    How to stretch a part of a model
    16 Posts 7 Posters 7.5k Views 7 Watching
    • jujuJ Offline
      juju
      The circle would look like a sausage and the model would be longer at the center section.
      DaveR, your method works, but doesn't take this into account.
        I reread the OP's post and see he wants to end up with an oval instead of a circle. That can be done with my first method if the circle is positioned correctly and exploded.
        If needed, the edges of the oval hole can be welded with TIG-weld.
        • BoxB Offline
          I must admit that I read this earlier and didn't reply because I felt the OP wasn't clear. Did he want the sausage or not.
            Yes. I clearly misunderstood the first time, too.
            • BoxB Offline
              No Dave I wouldn't say you have misunderstood, I'd say the question is unclear until clarified by the OP.
                Seems the case to use the Fredo Scale! 😄
                Minute 3.00
                Works also with wimple object! (no group or no component)
                Right Click for Show Hide Divider (Stretch) icon N°5
                Inside the Group Component
                • W Offline
                  williamp
                  Yes I was unclear, thank you for the replies. I'm usually able to work out things on my own, after 6 years I'm stumped so thanks for the help. 😉
                  I want the sausage...
                  The Fredo scales appear to distort the circular ends, the ends should remain the same shape.
                  I was also hoping someone would clarify whether there was at one time a built-in tool (not a plug-in) to perform this task, perhaps in a much older version of SU. I am almost certain that there was a tool built in to SU that did this, perhaps they removed it.
                  When you have very complex models, its much more time consuming to select everything manually so that is why I was looking for the tool.
                  Thanks.
                  • jujuJ Offline
                    juju
                    I don't recall the "tool" you may have in mind, not as a standard installation anyway.
                      Sausage as in oval like I showed in my last screen shots, not ellipse?
                      No. No tools have been removed. What I showed in my screenshots was done with only native tools.
                      Thanks.
                      It can be tine consuming to do that with a complex model. If you can anticipate the need, you can make adjustments to the modeling work flow to make it easier.
                      • HornOxxH Offline
                        HornOxx
                        Hi - an other option could be Tak2hata´s Stretch by Area plugin
                        http://sketchucation.com/pluginstore?pln=t2h_stretch_by_area
                        Thanks to all above for pointing out all these possibilities here.
                        Somehow I never unserstood, how Fredo´s scale tool (the one in the middle) is able to
                        stretch any outer shape but not this circle hole in the middle of it ❓ but it works
                        as shown in the video which Pilou has linked 😲 😳
                        So thanks again for all of your hints 😄
                        never trust a skinny cook
                        • fredo6F Offline
                          @hornoxx said:
                          Somehow I never understood, how Fredo´s scale tool (the one in the middle) is able to
                          FredoScale::Stretch use a simple rule:
                          • Curves (i.e. Sketchup Curve) are never deformed
                          • So you just need to explode your circle curve to have it transform into a sausage.
                          The main reason is that when you stretch furniture and you have rivet holes, you dont want them to stretch.
                          • HornOxxH Offline
                            HornOxx
                            Thank you Fredo ! These explanations are very helpful for me
                            Meanwhile I also understand that many tools have their own context options by right-clicking 😄
                            • W Offline
                              williamp
                              Thank you for the responses, Fredo6 was able to do it. Just needed to explode the curve as per the authors instructions above. Very nice little program.
                              Regards.
                              Stretch using Fredo6
