    [Plugin] BezierSpline - v2.2a - 22 Apr 21
    460 Posts 183 Posters 2.1m Views 183 Watching
    • fredo6F
      @coremaster110 said:
      Love this tool but is there a way to make a shortcut key for "BZ - Convert to / Polyline" etc?
      I guess you refer to the menu entries in the contextual menu. I thought it was possible to assign shortcuts to them.
      If not, this is not a big job to make them as regular menu static entries.
      • CoreMaster110C
        CoreMaster110
        Yes, in the contextual menu.
        Shortcuts can only be assigned in the "Preferences/Shortcuts"? There are options to assign shortcuts to draw polylines etc but did not see any options for converting.
        It would be really nice if shortcuts could be added to the contextual menu options aswell.
        Regards
          Did you have a curve selected while searching for the item in the list? Since it is a Context menu item, you need to select an entity that would make it show up there.
          • CoreMaster110C
            CoreMaster110
            Oh, that's how it works. Did not know. Thank you!
              That's how it works - for anything that would show in the Context menu.
              You're welcome.
                surfmike
                A+B=C
                Hi!
                I love BezierSpline - thanks! - but is there any plugin that can make a "C" curve out of a vertical "A" and a horisontal "B"(see attached pic)?
                Mikael
                • fredo6F
                  @surfmike said:
                  [attachment=0:1gq3jfrj]<!-- ia0 -->line_combo_plugin.jpg<!-- ia0 -->[/attachment:1gq3jfrj]
                  Hi!
                  Mikael
                  You can try Curviloft Loft By Spline, just keeping the contours
                    surfmike
                    @fredo6 said:
                    @surfmike said:
                    [attachment=0:2uv23w8c]<!-- ia0 -->line_combo_plugin.jpg<!-- ia0 -->[/attachment:2uv23w8c]
                    Hi!
                    Mikael
                    Thanks for suggesting.
                    Tried it, but since I wanted to create the "C" curve, I tried w/o it, which didn't give the desired result.
                    What I want is to NOT have to create two groups/components, and run th command "Intersect faces" to create a 3rd "C" contour.
                    Is that possible?
                    //Mike
                    • T
                      trannam4
                      thanks
                        surfmike
                        Hi! Is there any chance to override the maximum segments (300s) for each bezier curve made?
                        //Mike
                        • fredo6F
                          //Mike
                          I am not sure that curves should have too many segments , as a general statement.
                          But, I will increase it to 600 in a next release.
                          In the meantime, you can edit the file bezierspline_main.rb, line #62 and set the value you wish.
                            surfmike
                            Great! I'm doing some experiments with SU and 3D printing, that's why.
                            I agree that many segments slows down at least the next phase with Curviloft.
                            Maybe have a warning at a specific amount of segments with "don't show this message again" option.
                            //Mike
                            • gillesG
                              gilles
                              //Mike
                              Select the 300s curve, right-click/Explode, right-click/Convert to Catmull spline = 1800s.
                                surfmike
                                What will the difference be between the 2 options?
                                • fredo6F
                                  That's not the same curve, but visually, with hundreds of points, they may look the same!
                                    Medvezhonok
                                    Please update BezierSpline signature for compatibility with SU 2017
                                    • fredo6F
                                      NEW RELEASE 1.9a - 12 Feb 17
                                      This release is certified for Sketchup 2017
                                      Download new release at main post
                                      • T
                                        trngngntn
                                        Great plugin !!!
                                        Btw can you do B-spline through points like this one :
                                        https://extensions.sketchup.com/en/content/b-spline-curves-through-points
                                        • fredo6F
                                          In BezierSpline, you have several tools to have the curve go thorugh the control points: Cubic BSpline, Catmull, FSpline.
                                          • T
                                            trngngntn
                                            I tried these tools but I feel that not what I needed.
                                            The begin and the end of the curves look too flat.
                                            F Spline is better but still flat.
                                            I included an image here :
                                            https://i.imgur.com/t65T7K7.png
                                            The curve which generated by the B Spline through points look smoother, but that plugin is hard to use and lack of editing tools.
                                            So I hope you can add that to yours.
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 19 / 23
