    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
    • fredo6F
      NEW RELEASE: FredoScale v2.9b - 02 Jan 17
      FredoScale 2.9b is a maintenance release providing another workaround to potential bugsplats encountered specifically with SU2017, for Radial Bend and Twist when dicer is on.
      One small limitation in SU2017 is that you can only do one single Radial Bend at a time.
        I was with a guy who had SU 8 : Radial Bending don't display the orange horizontal lines and makes not the rounding volume : only an inclined volume! ๐Ÿ˜ฎ
        • fredo6F
          I think he needs to activate the dicer
          • press F4
          • or Contextual menu
            What is a dicer ?
              @pilou said:
              What is a dicer ?
              Sort of a mandoline. ๐Ÿ˜„
                "a sort of mandoline"
                the little cuting rakes ?
                https://files.meilleurduchef.com/mdc/photo/produit/bck/mandoline-du-chef/mandoline-du-chef-1-640.jpg
                More abstract for that! ๐Ÿ˜„
                http://www.woodbrass.com/images/woodbrass/SANTOS+Y+MAYOR+MANDOLINE.JPG
                  The first one is what I was referring to although if you could push it through the strings of the second one, you'd get a similar result. ๐Ÿ˜„
                    Sure but more difficult to extract slices of cucumber falling inside! ๐Ÿ’š
                      Good point. ๐Ÿ˜„
                      • P
                        penumbra
                        Fredo,
                        latest release seems to have an issue that at the end of stretching operation and click outside of group, instead of accepting the scale change it springs back to original shape, when I repeat the operation a second time, then the change is accepted. is happening consistently on every drawing.
                        I am on SU 2015, windows 7.
                        Any thoughts?
                        Thanks.
                          I just tried and I'm not seeing it. Could you upload an SKP file in which this happens?
                          • P
                            penumbra
                            File attached. If you don't see the behavior when trying to stretch any of the building elements you see here then I must have interference from another plugin.
                            Stretching.skp
                              Which direction are you trying to stretch them in?
                                Actually, I do see it in your model when I try stretching the large building.
                                • P
                                  penumbra
                                  I use the scale to target tool and also I invoke the input dialog box via the TAB key. Either way the issue exists in any stretching direction.
                                  • P
                                    penumbra
                                    Thanks for looking at it. And now for the great search of the other offending plugin... How I wish there was a quicker way to detect and find plugin clashes.
                                    Edit: On second thought. If Dave is seeing it also then there is a little issue with the plugin? Unless Dave and I have a similar plugin clashing with it?
                                      I think we need Fredo's input.
                                      • fredo6F
                                        Thanks for signaling. This is a side effect of the fix for bugsplat in SU2017.
                                        I fixed it and will re-publish.
                                        By the way, the fact that it work the second time is due to the fact that the first time, FredoScale chains two operations
                                        • Make Unique
                                        • Stretching
                                        The bug was due to an unvolontary Undo, but the make Unique remained, so that it works fine the second time.
                                        • P
                                          penumbra
                                          Thanks fredo.
                                          • fredo6F
                                            NEW RELEASE: FredoScale v3.0a - 14 Jan 17
                                            FredoScale 3.0a is a maintenance release providing corrections to previous versions, and should be installed for all SU Versions.
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 58
                                            • 59
                                            • 46 / 59
