    Need help constructing a sofa with subd
    26 Posts 7 Posters 3.8k Views 7 Watching
    • jo-keJ Offline
      jo-ke
      OK, I understand the first pic.
      but how to get to the thrid dimension?
      http://www.zz7.de
      • jo-keJ Offline
        jo-ke
        OK, so far, so nice. But now is my problem... how to go on?
        http://www.zz7.de
          Stick to very primitive forms then refine...
          keep refining as you go...
          i would have shared the file but i got this from SU...
          • jo-keJ Offline
            jo-ke
            looks effektive and simple.
            I am going to try it again....
            not too bad I hope
            http://www.zz7.de
              Excellent!
                Easiest thing to learn is proxy modelling. You're a natural at it too.
                • jo-keJ Offline
                  jo-ke
                  Thank you for your help. I am really not into proxymodelling... but result is quite well.
                  http://www.zz7.de
                    I think that looks like a fine result, I have problems with proxies too so appreciate how difficult it can be to get your mind around the method.
                      What is the difference between a Proxy and a simple 3D object?
                      State before subdivision ?
                      • ginchiusG Offline
                        ginchius
                        Made short but not full sofa modeling process, here you can download pdf tut
                        https://www.dropbox.com/s/5qgopf6p030oe4t/Sofa%20tut.pdf?dl=0
                        You can find my models at http://sketchucation.com/shop/models
                        • jo-keJ Offline
                          jo-ke
                          Wow! Extra Wow! This is really useful.
                          I will try to reconstruct it and post my results....
                          http://www.zz7.de
                          • HornOxxH Offline
                            HornOxx
                            πŸ‘ ... this is an excelent tutorial example here - thanks to all!
                            never trust a skinny cook
                              Thanks for the tut.
                              • jo-keJ Offline
                                jo-ke
                                Here's my new attempt
                                http://www.zz7.de
                                • HornOxxH Offline
                                  HornOxx
                                  πŸ‘ πŸ˜„ ...as expected with you - a great result
                                  Even the seams you've done - are these simple follow-me shapes?
                                  • ginchiusG Offline
                                    ginchius
                                    I'm glad you like my tutorial
                                    Very good result indeed
                                    @hornoxx said:
                                    ...are these simple follow-me shapes?
                                    For seams I'm usig the "Pipe along path" plugin
                                    • jo-keJ Offline
                                      jo-ke
                                      Yes, I've took also pipe along path.
                                      It was a mix between Artisan und SubD. My proxy wasn't able for SubD, but Artisan worked very well
                                      here's a view of my final proxy before subdivision:
                                      http://www.zz7.de
                                      • jo-keJ Offline
                                        jo-ke
                                        btw: Exactly this view will be reality in about two months. I will post a pic, when everything is finished.
                                        http://www.zz7.de
                                        • Bryan KB Offline
                                          Gorgeous as always!
                                          • jo-keJ Offline
                                            jo-ke
                                            Sofa is already here, chandelier still not:-(
                                            http://www.zz7.de
