    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 1.9m Views 79 Watching
    • BoxB Offline
      Here's a quick version without the top bit.
      http://i.imgur.com/vYhLjhg.gif
      • cottyC Offline
        cotty
        klick to animate
        my SketchUp gallery
          Each Fredo's plugin is a little true gem of possibilities! โ˜€
          You must read the manuals in deepth! ๐Ÿค“
          you will be astonished!
          • BoxB Offline
            A quick soap dish.
            I can add the proxy if anyone wants it.
              That's some hard-core poly-minimal models you making there ๐Ÿ˜„
              • cottyC Offline
                cotty
                my SketchUp gallery
                • pbacotP Offline
                  Great demos everyone!
                  • bazB Offline
                    baz
                    @box said:
                    A quick soap dish.
                    Yes please Box. I cant see how I get a different result with the exact same mesh...
                    • BoxB Offline
                      Baz you need to use the crease tool on that section, including the corners from memory.
                      I'm away from my PC just now so can't give you the proxy until later.
                      • bazB Offline
                        baz
                        Ah, creasing, forgot about that. I wish there was a SubD for Dummies, I would certainly buy it...
                        • BoxB Offline
                          Here ya go Baz, did a quick gif to show the creasing for you.
                          Soap Dish Proxy.skp
                          • bazB Offline
                            baz
                            Thanks Box. I'm getting there.
                            • BoxB Offline
                              The proxy is there under the gif, if you want it.
                              • aarondietzenA Offline
                                aarondietzen
                                Another lunch time model.
                                "Imagination is more important than knowledge..."
                                - Albert Einstein
                                • pbacotP Offline
                                  Hey Aaron. Nice job!
                                  • ithilI Offline
                                    ithil
                                    Hey.
                                    One more test SubD in real work. I tried to make a chandelier by photo. Fbai 3077/6 NERO.
                                    Small bug with uv maping on chandel, but only for rendering. maybe it's a v-ray
                                    bugs.
                                    V-ray render
                                    subd hi
                                    • ntxdaveN Offline
                                      ntxdave
                                      Great job, great example and great detail Ithil. Thanks for sharing...........
                                      Press F1...thank me later
                                      • cottyC Offline
                                        cotty
                                        So the first image isn't the photo?
                                        ๐Ÿ˜ฎ ๐Ÿ‘
                                        my SketchUp gallery
                                        • jo-keJ Offline
                                          jo-ke
                                          Wow. Good work!
                                          http://www.zz7.de
                                            !! I thought the first image was the reference photo!
                                            Well done!
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 83
                                            • 84
                                            • 39 / 84
