    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 927.6k Views 172 Watching
      Anton_S
      Hi, gilles,
      To fix that, you have to select the joint, open MSPhysics UI, and check the "connected collide" option.
      Regards,
      Anton
      • robintR Offline
        robint
        @anton_s said:
        Hi, Robin,
        I'm glad I could help.
        Best regards,
        Anton
        I made a simple mass/spring damper system as per model, but I get some odd results not like the damped sinusoid
        Am I on the right track or have I made some basic errors
        Also the block doesn't sit still on the plane but wanders off
        I am also having difficulty tying in the UI with real values of spring rate N/m and damping c*velocity Ns/m
        Any advice, most appreciated
        Cheers
        Robin
        BTW I looked at the Ruby docs but couldnt tie up real units to the constants
        classic spring damper
        As one door closes another one slams in your face
        • gillesG Offline
          gilles
          @anton_s said:
          Hi, gilles,
          Regards,
          Anton
          Works fine ๐Ÿ‘
          A lot to dig in, I go back to the mine.
            Anton_S
            Hi, Robin,
            The block doesn't sit still probably because you disabled the friction. Enabling the friction checkbox option for the block and for the floor contacting the block will fix the wandering off behavior.
            I will add an option to control accel and damp with the SI units in the upcoming release. At the moment, I figured that spring constant is roughly equals to (accel * 7 - damp), when spring joint stiffness is set to 1.0.
            Edit: Ensure that both anuglar and linear damping for all bodies are set to zero. This improves the closeness.
            Anton
            • robintR Offline
              robint
              Hi Anton
              I'm sure I tried every way with the friction coeffs, and it didnt seem to help much, unless Im doing something wrong. If you could get real SI units into the spring damper model this would be fantastic. Classic maths leaves everything in normalised units which is really hard for students to translate into the real world - thats what MS physics is about. I try to encourage my student to abandon th suck-it-and-see approach in favour of understanding what is really happening and calculating the effect. I know that math is a real turn off for most users, but I try
              cheers Robin
              • robintR Offline
                robint
                @anton_s said:
                Hi, Robin,
                Anton
                Yes indeed, improved action, I missed the friction box
                Herewith a revised model changing block mass from 0 - 0.5 kg gives a displacement of 0 - 1.0 so the spring rate is 2
                spring stiff 1 (what does this do?)
                Accel 1, damp 1.5 (gives critical damping approx)
                changing sample rate from 1/60 to 1/240 changes the whole model performance
                iterations 16 - improves stability
                the plane has a mass of 0.01kg, lowest i could get without instability
                So Ive actually got a spring damper that sort of behaves but it seems like the spring has inertial mass - an ideal spring should be zero mass and friction
                What do you think? Anything I can do to help (ruby dummy just now)
                Cheers
                Robin) ๐Ÿ˜›
                V 2
                  Anton_S
                  Hi, Robin,
                  I just revised the spring joint to base on Hooke's law. Just need to adress a few other things before its ready for the release.
                  Regards,
                  Anton
                  • robintR Offline
                    robint
                    @anton_s said:
                    Hi, Robin,
                    Regards,
                    Anton
                    Hi Anton
                    It occured to me loking at the motor joint, that it would be neat to have control sliders on important coeffs, of spring rate, friction, and damping, help to speed up student experience
                    BTW just seen some example in Sketchucation, blown away with the talent out there
                    Hope my little exercises aren' t too dull
                    Cheers
                    Robin
                    • gillesG Offline
                      gilles
                      What am I doing wrong?
                      THEO-JANSEN2.skp
                        Anton_S
                        Hi, gilles,
                        You just need to adjust motor joint properties. So, select the motor joint, open MSPhysics UI, and set Accel to 20, Damp to 10, and uncheck the Free Rotate checkbox option. This should make the motor more stronger.
                        Anton
                        • gillesG Offline
                          gilles
                          Thanks Anton,
                          Very nice tool you made there.
                          THEO.skp
                            Anton_S
                            Very clever, gilles!
                            I'm sure there is a way to improve performance and stiffness of that thing.
                            Anton
                            • gillesG Offline
                              gilles
                              Thรฉo Jansen.
                              http://www.strandbeest.com/index.php ๐Ÿ‘
                                The peaceful robots! ๐Ÿ˜Ž
                                • gillesG Offline
                                  gilles
                                  I had issues with MS UI: modifying values, sometimes works sometimes not. ๐Ÿ˜ก
                                  Then I notice this: typing a value +enter or tab does not work. ๐Ÿ˜ฎ
                                  Typing a value + click outside the input box worksโ€ฆ ๐Ÿ˜ฎ
                                  Just for anybody else having the same troubles.
                                  Mac OSX 10.8.5, SU2015.
                                    Anton_S
                                    Yeah, I'm working on that. Thanks for the report, gilles!
                                    • robintR Offline
                                      robint
                                      [attachment=0:3sqfwcxi]<!-- ia0 -->MS-UI.gif<!-- ia0 -->[/attachment:3sqfwcxi]
                                      Hi gilles
                                      I don't know if this is related but i noticed that when trying to alter friction, on cursor in window an X appears on the rhs and a new input will only be accepted after mouse over click X which blanks the window for a new entry
                                      kinda convoluted
                                      Robin
                                        Anton_S
                                        Announcing 0.9.9!
                                        This version comes with mainly an improved dialog and joints.
                                        View changelog for details: http://www.rubydoc.info/github/AntonSynytsia/MSPhysics/file/CHANGELOG.md
                                        Anton
                                          SketchyPhysicsNutt
                                          Thanks Anton for fixing the full-screen issue my animations are back to normal ๐Ÿ˜„
                                          MSPhysics 0.9.9
                                          tested on win 8.1 and sketchup 2015/2016 working fine.
                                          the new plane joint works great on single or two different planes ๐Ÿ‘
                                          thx again and merry xmas
                                          Tez
                                            Anton_S
                                            Hello, Tez,
                                            Good to hear that it's working now. And merry Christmas to you too!
                                            Best regards,
                                            Anton
                                            • 24
                                            • 25
                                            • 26
                                            • 27
                                            • 28
                                            • 46
                                            • 47
                                            • 26 / 47
