    [Plugin][$] FredoScale - v3.7c - 19 Aug 26
    1.2k Posts 347 Posters 3.5m Views 345 Watching
    • P
      pjalbert
      hi guys
      Actually I am having the same problem in Sketchup 2017 Pro. I wanted to bend a cube, and as soon I exit the tool it bugsplatted on me. It also crashes using "twisting with orientation of scaling box". It only happens when the object is a group or component.
        joxter87
        Hi Fredo!
        I have a colleague with the same issue as FZSarasota and pjalbert, after using
        radial bend and deselect the object SUP17 crash, it occurs only when used on a
        component or a group.
        You are however able to save the bend first and then deselect the object to preserve it
        when you reopen the document.
        As we use this tool everyday in our work its very frustrating. I have the same
        setup except i use Windows 10 and he uses Windows 7, for me it works perfect.
        We have tried to re-install the plugins whithout any result.
        Otherwise, Thank you for a great plugin!
        • fredo6F
          For info, the crash of RadialBend (and Twist), when you have the Dicing on, is identified.
          There is another thread to follow up on the issue.
          I don't have a 'clean' fix for the time being.
          • F
            FZSarasota
            Thanks for the heads up, I'll go to that thread... Don't worry Fredo, all the other tools in the plugin work Great! I'll grab the fix whenever you release it (take your time, wink) ๐Ÿ˜Ž
            -Terry
            PS: I moved the last two posts over to the thread you listed.....
            • F
              FZSarasota
              Hi Fredo,
              EDIT: I moved this post over to the thread you linked in last reply.
              404 Not Found
              (sketchucation.com)
              -Terry
              • F
                FZSarasota
                Hi Fredo,
                EDIT: I moved this message over to this thread (sorry for the mis-post).
                404 Not Found
                (sketchucation.com)
                -Terry
                  slb_jwm
                  Just reinstalled FredoScale v2.8a in SU 2017. Working fine, but the Extension Manager says 'Outdated signature'. The LibGFredo6 extension is happily saying 'Signed'.
                  Does this matter?
                    It won't keep Fredoscale from working correctly.
                    • fredo6F
                      NEW RELEASE: FredoScale v2.9a - 24 Dec 16
                      FredoScale 2.9a is a maintenance release providing a workaround to potential bugsplats encountered specifically with SU2017.
                      One small limitation in SU2017 is that you can only do one single Radial Bend at a time.
                      • fredo6F
                        NEW RELEASE: FredoScale v2.9b - 02 Jan 17
                        FredoScale 2.9b is a maintenance release providing another workaround to potential bugsplats encountered specifically with SU2017, for Radial Bend and Twist when dicer is on.
                          I was with a guy who had SU 8 : Radial Bending don't display the orange horizontal lines and makes not the rounding volume : only an inclined volume! ๐Ÿ˜ฎ
                          • fredo6F
                            I think he needs to activate the dicer
                            • press F4
                            • or Contextual menu
                              What is a dicer ?
                                @pilou said:
                                What is a dicer ?
                                Sort of a mandoline. ๐Ÿ˜„
                                  "a sort of mandoline"
                                  the little cuting rakes ?
                                  https://files.meilleurduchef.com/mdc/photo/produit/bck/mandoline-du-chef/mandoline-du-chef-1-640.jpg
                                  More abstract for that! ๐Ÿ˜„
                                  http://www.woodbrass.com/images/woodbrass/SANTOS+Y+MAYOR+MANDOLINE.JPG
                                    The first one is what I was referring to although if you could push it through the strings of the second one, you'd get a similar result. ๐Ÿ˜„
                                      Sure but more difficult to extract slices of cucumber falling inside! ๐Ÿ’š
                                        Good point. ๐Ÿ˜„
                                        • P
                                          penumbra
                                          Fredo,
                                          latest release seems to have an issue that at the end of stretching operation and click outside of group, instead of accepting the scale change it springs back to original shape, when I repeat the operation a second time, then the change is accepted. is happening consistently on every drawing.
                                          I am on SU 2015, windows 7.
                                          Any thoughts?
                                          Thanks.
                                            I just tried and I'm not seeing it. Could you upload an SKP file in which this happens?
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 58
                                            • 59
                                            • 45 / 59
