    โ„น๏ธ Licensed Extensions | FredoBatch, ElevationProfile, FredoSketch, LayOps, MatSim and Pic2Shape will require license from Sept 1st More Info
    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 343 Posters 2.3m Views 340 Watching
    • F Offline
      FZSarasota
      Hi Fredo,
      EDIT: I moved this message over to this thread (sorry for the mis-post).
      http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=66489
      -Terry
        slb_jwm
        Just reinstalled FredoScale v2.8a in SU 2017. Working fine, but the Extension Manager says 'Outdated signature'. The LibGFredo6 extension is happily saying 'Signed'.
        Does this matter?
          It won't keep Fredoscale from working correctly.
          • fredo6F Offline
            NEW RELEASE: FredoScale v2.9a - 24 Dec 16
            FredoScale 2.9a is a maintenance release providing a workaround to potential bugsplats encountered specifically with SU2017.
            One small limitation in SU2017 is that you can only do one single Radial Bend at a time.
            • fredo6F Offline
              NEW RELEASE: FredoScale v2.9b - 02 Jan 17
              FredoScale 2.9b is a maintenance release providing another workaround to potential bugsplats encountered specifically with SU2017, for Radial Bend and Twist when dicer is on.
                I was with a guy who had SU 8 : Radial Bending don't display the orange horizontal lines and makes not the rounding volume : only an inclined volume! ๐Ÿ˜ฎ
                • fredo6F Offline
                  I think he needs to activate the dicer
                  • press F4
                  • or Contextual menu
                    What is a dicer ?
                      @pilou said:
                      What is a dicer ?
                      Sort of a mandoline. ๐Ÿ˜„
                        "a sort of mandoline"
                        the little cuting rakes ?
                        https://files.meilleurduchef.com/mdc/photo/produit/bck/mandoline-du-chef/mandoline-du-chef-1-640.jpg
                        More abstract for that! ๐Ÿ˜„
                        http://www.woodbrass.com/images/woodbrass/SANTOS+Y+MAYOR+MANDOLINE.JPG
                          The first one is what I was referring to although if you could push it through the strings of the second one, you'd get a similar result. ๐Ÿ˜„
                            Sure but more difficult to extract slices of cucumber falling inside! ๐Ÿ’š
                              Good point. ๐Ÿ˜„
                                penumbra
                                Fredo,
                                latest release seems to have an issue that at the end of stretching operation and click outside of group, instead of accepting the scale change it springs back to original shape, when I repeat the operation a second time, then the change is accepted. is happening consistently on every drawing.
                                I am on SU 2015, windows 7.
                                Any thoughts?
                                Thanks.
                                  I just tried and I'm not seeing it. Could you upload an SKP file in which this happens?
                                    penumbra
                                    File attached. If you don't see the behavior when trying to stretch any of the building elements you see here then I must have interference from another plugin.
                                    Stretching.skp
                                      Which direction are you trying to stretch them in?
                                        Actually, I do see it in your model when I try stretching the large building.
                                          penumbra
                                          I use the scale to target tool and also I invoke the input dialog box via the TAB key. Either way the issue exists in any stretching direction.
                                            penumbra
                                            Thanks for looking at it. And now for the great search of the other offending plugin... How I wish there was a quicker way to detect and find plugin clashes.
                                            Edit: On second thought. If Dave is seeing it also then there is a little issue with the plugin? Unless Dave and I have a similar plugin clashing with it?
                                            • 40
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 56
                                            • 57
                                            • 42 / 57
