    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.3m Views 79 Watching
    • panixiaP
      panixia
      not 100% sure about the exagon being the best starting shape, depending on what i have to do, in most cases, i start from 4,8,12,16 segments.. anything you can split by 4.. there are some cases in wich i use 6, that's fine, but i would not say that's always"the golden rule".. it tends to generate asymmetrical topology distribution/flow/cap, sometimes it's what i need, sometime it's not..
      looking at your grid example, in that case exagon is the best way to go, bacause you need to tile your rows "alternate" but in the case of a "stack bond style" tiling, that same base topology could be quite problematic..
      so definetly, it depends on the shape/topology you are tryng to achieve.
        • JQLJ
          JQL
          Have you seen this Thomthom?
          http://www.blenderguru.com/tutorials/introduction-microdisplacements/
          www.casca.pt
          Visit us on facebook!
          • N
            nlipovac
            Hi Rich, when will be seeing SU_to_wRapr_to_Substance tutorials?
            Great modeling.
            • ontaottoO
              ontaotto
              @thomthom said:
              Lovely example!
              Btw, what software is that? Do you know if it uses OpenSubdiv?
              Thanks, it is Carrara the which is very compatible with SketchUp, and I don't know about Open SubD??
              Twitter: @ontaotto
              • ontaottoO
                ontaotto
                Yes sure, what I am saying is to build tubes, and as you have seen in the T Pipe tubes the best sample I have done was by using octagons, the main shape recommended to subdivide is the square, mainly known as Quad, it may vary according the model of course.
                Twitter: @ontaotto
                  It's the de-factor subdivision standard that's being adopted. Originally developed by pixar: http://graphics.pixar.com/opensubdiv/docs/intro.html
                  Next version of SUbD will use OpenSubdiv as the subdivision engine - so it'll subdivide consistently with other applications that implement OpenSubdiv.
                  • ontaottoO
                    ontaotto
                    Well honestly I have no idea if Carrara does have that, however I have done several tests in this program and the process to subdivide is quite similar to other 3D programs such Maya, Blender and others, I am very excited about the SU plugin you have developed, I did install it a few months ago, I was trying to upload more samples but my trial has been expired, (so sad) Will post some other samples soon.
                    Regards!
                    Otto
                    Twitter: @ontaotto
                    • BoxB
                      A little pub doodle. If i get a chance in the next few days I'll reconstruct it fully as a gif.
                      http://i.imgur.com/1303dBI.gif
                      • K
                        kenancakir
                        Hi Box, it says image not found, from Turkiye..
                        • BoxB
                          That is strange, it is my normal Imgur account which you have seen on FB.
                          The gif was too big to upload directly here.
                          I'll add a screenshot for you.
                          • BoxB
                            Here we go, sorry, I would normally post the non facebooked one here but I forgot to keep a clean copy.
                            http://i.imgur.com/gEkvuNf.gif
                            • bazB
                              baz
                              That's amazing. You go crazy!
                              • cottyC
                                cotty
                                +1
                                πŸ‘
                                my SketchUp gallery
                                • ontaottoO
                                  ontaotto
                                  That's pretty nice!
                                  Twitter: @ontaotto
                                  • HornOxxH
                                    HornOxx
                                    @box said:
                                    A little pub doodle
                                    πŸ‘ πŸ‘
                                    this is so great again - Where do you get these crazy ideas from ??
                                    BTW - thanks for your many BOX-gifs here which always are so interesting and so helpful !!!
                                    never trust a skinny cook
                                      Kito Raupp inspiration! πŸ˜‰
                                      • dereiD
                                        derei
                                        A friend of mine just finished a reprap 3d printer and I thought to "celebrate" his achievement, by modeling a boat for him to print...
                                        DESIGNER AND ARTIST DEREI.UK
                                        • N
                                          nlipovac
                                          [attachment=0:10i72gyl]<!-- ia0 -->Mowiti.jpg<!-- ia0 -->[/attachment:10i72gyl]
                                          It looks great!
                                          Hove did you do lettering?
                                          • aarondietzenA
                                            aarondietzen
                                            Been a while since I posted anything here!
                                            Quick model I did earlier this week:
                                            "Imagination is more important than knowledge..."
                                            - Albert Einstein
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 39
                                            • 83
                                            • 84
                                            • 37 / 84
