    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
      @gettes said:
      Where can I find this extension? Can I use it just with Sketchup 2016?
      Gert
      Have you actually read the first post in this thread ?
      Or perhaps more sensibly, have you looked in the SketchUcation PluginStore for its RBZ ?
      http://sketchucation.com/pluginstore?pln=BezierSpline
      I think it's one of the few Plugins from Fredo that does NOT actually need his 'Lib' installing [ although having that too does not harm ! ]...
      As far as I know it works in all available SketchUp versions...
      So why not try it... and let us know...
      • K
        kk20314
        感謝你的分享 ~~ 好用插件
        • CoreMaster110C
          CoreMaster110
          Love this tool but is there a way to make a shortcut key for "BZ - Convert to / Polyline" etc?
          • fredo6F
            I guess you refer to the menu entries in the contextual menu. I thought it was possible to assign shortcuts to them.
            If not, this is not a big job to make them as regular menu static entries.
            • CoreMaster110C
              CoreMaster110
              Yes, in the contextual menu.
              Shortcuts can only be assigned in the "Preferences/Shortcuts"? There are options to assign shortcuts to draw polylines etc but did not see any options for converting.
              It would be really nice if shortcuts could be added to the contextual menu options aswell.
              Regards
                Did you have a curve selected while searching for the item in the list? Since it is a Context menu item, you need to select an entity that would make it show up there.
                • CoreMaster110C
                  CoreMaster110
                  Oh, that's how it works. Did not know. Thank you!
                    That's how it works - for anything that would show in the Context menu.
                    You're welcome.
                      surfmike
                      A+B=C
                      Hi!
                      I love BezierSpline - thanks! - but is there any plugin that can make a "C" curve out of a vertical "A" and a horisontal "B"(see attached pic)?
                      Mikael
                      • fredo6F
                        @surfmike said:
                        [attachment=0:1gq3jfrj]<!-- ia0 -->line_combo_plugin.jpg<!-- ia0 -->[/attachment:1gq3jfrj]
                        Hi!
                        Mikael
                        You can try Curviloft Loft By Spline, just keeping the contours
                          surfmike
                          @fredo6 said:
                          @surfmike said:
                          [attachment=0:2uv23w8c]<!-- ia0 -->line_combo_plugin.jpg<!-- ia0 -->[/attachment:2uv23w8c]
                          Hi!
                          Mikael
                          Thanks for suggesting.
                          Tried it, but since I wanted to create the "C" curve, I tried w/o it, which didn't give the desired result.
                          What I want is to NOT have to create two groups/components, and run th command "Intersect faces" to create a 3rd "C" contour.
                          Is that possible?
                          //Mike
                          • T
                            trannam4
                            thanks
                              surfmike
                              Hi! Is there any chance to override the maximum segments (300s) for each bezier curve made?
                              //Mike
                              • fredo6F
                                //Mike
                                I am not sure that curves should have too many segments , as a general statement.
                                But, I will increase it to 600 in a next release.
                                In the meantime, you can edit the file bezierspline_main.rb, line #62 and set the value you wish.
                                  surfmike
                                  Great! I'm doing some experiments with SU and 3D printing, that's why.
                                  I agree that many segments slows down at least the next phase with Curviloft.
                                  Maybe have a warning at a specific amount of segments with "don't show this message again" option.
                                  //Mike
                                  • gillesG
                                    gilles
                                    //Mike
                                    Select the 300s curve, right-click/Explode, right-click/Convert to Catmull spline = 1800s.
                                      surfmike
                                      What will the difference be between the 2 options?
                                      • fredo6F
                                        That's not the same curve, but visually, with hundreds of points, they may look the same!
                                          Medvezhonok
                                          Please update BezierSpline signature for compatibility with SU 2017
                                          • fredo6F
                                            NEW RELEASE 1.9a - 12 Feb 17
                                            This release is certified for Sketchup 2017
                                            Download new release at main post
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 19 / 23
