    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.6m Views 343 Watching
    • N Offline
      nbromz
      Just done an installation repair on sketchup and now the plugin is working great - thank god-as its one of my favourites!
      Regards,
      Nigel
      • N Offline
        nbromz
        Sorry i thought i solved the problem with the installation but it crashes when an object is grouped- works fine when exploded - but get bug splat when bending a group object.
        Iam using Sketchup 2017- windows 7 professional
        • fredo6F Offline
          @nbromz said:
          Could you post or PM the model, with indications of which part you try to bend.
          In general complications come from multiple instances of components.
            pjalbert
            hi guys
            Actually I am having the same problem in Sketchup 2017 Pro. I wanted to bend a cube, and as soon I exit the tool it bugsplatted on me. It also crashes using "twisting with orientation of scaling box". It only happens when the object is a group or component.
              joxter87
              Hi Fredo!
              I have a colleague with the same issue as FZSarasota and pjalbert, after using
              radial bend and deselect the object SUP17 crash, it occurs only when used on a
              component or a group.
              You are however able to save the bend first and then deselect the object to preserve it
              when you reopen the document.
              As we use this tool everyday in our work its very frustrating. I have the same
              setup except i use Windows 10 and he uses Windows 7, for me it works perfect.
              We have tried to re-install the plugins whithout any result.
              Otherwise, Thank you for a great plugin!
              • fredo6F Offline
                For info, the crash of RadialBend (and Twist), when you have the Dicing on, is identified.
                There is another thread to follow up on the issue.
                I don't have a 'clean' fix for the time being.
                • F Offline
                  FZSarasota
                  Thanks for the heads up, I'll go to that thread... Don't worry Fredo, all the other tools in the plugin work Great! I'll grab the fix whenever you release it (take your time, wink) ๐Ÿ˜Ž
                  -Terry
                  PS: I moved the last two posts over to the thread you listed.....
                  • F Offline
                    FZSarasota
                    Hi Fredo,
                    EDIT: I moved this post over to the thread you linked in last reply.
                    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=66489
                    -Terry
                    • F Offline
                      FZSarasota
                      Hi Fredo,
                      EDIT: I moved this message over to this thread (sorry for the mis-post).
                      -Terry
                        slb_jwm
                        Just reinstalled FredoScale v2.8a in SU 2017. Working fine, but the Extension Manager says 'Outdated signature'. The LibGFredo6 extension is happily saying 'Signed'.
                        Does this matter?
                          It won't keep Fredoscale from working correctly.
                          • fredo6F Offline
                            NEW RELEASE: FredoScale v2.9a - 24 Dec 16
                            FredoScale 2.9a is a maintenance release providing a workaround to potential bugsplats encountered specifically with SU2017.
                            One small limitation in SU2017 is that you can only do one single Radial Bend at a time.
                            • fredo6F Offline
                              NEW RELEASE: FredoScale v2.9b - 02 Jan 17
                              FredoScale 2.9b is a maintenance release providing another workaround to potential bugsplats encountered specifically with SU2017, for Radial Bend and Twist when dicer is on.
                                I was with a guy who had SU 8 : Radial Bending don't display the orange horizontal lines and makes not the rounding volume : only an inclined volume! ๐Ÿ˜ฎ
                                • fredo6F Offline
                                  I think he needs to activate the dicer
                                  • press F4
                                  • or Contextual menu
                                    What is a dicer ?
                                      @pilou said:
                                      What is a dicer ?
                                      Sort of a mandoline. ๐Ÿ˜„
                                        "a sort of mandoline"
                                        the little cuting rakes ?
                                        https://files.meilleurduchef.com/mdc/photo/produit/bck/mandoline-du-chef/mandoline-du-chef-1-640.jpg
                                        More abstract for that! ๐Ÿ˜„
                                        http://www.woodbrass.com/images/woodbrass/SANTOS+Y+MAYOR+MANDOLINE.JPG
                                          The first one is what I was referring to although if you could push it through the strings of the second one, you'd get a similar result. ๐Ÿ˜„
                                            Sure but more difficult to extract slices of cucumber falling inside! ๐Ÿ’š
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 57
                                            • 58
                                            • 45 / 58
