    1.5k Posts 478 Posters 4.3m Views 478 Watching
      I'm sure it's already been said here, and it's been commonly said elsewhere...
      SketchUp cannot create geometry less than 1/1000".
      With start/end of edges closer than that are regarded as coincident so that edge fails to form, then any faces that might rely on that edge are also missed out...
      Your model contains some tiny geometry - it's a wonder that it's survived thus far.
      It is easily resolved.
      Try Scaling everything x1000.
      Then set your Model Info > Units to m rather than mm.
      Switch off Units display.
      Change the number of d.p. displayed.
      Model in units assuming they are mm...
      Tiny edges are avoided.
      They can still exist in SketchUp but you can't make them...
      When you are ready to export to some other format, rescale the model down and use that.
      You'll need to reset the Model Units.
      A simple rescaling trick is to draw a line at the existing size that's 1000 units long and use the Tapemeasure tool to pick the start/end, which should show 1000, then type 1 + <enter>
      When prompted, accept the rescale and everything is reduced by 1/1000th
        ardianto0951
        Thanks Fredo, it Helps.......
          alankong
          Great
            deadstar
            thanks
            • N
              numerobis
              @numerobis said:
              @numerobis said:
              The edges are showing up correctly (hard edges) but the shading is messed up in display and rendering.
              I have to use the smoothing controls after the beveling and set it to hard egdes again to get this fixed.
              Any chance to get this fixed? Here is an example how it looks like in SU. Just like smoothing >45° + hard edges.
              The left cube is the direct result of the beveling. The right one is the same model with corrected normals (0°).
              https://abload.de/img/chamfer017fu3y.png
              (The lighting is the same)
              no? ❓
              • fredo6F
                no? ❓
                I am unclear on what is the problem.
                Do you have a model to share as well as the parameters you use for the Bevel operation.
                • N
                  numerobis
                  Sure, but i think there is nothing special at all.
                  https://abload.de/img/bevelcjspt.png
                  And here is model (v2015). The left cube shows the result of the beveling and the right one is the same model with fixed normals (0°).
                  bevel01.skp
                    I can see no visible difference between the two versions.
                    Perhaps due to my OpenGL settings.
                    However, using Entity Info on the contents...
                    The edges in the right-hand one are all 'normal' [i.e. solid with no behaviors checked].
                    But the edges in the left-hand one have their behaviors set differently -
                    'smooth' is checked, 'soft' is not.
                    However, they do not appear as softened/smoothed dotted-edges, but as 'normal' solid edges ??
                      @Numerobis, try making the shape but with the settings like this:
                      • N
                        numerobis
                        Ok, no i'm officially an idiot. 💚
                        Maybe i should have read the tooltips... i thought the continous line would be a hard edge an didn't realize that grey means smooth. Thanks for pointing this out Dave!
                        And sorry fredo that i bugged you with my "problems" ❗
                          davionkia
                          ty
                          • F
                            FZSarasota
                            I just tested it in 2017, Works Great!!! Thanks for the plugin, saves me a lot of time working in SU2017.
                            -Terry
                            • P
                              pebkac000
                              Great plugin. Thank you very much.
                              It is so easy to select the edges and configure for the required result.
                              • V
                                valid8r
                                A question. I'm thankful for this plug in. I've installed it on two machines, one running Win10 and one running Win7. Both install and the Win7 version works great, but the Win 10 'compresses' the window that gets loaded when I select one of the three cube icons. This means I can not control the parameters for RoundCorner. Is this a known issue with a solution?
                                • ipsketchpiI
                                  ipsketchpi
                                  Maybe silly question, but I cant get those edges visible, have tryed all without luck 😞 please help
                                  /IP
                                    Maybe you haven't tried all
                                    • ipsketchpiI
                                      ipsketchpi
                                      hmm, you have done it with "Sharp corners in 3D" and have choose one segment property for round corner.
                                      But can you repeat the same with "Bevel edges and corners" ?
                                      /IP
                                      • fredo6F
                                        Do you have a picture of the situation on Win 10. Do you have a high resolution screen ?
                                        • sirtetS
                                          sirtet
                                          SU 2017 complains about an outdated signature... Is there a new version of RoundCorner, or a workaround?
                                            There are loads of extensions that show as having outdated signatures. It doesn't prevent them from working. They still work just fine in SU2017 as does this one. The most recent version of Round Corner is in the SCF Extension Store.
                                            • 55
                                            • 56
                                            • 57
                                            • 58
                                            • 59
                                            • 74
                                            • 75
                                            • 57 / 75
