    [Plugin][$] FredoScale - v3.6a - 01 Apr 24
    1.1k Posts 345 Posters 2.4m Views 342 Watching
    • fredo6F Offline
      For info, the crash of RadialBend (and Twist), when you have the Dicing on, is identified.
      There is another thread to follow up on the issue.
      I don't have a 'clean' fix for the time being.
      • F Offline
        FZSarasota
        Thanks for the heads up, I'll go to that thread... Don't worry Fredo, all the other tools in the plugin work Great! I'll grab the fix whenever you release it (take your time, wink) ๐Ÿ˜Ž
        -Terry
        PS: I moved the last two posts over to the thread you listed.....
        • F Offline
          FZSarasota
          Hi Fredo,
          EDIT: I moved this post over to the thread you linked in last reply.
          http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=66489
          -Terry
          • F Offline
            FZSarasota
            Hi Fredo,
            EDIT: I moved this message over to this thread (sorry for the mis-post).
            -Terry
              slb_jwm
              Just reinstalled FredoScale v2.8a in SU 2017. Working fine, but the Extension Manager says 'Outdated signature'. The LibGFredo6 extension is happily saying 'Signed'.
              Does this matter?
                It won't keep Fredoscale from working correctly.
                • fredo6F Offline
                  NEW RELEASE: FredoScale v2.9a - 24 Dec 16
                  FredoScale 2.9a is a maintenance release providing a workaround to potential bugsplats encountered specifically with SU2017.
                  One small limitation in SU2017 is that you can only do one single Radial Bend at a time.
                  • fredo6F Offline
                    NEW RELEASE: FredoScale v2.9b - 02 Jan 17
                    FredoScale 2.9b is a maintenance release providing another workaround to potential bugsplats encountered specifically with SU2017, for Radial Bend and Twist when dicer is on.
                      I was with a guy who had SU 8 : Radial Bending don't display the orange horizontal lines and makes not the rounding volume : only an inclined volume! ๐Ÿ˜ฎ
                      • fredo6F Offline
                        I think he needs to activate the dicer
                        • press F4
                        • or Contextual menu
                          What is a dicer ?
                            @pilou said:
                            What is a dicer ?
                            Sort of a mandoline. ๐Ÿ˜„
                              "a sort of mandoline"
                              the little cuting rakes ?
                              https://files.meilleurduchef.com/mdc/photo/produit/bck/mandoline-du-chef/mandoline-du-chef-1-640.jpg
                              More abstract for that! ๐Ÿ˜„
                              http://www.woodbrass.com/images/woodbrass/SANTOS+Y+MAYOR+MANDOLINE.JPG
                                The first one is what I was referring to although if you could push it through the strings of the second one, you'd get a similar result. ๐Ÿ˜„
                                  Sure but more difficult to extract slices of cucumber falling inside! ๐Ÿ’š
                                    Good point. ๐Ÿ˜„
                                      penumbra
                                      Fredo,
                                      latest release seems to have an issue that at the end of stretching operation and click outside of group, instead of accepting the scale change it springs back to original shape, when I repeat the operation a second time, then the change is accepted. is happening consistently on every drawing.
                                      I am on SU 2015, windows 7.
                                      Any thoughts?
                                      Thanks.
                                        I just tried and I'm not seeing it. Could you upload an SKP file in which this happens?
                                          penumbra
                                          File attached. If you don't see the behavior when trying to stretch any of the building elements you see here then I must have interference from another plugin.
                                          Stretching.skp
                                            Which direction are you trying to stretch them in?
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 56
                                            • 57
                                            • 12 / 57
