    [Plugin][$] S4u_Slice
    48 Posts 23 Posters 70.7k Views 23 Watching
      Sure i can make an horizontal Detach or cut more! but... πŸ˜„
      • hdpvH Offline
        hdpv
        my slice is very sharp,it can detach a face to 2 faces. πŸ˜„
        This is special case.I will try fix it.
        Suforyou
        http://www.sketchupforyou.com
        • Bob JamesB Offline
          Bob James
          S4USlice is enabled and activated but when I try to use it I get the License Expired error.
          Extension Warehouse lists it in my extensions as enabled.
          This is the second time I've gone through this rain dance 😞
          What's wrong this time?????
          Purchased From:
          Trimble Navigation Ltd.
          TIN# 94-2802192
          Netherlands VAT # NL003257447B01
          Billed to:
          Robert James
          4159 Constellation Road
          Lompoc
          CA, 93436
          United States
          Order Details:
          Order Confirmation Number: 636688
          Transaction Date: July 2, 2015 3:08:30 AM EDT
          Vendor Web Store: HUYNH DUONG PHUONG VI
          Your order includes the following items:
          Qty Item No. Description Unit Price
          1 x ea643527-4b89-45da-a8f6-c79994cd15e3 s4u Slice 3.3.1 $9.00 US
          • hdpvH Offline
            hdpv
            Sorry! Sketchup checks the license.
            I don't know this error.
            Suforyou
              Bob James
              Are you going to attempt to find out? It would be nice if an extension I paid for would not be identified as expired.
              • hdpvH Offline
                hdpv
                You try uninstall then reinstall.
                http://help.sketchup.com/en/article/3000264
                Your licenses is not expired.
                or If you want install and active by manual(not on Extension WareHouse) i will send the file *.rbz to you.
                Suforyou
                  Bob James
                  Extension Warehouse identifies Slice as enabled, but when used Slice is shown as expired.
                  Seems like the only thing left to do πŸ˜„
                    rv1974
                    Hdpv, would it be possible to add a 'multi-point' (not just by 2\3 points we have now) cutting mode?
                    • ithilI Offline
                      ithil
                      Hello!
                      Many thanks for your plugin.
                      I'm just happy with him πŸ˜ƒ
                      My work accelerated even more.
                      • srxS Offline
                        srx
                        Hi. Congratulation on making one of the most useful Sketchup plugins.
                        I have an idea to make it twice time useful πŸ˜„...simply by adding inverse function. So it could not only trim SU geometry, but also extend it using the same logic in picking 2 point lines, faces or 3 point faces...
                        Even more useful would be possibility to select a few faces, or curved surface as an "edge" for trimming, or extending.
                        It would be powerful feature.
                        www.saurus.rs
                          makro88
                          Hi, I've just purchased this extansions but after 3-4 inputs where it works correctly, it says "S4u_slice is not yet Activated. Do you have the Activaiton file?"
                          Any solution?
                          edit:
                          I'm in touch with the developer, he's being super helpful.
                          Apparently it's an issue linked to the extension warehouse, as I cannot use it within sketchup (it appears to be offline)
                          • hdpvH Offline
                            hdpv
                            Suforyou
                              KikoIta
                              Hi, I just purchased the slice extension and I love it, I was wondering if you have an extension that can cut components base on a shape. For example, if I do a house siding made of components and then I need to cut the holes for the doors and windows
                              • 3 / 3
