run ok though when i close the window.
                            cheers in advance
                            chris
                              mae_fierros
                              How come the "Offset Loop" under my Quadface tools seems not to work/function in SU 2017 ? what is the most compatible extension for the 2017 version? thank you in advance
                                Offset Loop is still a work in progress.
                                It was a experimental feature Thom added a few versions ago.
                                Sometimes it works ok other times it fails. Always send crash reports when it fails.
                                • K
                                  Kuu
                                  I've recently started learning to do quad modelling in other apps but these tools are great for doing stuff in sketchup! However there's a couple of tools I feel are missing which would be great to roundout QuadFaceTools:
                                  1. Offset with edges. Basically just an offset tool but that builds all the connecting lines so you don't have to draw them in manually to preserve the quad topology, which is a drag. I tried looking at all offset plugins but none seems to do this relatively simple thing:
                                  Offset with edges
                                  Above offset with edges; below regular offset. (I'm not sure how the intersections would be though, but at least for simple offsets it would be easy)
                                  1. Quadify N-gon. Basically automatically divide any convex polygon into quads, being able to preview and choose division type before finalizing.
                                  Quadify
                                  1st row is edge splitting but works with any N-gon, i suppose it would be nice to also make the extra loops.
                                  2nd row is central but only works with N-gons divisible by two above N = 6
                                  3rd row is grid splitting which is the best solution for large N values to avoid nasty poles.
                                  4 and 5 provide other alternatives...
                                  If these things could be added that would be awesome! Or if other plugins I don't know about already do this that would be nice too...
                                    rtd
                                    I hope that this is the best place for this question.
                                    What is the relationship, if any, between 'vertexTools', 'subD', and quadFaceTools?
                                    Are they independent or is one or more required for the other(s) to function?
                                    Thank you
                                    • BoxB
                                      They are independent tools that work together. None are needed for others to work but they are authored by the same magician and therefore help you to pull a rabbit out of your hat or a hare out of your ....
                                        SUbD do work best with quad topology - and for that you would be better of using QFT to author the mesh.
                                          @cmeed said:
                                          Hi Thom Thom
                                          cheers in advance
                                          chris
                                          Sorry man - I haven't visited this thread for a while. Do you still have this issue?
                                          What version of QFT and TT_Lib do you have installed?
                                            That's for the details suggetsions. I logged it in the issue tracker.
                                            404 β€” Bitbucket
                                            (bitbucket.org)
                                            Meanwhile you can try out TIG's Split Tools: http://sketchucation.com/forums/viewtopic.php?t=43376
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 33
                                            • 34
                                            • 27 / 34
