    Need help constructing a sofa with subd
    26 Posts 7 Posters 3.9k Views 7 Watching
    • Rich O BrienR Online
      Stick to very primitive forms then refine...
      keep refining as you go...
      i would have shared the file but i got this from SU...
      • jo-keJ Offline
        jo-ke
        looks effektive and simple.
        I am going to try it again....
        not too bad I hope
        http://www.zz7.de
          Excellent!
            Easiest thing to learn is proxy modelling. You're a natural at it too.
            • jo-keJ Offline
              jo-ke
              Thank you for your help. I am really not into proxymodelling... but result is quite well.
              http://www.zz7.de
                I think that looks like a fine result, I have problems with proxies too so appreciate how difficult it can be to get your mind around the method.
                  What is the difference between a Proxy and a simple 3D object?
                  State before subdivision ?
                  • ginchiusG Offline
                    ginchius
                    Made short but not full sofa modeling process, here you can download pdf tut
                    https://www.dropbox.com/s/5qgopf6p030oe4t/Sofa%20tut.pdf?dl=0
                    You can find my models at http://sketchucation.com/shop/models
                    • jo-keJ Offline
                      jo-ke
                      Wow! Extra Wow! This is really useful.
                      I will try to reconstruct it and post my results....
                      http://www.zz7.de
                      • HornOxxH Offline
                        HornOxx
                        πŸ‘ ... this is an excelent tutorial example here - thanks to all!
                        never trust a skinny cook
                          Thanks for the tut.
                          • jo-keJ Offline
                            jo-ke
                            Here's my new attempt
                            http://www.zz7.de
                            • HornOxxH Offline
                              HornOxx
                              πŸ‘ πŸ˜„ ...as expected with you - a great result
                              Even the seams you've done - are these simple follow-me shapes?
                              • ginchiusG Offline
                                ginchius
                                I'm glad you like my tutorial
                                Very good result indeed
                                @hornoxx said:
                                ...are these simple follow-me shapes?
                                For seams I'm usig the "Pipe along path" plugin
                                • jo-keJ Offline
                                  jo-ke
                                  Yes, I've took also pipe along path.
                                  It was a mix between Artisan und SubD. My proxy wasn't able for SubD, but Artisan worked very well
                                  here's a view of my final proxy before subdivision:
                                  http://www.zz7.de
                                  • jo-keJ Offline
                                    jo-ke
                                    btw: Exactly this view will be reality in about two months. I will post a pic, when everything is finished.
                                    http://www.zz7.de
                                    • Bryan KB Offline
                                      Gorgeous as always!
                                      • jo-keJ Offline
                                        jo-ke
                                        Sofa is already here, chandelier still not:-(
                                        http://www.zz7.de
                                          Very nice.
                                          • Bryan KB Offline
                                            Looking good as always!
