    [Plugin] LSS Toolbar 2.0 Beta
    68 Posts 39 Posters 75.4k Views 39 Watching
      DreamPsi
      thanks I will try my hand... but seing how I'm rusty at programing that hand will probably find my face several times before finding the other hand lol.
        driven
        @DreamPSI,
        I imagine you are now getting a 'less fatal' No Method error for 'lines'...
        but you could try to fix it properly...
        the to_a method used to take a String and 'split' it into an array...
        as it's no longer available you need to 'split' any String yourself...
        so to find what we need to 'split' we first need to know what @stick_vec is...
        on line 108 @stick_vec=Geom::Vector3d.new(0,0,-1), but if you do a test in 'Ruby Console' it's not a String and @stick_vec.to_a will work, so we keep digging...
        on line 1063 @stick_vec=Sketchup.read_default("LSS_Mshstick", "stick_vec", nil), will return a String and
        on line 1073 we see it's being passed to the method that's failing using self.settings2hash...
        so now we have a String and we know it was once in the format of (n,n,n) we can try splitting it using ','...
        @stick_vec.to_a.join(";") >> @stick_vec.split(',').join(";")
        but, there is another place as well, so use search and replace for @stick_vec.to_a to find it...
        @bounce_vec.to_a possibly has the same solution...
        • E Offline
          elizabeth001au
          Please excuse me if I have missed something. I am excited about this plugin. Downloaded it today and went to use it. Can not
          use any tool. Each tool give me the message " Cannot find file LSS_toolbar/pathface.html" I have read the installation instructions and have checked that everything is in correct folder. The same message repeats for each different tool. Thanks.
            DreamPsi
            open ruby script console, copy and then post the results here, when you try to click on the tool bar buttons
            idk maybe you dled a baddy
            • E Offline
              elizabeth001au
              Thankyou DreamPSI. Yes, I was able to make the toolbar appear to be active. However, unfortunately this tool is not working with Sketchup Pro 2016. The last version it is compatible with is Sketchup 2013. This is due to some changes in API. Shame really...I was very keen to play with this, as it appears to be just what I need.
                What tool exactly?
                Seems Lss works fine in 2016!
                Ah Yes The Stick tool : curious I have seen the Stick Dialog Box one time but then after to close it impossible to re-appear! ๐Ÿ˜ž
                http://s6.postimg.org/lilkfpzwx/lss.jpg
                Someone can post the file lss_mshstick.rb modified for 2016 ?
                  DreamPsi
                  I would but unfortunately I had to reinstall windows ten due to a virus but if you look at the post by driven a few posts up you would see exactly where in the rb file you need to change the code to the corrected code. it can be edited in any text editor, I find notepad++ to be an excellent fast and easy app that's free for editing minor script changes
                  ill will reinstall sketchup and re dl the lss tool bar and post the updated rb for mshstick.rb in lss tool bar plugin at a later date.
                  • F Offline
                    frankleng
                    @pilou said:
                    What tool exactly?
                    I had the same problem. NOw it works.
                    lss_mshstick.zip
                      NOw it works.
                      Not yet! Even more it's bugsplat and crashes! ๐Ÿ˜‰
                      • H Offline
                        haydenr
                        I am also having the issue where it cant find the support html files. Every tool replies with the same pathing issue.
                        • Bob JamesB Offline
                          Bob James
                          This problem has existed for almost two years!! ๐Ÿ˜
                          See earlier post in this thread dated..Mon Sep 22, 2014 12:15 pm
                            crazyteaboy
                            Does this work with SU2017? The folders mentioned to copy the files to, the Plugin one doesn't exist!!! Will there be an update for SU2017?
                            • majidM Offline
                              majid
                              I also have the same question please!
                                Use the RBZ version in the PluginStore to install, but also read the posts in this thread about finding the 'resources' folder, and ensuring files are in the right place etc...
                                It is an old tool so its efficacy is uncertain...
                                  crazyteaboy
                                  That's my point. I followed all the instructions on where to put the extracted files, and the Plugin folder does not exist. I did find where to put the so called Plugin files, and the toolbar runs, but no matter which tool I use, it reports an error that it cannot find an html file, so I can only guess this version is not compatible with SU2017.
                                    This is an old Plugin, so its usefulness is unsure...
                                    If you install it from its RBZ, it goes directly into the Plugins folder, that step is sorted.
                                    Now you are missing some files in the Resources folder...
                                    The folders in the RBZ are badly arranged !
                                    Do not forget that this Plugin is old and poorly configured...
                                    But if you want to try it out, then you'll need to either rewrite its code to look into the correct folder [needs some coding ability***] OR you need to look into the subfolders added within its installation
                                    C;\Users\USERNAME\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins\lss_toolbar
                                    and you then need to copy all of the the files / subfolder+files from within there
                                    C;\Users\USERNAME\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins\lss_toolbar\Resources\en-US
                                    *1
                                    and paste them into here [NB: you will probably be prompted for admin-rights etc...]
                                    C;\Program Files\SketchUp\SketchUp 2017\Resources\en-US
                                    Restart SketchUp and the missing files are now found...
                                    ***Alternative, edit the RB files and re-path them to look into the shipped plugin's own subfolder's contents for the html files etc... *1
                                      kirill2008
                                      Hello All,
                                      LSS Toolbar is an outdated plugin (as TIG correctly stated) and last version of SketchUp, which LSS Toolbar is compatible with is unfortunately SketchUp 2013.
                                      The point is that I'm not able to continue developing of freeware projects like LSS Toolbar at the moment, so I highly recommend to look for some other alternatives to LSS Toolbar, which have similar functionality.
                                      • majidM Offline
                                        majid
                                        @kirill2008 said:
                                        Hello All,
                                        ๐Ÿ˜ฎ ๐Ÿ˜ฎ What a pity!
                                        • E Offline
                                          Einstein
                                          I guess the plugin should be working with SU 8. The toolbar opens with errors in all tools:
                                          "No definition "callRuby"", "No definition "get_settings"", "No definition "obtain_defaults""
                                          They don't let me continue working with this plugin, regardless I answer YES or NO.
                                          Unfortunately, Ruby console is empty.
                                          I have rather put the files into correct folders.
                                          • 3 / 4
