SketchUcation Tools in 2017
Another possibility...
Somehow the dialog's min height is getting messed with in the v2017 API [but only for some !], so I have made a test RBS that restricts the min height of that dialog to 100 - which should then be enough to give some borders and let you grab an edge and resize, and perhaps then have it remembered for next time ?Please follow these steps...
Download the attached ZIP file:SCF_Dialog.rbs.zip
Extract the RBS file that's in it - to somewhere like your Desktop.
Close SketchUp 2017.
OpenC:\Users\YourUserName\AppData\Roaming\SketchUp\SketchUp 2017\SketchUp\Plugins\SketchUcation
Find the file namedSCF_Dialog.rbs
Select it and rename itSCF_Dialog.rbsxxxso it doesn't load.
Move the new fileSCF_Dialog.rbsinto that subfolder.
Restart SketchUp 2017, test the SCF dialog and report what happens...NOTE:
Because changing that RBS file then breaks the 'signing' hash you must use the Unrestricted Loading Policy.If it's unsuccessful...
Reset things - delete theSCF_Dialog.rbsfile and rename theSCF_Dialog.rbsxxxoriginal asSCF_Dialog.rbs.
When you restart SketchUp 2017 things will be as they were.If it's successful...
I'll prepare a new v3.0.3 to include this 'hack'...Let us know...
Hi TIG,
The MINWIDTH and MAXWIDTH do came back as 350 and 900.The Regedit followed by Run As Administrator makes no change.
Can't you grab the bottom edge and make it higher ?
OK, so the dialog is now taller, but I cannot change the height. I do get the double headed arrow at the dialog's bottom edge, but cannot drag it either up or down. And the scrollbar on the RHS of the dialog has no effect FWIW.
Sorry, we had crossing posts. No, I cannot drag it in either direction.
Cool hack:
I feel we're getting there... can't we have a minimum value bigger than 100
The RBS in the attached ZIP has a larger min height [500] so it might at least be usable, at least until I get to the bottom of this weirdness...
Please follow the earlier instructions and retest.
I can't see how the window is not resize-able for you !
It is for me and the code specifically makes it so...Anyway, thanks for the testing...
Please report back...
Nice this one is useable:
Nicelly done, Thanks!
I now have a scrollable area, and the scrollbar works. Still cannot resize vertically, but at least it's usable in this form.
Thanks, and good luck with finding the root cause. Post again if I can help further.
JQL
Your last three images are blank apart from a caption in the middle.
EDIT: ...four...
They are not images, they are gifs, Click on them. Sorry for that I usually say you have to click on them but I believe Tig has seen those before, so I assume he knows he has to click them already. My mistake...
Here's how they are done with Licecap:
If I click on them I just get a popup window with the same, mostly black, image.
EDIT: AH, no, it just takes a little time to load. Sorry.
Damn... I'm not telling everything again. Click on them and wait 3 secs...
Sorry JQL.Good app that though, thanks for pointing it out.
Can you please try this alternative RBS in the attached ZIP.
As well as setting a min height [500] it also sets a max height [900] - which I hope might make the dialog see sense for those of you with the issue - it already works for me with no tweaks...Please report back asap...
I need to get this fixed...
I need to get this fixed...This worked flawlessly for me.
I had the weird box problem before.
-- it also remembers the size and location. -
Nice one Tig, although I don't need it.
Yes, that seems to work fine, though I'm not sure I can tell the difference from the previous version.
So you are saying that giving an explicit min & max height resolves the issue - it is now vertically resize-able between those limits... and its last used height is remembered on a restart... ??
Can someone else confirm this works for them too, so I can make an update...
