    [Plugin] LSS Toolbar 2.0 Beta
    68 Posts 39 Posters 79.2k Views 39 Watching
      What tool exactly?
      Seems Lss works fine in 2016!
      Ah Yes The Stick tool : curious I have seen the Stick Dialog Box one time but then after to close it impossible to re-appear! ๐Ÿ˜ž
      http://s6.postimg.org/lilkfpzwx/lss.jpg
      Someone can post the file lss_mshstick.rb modified for 2016 ?
        DreamPsi
        I would but unfortunately I had to reinstall windows ten due to a virus but if you look at the post by driven a few posts up you would see exactly where in the rb file you need to change the code to the corrected code. it can be edited in any text editor, I find notepad++ to be an excellent fast and easy app that's free for editing minor script changes
        ill will reinstall sketchup and re dl the lss tool bar and post the updated rb for mshstick.rb in lss tool bar plugin at a later date.
        • F
          frankleng
          @pilou said:
          What tool exactly?
          I had the same problem. NOw it works.
          lss_mshstick.zip
            NOw it works.
            Not yet! Even more it's bugsplat and crashes! ๐Ÿ˜‰
            • H
              haydenr
              I am also having the issue where it cant find the support html files. Every tool replies with the same pathing issue.
              • Bob JamesB
                Bob James
                This problem has existed for almost two years!! ๐Ÿ˜
                See earlier post in this thread dated..Mon Sep 22, 2014 12:15 pm
                • C
                  crazyteaboy
                  Does this work with SU2017? The folders mentioned to copy the files to, the Plugin one doesn't exist!!! Will there be an update for SU2017?
                  • majidM
                    majid
                    I also have the same question please!
                      Use the RBZ version in the PluginStore to install, but also read the posts in this thread about finding the 'resources' folder, and ensuring files are in the right place etc...
                      It is an old tool so its efficacy is uncertain...
                      • C
                        crazyteaboy
                        That's my point. I followed all the instructions on where to put the extracted files, and the Plugin folder does not exist. I did find where to put the so called Plugin files, and the toolbar runs, but no matter which tool I use, it reports an error that it cannot find an html file, so I can only guess this version is not compatible with SU2017.
                          This is an old Plugin, so its usefulness is unsure...
                          If you install it from its RBZ, it goes directly into the Plugins folder, that step is sorted.
                          Now you are missing some files in the Resources folder...
                          The folders in the RBZ are badly arranged !
                          Do not forget that this Plugin is old and poorly configured...
                          But if you want to try it out, then you'll need to either rewrite its code to look into the correct folder [needs some coding ability***] OR you need to look into the subfolders added within its installation
                          C;\Users\USERNAME\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins\lss_toolbar
                          and you then need to copy all of the the files / subfolder+files from within there
                          C;\Users\USERNAME\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins\lss_toolbar\Resources\en-US
                          *1
                          and paste them into here [NB: you will probably be prompted for admin-rights etc...]
                          C;\Program Files\SketchUp\SketchUp 2017\Resources\en-US
                          Restart SketchUp and the missing files are now found...
                          ***Alternative, edit the RB files and re-path them to look into the shipped plugin's own subfolder's contents for the html files etc... *1
                          • K
                            kirill2008
                            Hello All,
                            LSS Toolbar is an outdated plugin (as TIG correctly stated) and last version of SketchUp, which LSS Toolbar is compatible with is unfortunately SketchUp 2013.
                            The point is that I'm not able to continue developing of freeware projects like LSS Toolbar at the moment, so I highly recommend to look for some other alternatives to LSS Toolbar, which have similar functionality.
                            • majidM
                              majid
                              @kirill2008 said:
                              Hello All,
                              ๐Ÿ˜ฎ ๐Ÿ˜ฎ What a pity!
                              • E
                                Einstein
                                I guess the plugin should be working with SU 8. The toolbar opens with errors in all tools:
                                "No definition "callRuby"", "No definition "get_settings"", "No definition "obtain_defaults""
                                They don't let me continue working with this plugin, regardless I answer YES or NO.
                                Unfortunately, Ruby console is empty.
                                I have rather put the files into correct folders.
                                • 4 / 4
