    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
      chriscall
      Doesnt seem to be working on su7. Some of the tools stuck while loading; script errors on different lines. Where can I download version 6.9?
      • fredo6F Offline
        Could you be more explicit?
        Which tools?
        What is not working?
        Also when you have problems, could you open the Ruby console and see if there are errors.
          melmanosul
          Can anyone help me pls? I am getting this error at load after installing LibFredo -v7 for sketchup 2016.
          Error Loading File Fredo6_FredoScale.rb
          Error: #<ArgumentError: wrong number of arguments (2 for 1)>
          C:/Users/alexa/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:308:in top_load' C:/Users/alexa/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_FredoScale.rb:29:in module:Fredo6'
          C:/Users/alexa/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_FredoScale.rb:26:in `<top (required)>'
          Thank you !
          • fredo6F Offline
            NEW RELEASE: LibFredo6 v7.3a - 24 Dec 16
            LibFredo6 7.3a fixes a major bugs for FredoScale to run on SU2017. These bugs were creating bugsplats, in particular with Radial Bend.
            See main post of this thread for Download of LibFredo6.
            • bazB Offline
              baz
              Thanks Fredo.
                josekvf
                Thank you Fredo
                • bazB Offline
                  baz
                  Fredo, sorry to say I am still getting the splat even with the update.
                  • fredo6F Offline
                    Do you get it at the first radial bending?
                    • bazB Offline
                      baz
                      Yes I did!
                      • fredo6F Offline
                        NEW RELEASE: LibFredo6 v7.3b - 02 Jan 17
                        LibFredo6 7.3b is another attempt to fix a major bugs for FredoScale when run on SU2017. These bugs were creating bugsplats, in particular with Radial Bend and Twsit, when dicer is on.
                        • fredo6F Offline
                          Please try with FredoScale 1.3b. I made a workaround (waiting on a fix in SU2017, if ever it comes).
                          • fredo6F Offline
                            NEW RELEASE: LibFredo6 v7.4a - 14 Jan 17
                            LibFredo6 7.4a fixes bugs in FredoScale and SUCLock
                            • bazB Offline
                              baz
                              Thanks again Fredo. All working. Cheers.
                              • fredo6F Offline
                                NEW RELEASE: LibFredo6 v7.4c - 16 Jan 17
                                LibFredo6 7.4c is another set of corrections required for SUCLock and general
                                  sherlocksam17
                                  thx for ur post! love it
                                  • fredo6F Offline
                                    NEW RELEASE: LibFredo6 v7.5a - 12 Feb 17
                                    LibFredo6 7.5a is a maintenance release mainly dedicated to Animator 1.5a
                                      bharralure
                                      Bonjour Fredo
                                      Je rencontre un petit soucis avec la dernière version de LibFredo06, le lanceur Curvizard ne fonctionne plus, mais tous les outils Curvizard fonctionnent aussi bien depuis > Outils > Fredo 6 Collection > Curvizar, que depuis > clic droit > menu contextuel.
                                      J'ai désinstallé la dernière version de Curvizard et Animator, et réinstallé la version LibFredo6 v7.4c, et constaté que le lanceur Curvizard fonctionne à nouveau.
                                      J'ai réinstallé la version Animator v1.4c (je n'ai pas essayé de réinstaller la dernière version), tout fonctionne, y compris Curvizard.
                                      Je ne doute pas que vous allez remédier au problème, donc j'attends avant de réinstaller les dernières versions...
                                      • fredo6F Offline
                                        @bharralure said:
                                        Bonjour Fredo
                                        Thanks for signaling. Could you open the Ruby console and then call the Curvizard Quick Launcher.
                                          bharralure
                                          Je ne connais strictement rien à la programmation, et c'est bien la première fois que j'utilise la console...
                                          J'ouvre donc la console et je fais un copier coller de votre texte "Curvizard Quick Launcher", le message qui s'affiche est sur la capture d'écran qui suit.
                                          Je vous rappèle que j'ai désinstallé la dernière version.
                                          Que puis-je faire d'autre pour vous être utile?
                                          • fredo6F Offline
                                            [attachment=0:1bikmim1]<!-- ia0 -->2017-02-13 14_15_56-Console Ruby.png<!-- ia0 -->[/attachment:1bikmim1]
                                            Non. Je veux dire, ouvrez la console Ruby. Ne rien taper. Mais appeler le lanceur Curvizard.
                                            Il y aura peut-etre un meessage d'erreur qui s'affichera dans la console Ruby.
                                            • 60
                                            • 61
                                            • 62
                                            • 63
                                            • 64
                                            • 108
                                            • 109
                                            • 62 / 109
