    [Tutorial] Animator Quick Start
    renderpluginsextensions
    136 Posts 39 Posters 896.5k Views 40 Watching
    • fredo6F
      Visual Extents
      This video tutorial explains the concept of Visual Extents which is a visual effect forcing the camera to frame the whole model or a selection of objects. The camera automatically pans and zooms to center the whole model or selection of objects and make sure it is fully visible in the viewport.
        Spielberg uses Animator for prototyping its movies! 😎
        • ithilI
          ithil
          Hi.
          Many thanks for such a wonderful plugin!
          I made a translation of this lesson on the Russian language.
          SketchUp for the Russian community.
          • fredo6F
            ithil,
            Good job. Thank you very much, this is a big contribution.
              Migmat
              PROBLEM GENERATING VIDEO with ffmpg.exe INSKETCHUP 2013 (Works Animator for this versión?)
              1- Animator Beta Works OK
              2- Install ffmpeg.exe in LibFredo6 (disapear the red text to Find the ffmpeg.exe)
              3- Make a simple animation that Works fine in preview
              4- Try to generate a video with defaut parameters. Push the button "Test Image" and also work
              5- Push the button "Generate Video" and NOTHING HAPPENDS. Sketchup continues inside the animator plugin. I can exit and star again the plugin,but nothing happends.
              I instal the two versión of ffmpeg.exe, the last and the 3.2 (more stable).
              Thanks in advance
              • fredo6F
                @Migmat
                Your problem may be independent of FFmpeg.
                When you generate the video, do you get the progress dialog box ?
                Can you open the Ruby console to see if there is an error displayed.
                  Migmat
                  Thanks Fredo for your extraordinary plugin.
                  I answer first and send more data next.
                  a- When generate Video animation (sketchup2013)I dont get any progress dialog box
                  b - Te rubi console says this error:
                  SkETCHUP 2013 RUBI CONSOLE OUTPUT DURING ANIMATOR VIDEO CREATION
                  ambient init nil nil
                  Twilight declare nil
                  :dimY => 806
                  :beg_time => 0
                  :date_modified => 1478294026.547
                  :reverse => nil
                  :movie_formats => {
                  :mov => false
                  :avi => true
                  :mp4 => true
                  } (:movie_formats)
                  :speed_factor => 1.0
                  :root_dir => "D:/DISEÑO_DIBUJOS_IMAGENES/SKETCHUP_2013/@_ Animaciones/ANIMATOR FREDO/Animator Videos"
                  :rendering_method => :natural
                  :movie_name => "Despegue avion"
                  :filter => {
                  } (:filter)
                  :dimX => 1710
                  :end_time => 2.0
                  :movie_dir => "AnimatorPRU_1 - 09-Nov-2016 18-22-13"
                  :dim_mode => "viewport"
                  :frame_rate => 25
                  Error: #<Errno::ENOENT: No such file or directory - D:/DISEÑO_DIBUJOS_IMAGENES/SKETCHUP_2013/@_ Animaciones/ANIMATOR FREDO/Animator Videos>
                  (eval):944:in mkdir' (eval):944:in movie_create_folder'
                  (eval):863:in movie_top_generate' (eval):1820:in movie_dialog_call_back'
                  (eval):379:in call' (eval):379:in notify_result'
                  (eval):442:in on_close' (eval):405:in dialog_create'
                  (eval):454:in call' (eval):454:in j_onclose'
                  (eval):197:in create_dialog' (eval):223:in call'
                  (eval):223:in close' (eval):223:in close'
                  (eval):453:in close_validate' (eval):1247:in param_dialog_callback'
                  (eval):574:in call' (eval):574:in j_action'
                  (eval):501:in j_callback' (eval):491:in j_dispatch'
                  END OF OUTPUT
                  Such directory efectively exist.
                  MORE EXPERIMETS
                  1- I installa Animator on Sketchup 2014 on the same PC
                  2- Works perfectly. meke the animation and the final video without problems.
                  Posible problem: we know that Sketchup 2013 and 2014 have quite differnt folder structure, firsly in the plugin placement.
                  Could be related with this?
                  thanks again.
                    Migmat
                    This is a sample of my animation job with a very poor elaborated animation plugin.
                    With your plugin I hope to get better results
                    (Is the recreation of a traffic accident seen from two viewpoint)
                    View From the car
                    • fredo6F
                      @Migmat,
                      1. In Sketchup 2013, there is no satisfactory support for non-ascii diretory or filename. So this may be the explanation. In Sketchup 2014, based on Ruby 2.0, non-ascii is fully supported.
                      2. Your video is quite impressive. I don't know which plugin you used, but I would not qualify it of "very poor elaborated animation plugin".
                        Dead or alive ?
                          Dead or alive ? (the motor bike guy)
                          PS Animator has not a French version ?
                            Migmat
                            Thanks Fredo for your acclaration. Now I am using Sketchup 2014.
                            Fortunately alive!. Thanks again for your care.
                            You hare good coders but better persons.
                            Compared with your Animator plugin the used in my video is really poor(frame Animation). The animation that I did is only plenty of tricks, artisan job and posproduction in some videos.
                            Postproduction i a really important key in most films.
                            I advice HitFilm. A very unknown and ppwerful software for PostPro.
                              Migmat
                              First test of your amazing Animator plugin.
                              Is only a ten minutes of work animation that shows a minimun part of the power behind Animator.
                                Migmat
                                A Little example of mixing Sketchup with some PostPro of HitFilm.
                                And a funny/mini PostPro.
                                https://www.youtube.com/watch?v=jHjCyM1yKRE
                                Fredo Animator plus HitFilm could be very good.
                                  M3one
                                  Hi Fredo,
                                  I've been working on an animation lately and it's almost finished. The last thing I want to do is to generate a video rendered with Twilight Render (free version) but I don't know how to do it. Please could you tell me how?
                                  • ntxdaveN
                                    ntxdave
                                    @m3one said:
                                    Hi Fredo,
                                    I am not Fredo but I can tell you that you must have the Pro version to create a rendered animation with Twilight.
                                    Press F1...thank me later
                                      M3one
                                      @ntxdave said:
                                      @m3one said:
                                      Hi Fredo,
                                      😞 That's a pity
                                      Is there anyway to generate a video clip with a decent render for free?
                                      Thanks for your answer!
                                      • fredo6F
                                        Trajectory
                                        Trajectory is a visual effect allowing to visualize the trajectory of selected points along the animation.
                                        The resulting Trajectory curves are drawn in the viewport. You can then
                                        • generate them as one or several groups in the Sketchup model
                                        • export the coordinates in a CSV file
                                        Since Trajectory is a visual effect, you can insert instances along the timeline and switch them on and off, so that you can visualize trajectory curves when desired.
                                        Note: because the resolution of trajectory is dependent on the progression of the animation, it is a good idea to reduce the animation speed to generate smoother trajectory curves.
                                          How is drawn the first curve without the object (s) ?
                                          Seems curves are resulting and not something to follow ?
                                          • fredo6F
                                            Trajectory curves reflect the movement of a given point on the solid. So they are always attached to an object.
                                            This feature has nothing to do with Movement along Path. This will come in the next release, when I finish the GUI for it.
                                            Actually, I initially designed the Trajectory visual effect for debugging purpose, in order to follow the movement of objects (since MovementAlongPath has to deal with offsetting).
                                            • 1 / 7
