    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 957.7k Views 172 Watching
      Anton_S
      Robin,
      I assume the script you talk about is the controllable sphere thingy. There has been some scripting changes and the documentation for the controllable sphere is updated. For your case, you will have to replace the add_force2 function with the add_force function.
      Now, I don't know how the static floor behaved previously. Basing on the model you posted, everything is working fine. I don't see any issues.
      If you want to revert to on original version, you may always refer to the instructions on the homepage.
      Anton
      • robintR Offline
        robint
        Very strange Anton, I removed the sphere from the model to avaoid confusion , but on mine Falling block 7 the whole model falls. I must assume I got a corrupt installation, so will start again afresh back to 0.9.8 and fb 6
        Cheers
        Robin
        As one door closes another one slams in your face
        • robintR Offline
          robint
          I am pleased to report, that after a tedious uninstall of msp and a clean instal of 0.9.9, everything now seems to work ok
          Overwriting existing files looks unwise and it was severely screwed up
          I would advise users
          Cheers
          Robin
          PS I made the block and floor out of tungsten carbide, so the block didnt penetrate AKAIK, but bounces as expected
          falling block8.skp
          • F Offline
            faust07
            Thanks Anton for making MSPhysics better and better. First impression of running an old model with Curvy Pistons with version 0.9.9 - all moves but some objects move backwards... - I will test in the next days what I must change to get the desired results.
            Merry Christmas to all friends of SketchUp, physics and animation.
            • robintR Offline
              robint
              Hi MSP's
              Herewith my mortar gun model, run and tap space bar, adjust azimuth with rotate tool on all the gun. Adjust charge by piston rate
              I thought I might add display of distance to first landing (just like a real gun spotter?
              mortar.skp
                SketchyPhysicsNutt
                Hi robint your original model falling block8 and script anton
                helped u with i found very interesting thx.
                I set block material to gold / elasticity to 2.00 and got a
                bouncing ball i like the affect max elasticity gives u.
                Gif starts on 2nd bounce then breaks free on 3rd and keeps bouncing
                http://s24.postimg.org/41779b5dx/bounce.gif
                Tez
                • robintR Offline
                  robint
                  Indeed, it becomes quite addictive I found. I wish I knew more about ruby script
                  I want to xfer the script to my mortar gun, try to get muzzle velocity, distance to target and time of flight
                  cheers, have fun
                  Robin
                    SketchyPhysicsNutt
                    Im no script monkey as well wish i was....but im experimenting connecting two servo's for swivel and tilt with your mortar gun model no luck yet πŸ˜„
                    Antons original script has come in handy with my trebuchet/catapult models and projectiles
                    THX Robin happy new year
                    Tez
                    • robintR Offline
                      robint
                      Yes I tried that, but the outer gun barrel has to be made up of 4 flat slabs grouped together and made static which is why it wont move, else the ball just falls through it
                      only way I found was to use the rotate tool before hitting go
                      not very elegant
                      perhaps someone else will pitch in
                      Cheers
                      Robin
                      • robintR Offline
                        robint
                        Anyone know how to put sound into script eg a sound wav called "cannon" to be played when I press space bar (which also fires the cannon ball
                        I put the sound byte into the UI sound tab, but nothing happens? WOTODO?
                        Robin
                          PituPhysics
                          Robin
                          Hello Robin. I wrote a script to display the distance of bullet and target, the time of flight and play the sound. But the "Update Timestep" change it to Normal 1/60 on the Simulation tab.
                          Try this:
                          mortar 2.skp
                            SketchyPhysicsNutt
                            Great script inside PituPhysics 'Distance and time of flight' perfect for projectiles
                            thx
                            Tez
                            • robintR Offline
                              robint
                              Hi PP
                              some good stuff there, doesnt make the sound?
                              take a look at my falling block as it uses the ontouch procedure to capture the distance at the moment of first impact
                              Another way might be to insert some magnetism into the ball, floor and target so that the missile sticks to its first landing place, as with a real mortar
                              Have tried to use magnetism in UI but doesnt seem to have any effect? 😲
                              What am I doing wrong?
                              Robin
                              mortar 3.skp
                                PituPhysics
                                I made more models to be more opportunities.
                                1.) Frozen: mortar 4.1.skp
                                2.) Hide: mortar 4.2.skp
                                3.) Simulation pause: mortar 4.3.skp
                                And magnet test:magnet.skp
                                • robintR Offline
                                  robint
                                  Hi PP
                                  tried your magnet and I am baffled as to why its so very slow, <2fps. tried everything to speed it up. Sketchy physic was much faster? I made ther executive balls desktop toy by putting all the balls as pendulums in a frame and colliding. It was fast and realistic?
                                  Robin
                                  • robintR Offline
                                    robint
                                    Even stranger, I managed to get my balls to clang together at 30 fps, but unable to simulate repulsion even with negative magnet values? I notice that perhaps magnet is a wrong term as it behave more like gravity between two masses (hence no repulsion effect)
                                    Universal gravitation equation
                                    F = GMm/R2
                                    where
                                    F is the force of attraction between two objects in newtons (N)
                                    G is the Universal Gravitational Constant = 6.674*10βˆ’11 N-m2/kg2
                                    M and m are the masses of the two objects in kilograms (kg)
                                    R is the separation in meters (m) between the objects, as measured from their centers of mass
                                    notice how the ball is attracted to the target even though the target has no magnetic force
                                    for example
                                    Robin
                                    my magnetic balls 1.skp
                                    • robintR Offline
                                      robint
                                      Hi PP
                                      Got as far as 4.3 and it certainly is the cats whiskers, like the disappering effect in 4.2, all we need is a little pop up explosion (still no sound on mine?)
                                      I dont understand what is affecting the fps so drastically? It goes from 30fps down to 4 or less
                                      Robin
                                      • robintR Offline
                                        robint
                                        Playing with real shells. Wonder how I can get the nose pointing along the path? hmmm ❓ notice the fps is 27, yet on some of the models its very slow 2fps
                                        mortar 5.1.skp
                                          PituPhysics
                                          For me 63 fps.
                                          mortar 5.2.skp
                                          • robintR Offline
                                            robint
                                            Wow PP that has blown me away, havent looked into detail yet, tomorrow am
                                            Now could this be mounted on a tank? Forward, left, right track
                                            Then we could have two or more, multi players
                                            Tank battle, forests, obstacles, terrain, mines, smoke etc
                                            Pls assume all rights, I'll be your beta tester and write the manual
                                            Robin
                                            Ps I wrote a game like this in BASIC years ago, for four players, it was extemely addictive, hidng under tree cover trying to guess where you opponents were. Each tank had a home base corner and had to return for new ammo and fuel. we spent hours on it
                                            I turned this into a kids game sliding around on mats on a polished wood floor blindfold, getting coded instruction from their base commanders. They fired foam tennis balls at each other and only had three reserve tanks. Couldn't get them out of the classroom, oh and they had to give their instructions in a foreign language, French German, Italian and swedish - a summer uni job - but the kids loved it
                                            Robin
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 47
                                            • 44 / 47
