    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
      penumbra
      Thanks for looking at it. And now for the great search of the other offending plugin... How I wish there was a quicker way to detect and find plugin clashes.
      Edit: On second thought. If Dave is seeing it also then there is a little issue with the plugin? Unless Dave and I have a similar plugin clashing with it?
        I think we need Fredo's input.
        • fredo6F Offline
          Thanks for signaling. This is a side effect of the fix for bugsplat in SU2017.
          I fixed it and will re-publish.
          By the way, the fact that it work the second time is due to the fact that the first time, FredoScale chains two operations
          • Make Unique
          • Stretching
          The bug was due to an unvolontary Undo, but the make Unique remained, so that it works fine the second time.
            penumbra
            Thanks fredo.
            • fredo6F Offline
              NEW RELEASE: FredoScale v3.0a - 14 Jan 17
              FredoScale 3.0a is a maintenance release providing corrections to previous versions, and should be installed for all SU Versions.
              • gudio83G Offline
                gudio83
                Any idea how to resolve this bug?
                SU2017 x64, Win10
                  What bug? Your screen shot doesn't clearly indicate a problem.
                  • gudio83G Offline
                    gudio83
                    the menu bar is small and i can't resize it. I must scroll every time to see all options / results.
                    This bug appear only on "Labels with areas". The same problem on my PC and my laptop.
                      So this has nothing to do with FredoScale.
                      • fredo6F Offline
                        SU2017 x64, Win10
                        SU2017 has changed a few things in the dimensioning of web dialogs.
                        Normally, you should be able to resize and adjust the size, which would be kept for the next use.
                        I just have one doubt: not sure I released the fix in FredoTools 3.0a (i.e. the capability to resize the dialog box).
                        • E Offline
                          elfis
                          First of all that you for the best plugin in sketchup. Enginsh is not my native language so I record this short clip to explain my problem.
                          When I copy group of objects and start to stretching one of them I'm getting this conflict.
                          I know there is problem with components when they all not unique but why with groups ?
                          It was fine before format of windows with different versions of plugin.
                          For now i'm using Sketchup 2016 and latest plugin with libs.
                          Kind Regards
                          Patrick
                          ps. Sorry if this is noob question.
                          • fredo6F Offline
                            In Sketchup, a group just copied behaves like Components...
                            ...unless you just edit (i.e. double click) the group you copied.
                            This is probably for optimization.
                            • E Offline
                              elfis
                              Hi, thanks for the answer . Before I have never have this problem, I found small fix on this "model" by removing group of objects inside this group.
                              Group Tree
                              • array81A Offline
                                array81
                                I installed the last version but I have only the "box" tools, no "target" tools. Any ideas?
                                  They don't show even after you enabled them and restarted SketchUp?
                                    georgeoakblaster
                                    Is there a way to get the dimension tags to update after you resize using the 'box stretching' feature? At the moment I re-add them manually to get them to update to the correct measurement.
                                    Thanks for this great plugin Fredo.
                                      @georgeoakblaster said:
                                      Like this?
                                        georgeoakblaster
                                        Thanks,
                                        I should have mentioned this is when using 'enter new dimensions' which is on the right click dialogue box.
                                        George
                                          Maybe you could post a screen shot of what you are trying to describe because it isn't clear.
                                          The New Dimension window is intended to allow you to type in the new dimension.
                                          What is the "dimension tag" you refer to?
                                            kevsterman
                                            Hey guys. I've recently discovered radial bend and its just brilliant. Its really helping me with some illustrations I'm doing. I was wondering if there's a way for the materials to bend as well as the model. So far the materials either stay the same or go a bit skew-whiff, they don't bend in the same directions as the face they're on. Any way of doing this?
                                            "Avoid keeping more than 3 items on your desk that you can't fit into your mouth."
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 56
                                            • 57
                                            • 38 / 57
