    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 587 Posters 10.9m Views 589 Watching
      Also remember that SketchUp must be installed properly.
      That means selecting the installer's exe icon,
      then using the right-click > context-menu > Run as administrator...
      Running the installer by double-clicking the installer's exe will install it,
      BUT that can often result in unexpected weirdness... that might be the case here.
      It is NOT sufficient that you have admin-powers as a user, it must be 'Run as administrator'.
      It's not so painful to correct this...
      You do NOT need to uninstall SketchUp.
      First close SketchUp,
      then you find the installer exe [either the existing in Downloads or perhaps a re-download]
      and then run its exe as explained above...
      When prompted choose to 'Repair'.
      Let it run...
      This should correct any issues, since it will now be properly installed.
      Restart SketchUp to see if that approach has helped...
      • T
        topbobster
        Let it run...
        TIG, Fredo many thanks for your help. Before I read TIG's last response my intention was to uninstall Sketchup and re-install on my admin account. I un-installed, then saw TIG's message before re-installing so was able to follow his instructions exactly for the install. Then installed Libfredo tested, ok, then installed round corners and tested and it all worked on my admin account. I then logged into my user account and still got the errors.....I believe I read somewhere regarding permissions on user accounts but I installed files before so not sure if it is that, I will try to fiddle around with it on the user account. Anyway I can and am using it successfully on my admin account so am happy to do that.
        Many thanks to everyone for your time and inclination to help. I look forward to using Fredo's good work and when I have seen the various tools working will surely make a well earned donation.
        Hope I didn't waste anyone's time. Regards, Rob
        • fredo6F
          Rob,
          Glad you finally see the light.
          I think it's useful to understand the root cause (permissions on user account) so that we can understand for other users.
          • T
            topbobster
            @fredo6 said:
            Rob,
            Hello Fredo, Not sure if this throws any light on the subject but here goes....A while back I had trouble with an online storage account and they suggested it could be a corrupt profile. At the time I started to set up a new profile but had trouble copying over files so stopped there and did not use the account, but it was still there. I thought about trying Sketchup on that new profile (no admin rights), to see what happened......I have loaded all plugins succesfully, no issues whatsoever. I have made no changes to permissions on this account although they do seem to be in order:
            • fredo6F
              NEW RELEASE: LibFredo6 v7.2e - 15 Nov 16
              LibFredo6 7.2e fixes somemajor issues having a side effect on [b]Curvizard and Curviloft.
              See main post of this thread for Download of LibFredo6.
                And for 2016 & 2017...
                Recommanded also ?
                • fredo6F
                  Recommanded also ?
                  Yes. LibFredo6 is signed for SU2017 (and SU2016).
                  My other plugins are not signed yet for SU2017. I will release a signed version progressively. I guess not too many people works in SU2017 with Strict Security!
                  • fredo6F
                    NEW RELEASE: LibFredo6 v7.2g - 20 Nov 16
                    LibFredo6 7.2g fixes two **major bug in Animator for:
                    [list]
                    []Orbiting (i.e. rotation around another object)
                    ]Screw, where the movement was simply wrongly calculated
                    See main post of this thread for [b]Download of LibFredo6**.
                    • fredo6F
                      NEW RELEASE: LibFredo6 v7.2h - 24 Nov 16
                      LibFredo6 7.2h fixes **major bugs in Animator
                      • C
                        chriscall
                        Doesnt seem to be working on su7. Some of the tools stuck while loading; script errors on different lines. Where can I download version 6.9?
                        • fredo6F
                          Could you be more explicit?
                          Which tools?
                          What is not working?
                          Also when you have problems, could you open the Ruby console and see if there are errors.
                            melmanosul
                            Can anyone help me pls? I am getting this error at load after installing LibFredo -v7 for sketchup 2016.
                            Error Loading File Fredo6_FredoScale.rb
                            Error: #<ArgumentError: wrong number of arguments (2 for 1)>
                            C:/Users/alexa/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:308:in top_load' C:/Users/alexa/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_FredoScale.rb:29:in module:Fredo6'
                            C:/Users/alexa/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_FredoScale.rb:26:in `<top (required)>'
                            Thank you !
                            • fredo6F
                              NEW RELEASE: LibFredo6 v7.3a - 24 Dec 16
                              LibFredo6 7.3a fixes a major bugs for FredoScale to run on SU2017. These bugs were creating bugsplats, in particular with Radial Bend.
                              • bazB
                                baz
                                Thanks Fredo.
                                  josekvf
                                  Thank you Fredo
                                  • bazB
                                    baz
                                    Fredo, sorry to say I am still getting the splat even with the update.
                                    • fredo6F
                                      Do you get it at the first radial bending?
                                      • bazB
                                        baz
                                        Yes I did!
                                        • fredo6F
                                          NEW RELEASE: LibFredo6 v7.3b - 02 Jan 17
                                          LibFredo6 7.3b is another attempt to fix a major bugs for FredoScale when run on SU2017. These bugs were creating bugsplats, in particular with Radial Bend and Twsit, when dicer is on.
                                          • fredo6F
                                            Please try with FredoScale 1.3b. I made a workaround (waiting on a fix in SU2017, if ever it comes).
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 113
                                            • 114
                                            • 57 / 114
