    [Plugin][$] S4u_Slice
    48 Posts 23 Posters 70.9k Views 23 Watching
    • cottyC Offline
      cotty
      Very nice plugin!
      One suggestion: a one-click-undo for the slicing would be nice.
      my SketchUp gallery
      • hdpvH Offline
        hdpv
        I use Ctrl_Z for undo.
        Suforyou
        http://www.sketchupforyou.com
          French version! πŸ˜‰
          Fr.zip
          • hdpvH Offline
            hdpv
            Thanks Mo!
            purchase here: http://extensions.sketchup.com/en/content/s4u-slice
            Suforyou
              Sure i can make an horizontal Detach or cut more! but... πŸ˜„
              • hdpvH Offline
                hdpv
                my slice is very sharp,it can detach a face to 2 faces. πŸ˜„
                This is special case.I will try fix it.
                Suforyou
                • Bob JamesB Offline
                  Bob James
                  S4USlice is enabled and activated but when I try to use it I get the License Expired error.
                  Extension Warehouse lists it in my extensions as enabled.
                  This is the second time I've gone through this rain dance 😞
                  What's wrong this time?????
                  Purchased From:
                  Trimble Navigation Ltd.
                  TIN# 94-2802192
                  Netherlands VAT # NL003257447B01
                  Billed to:
                  Robert James
                  4159 Constellation Road
                  Lompoc
                  CA, 93436
                  United States
                  Order Details:
                  Order Confirmation Number: 636688
                  Transaction Date: July 2, 2015 3:08:30 AM EDT
                  Vendor Web Store: HUYNH DUONG PHUONG VI
                  Your order includes the following items:
                  Qty Item No. Description Unit Price
                  1 x ea643527-4b89-45da-a8f6-c79994cd15e3 s4u Slice 3.3.1 $9.00 US
                  • hdpvH Offline
                    hdpv
                    Sorry! Sketchup checks the license.
                    I don't know this error.
                    Suforyou
                      Bob James
                      Are you going to attempt to find out? It would be nice if an extension I paid for would not be identified as expired.
                      • hdpvH Offline
                        hdpv
                        You try uninstall then reinstall.
                        http://help.sketchup.com/en/article/3000264
                        Your licenses is not expired.
                        or If you want install and active by manual(not on Extension WareHouse) i will send the file *.rbz to you.
                        Suforyou
                          Bob James
                          Extension Warehouse identifies Slice as enabled, but when used Slice is shown as expired.
                          Seems like the only thing left to do πŸ˜„
                            rv1974
                            Hdpv, would it be possible to add a 'multi-point' (not just by 2\3 points we have now) cutting mode?
                            • ithilI Offline
                              ithil
                              Hello!
                              Many thanks for your plugin.
                              I'm just happy with him πŸ˜ƒ
                              My work accelerated even more.
                              • srxS Offline
                                srx
                                Hi. Congratulation on making one of the most useful Sketchup plugins.
                                I have an idea to make it twice time useful πŸ˜„...simply by adding inverse function. So it could not only trim SU geometry, but also extend it using the same logic in picking 2 point lines, faces or 3 point faces...
                                Even more useful would be possibility to select a few faces, or curved surface as an "edge" for trimming, or extending.
                                It would be powerful feature.
                                www.saurus.rs
                                  makro88
                                  Hi, I've just purchased this extansions but after 3-4 inputs where it works correctly, it says "S4u_slice is not yet Activated. Do you have the Activaiton file?"
                                  Any solution?
                                  edit:
                                  I'm in touch with the developer, he's being super helpful.
                                  Apparently it's an issue linked to the extension warehouse, as I cannot use it within sketchup (it appears to be offline)
                                  • hdpvH Offline
                                    hdpv
                                    Suforyou
                                      KikoIta
                                      Hi, I just purchased the slice extension and I love it, I was wondering if you have an extension that can cut components base on a shape. For example, if I do a house siding made of components and then I need to cut the holes for the doors and windows
                                      • 3 / 3
