    [Plugin][$] S4u_Slice
    48 Posts 23 Posters 74.8k Views 23 Watching
    • Bob JamesB
      Bob James
      S4USlice is enabled and activated but when I try to use it I get the License Expired error.
      Extension Warehouse lists it in my extensions as enabled.
      This is the second time I've gone through this rain dance 😞
      What's wrong this time?????
      Purchased From:
      Trimble Navigation Ltd.
      TIN# 94-2802192
      Netherlands VAT # NL003257447B01
      Billed to:
      Robert James
      4159 Constellation Road
      Lompoc
      CA, 93436
      United States
      Order Details:
      Order Confirmation Number: 636688
      Transaction Date: July 2, 2015 3:08:30 AM EDT
      Vendor Web Store: HUYNH DUONG PHUONG VI
      Your order includes the following items:
      Qty Item No. Description Unit Price
      1 x ea643527-4b89-45da-a8f6-c79994cd15e3 s4u Slice 3.3.1 $9.00 US
      • hdpvH
        hdpv
        Sorry! Sketchup checks the license.
        I don't know this error.
        Suforyou
        http://www.sketchupforyou.com
        • Bob JamesB
          Bob James
          Are you going to attempt to find out? It would be nice if an extension I paid for would not be identified as expired.
          • hdpvH
            hdpv
            You try uninstall then reinstall.
            http://help.sketchup.com/en/article/3000264
            Your licenses is not expired.
            or If you want install and active by manual(not on Extension WareHouse) i will send the file *.rbz to you.
            Suforyou
            • Bob JamesB
              Bob James
              Extension Warehouse identifies Slice as enabled, but when used Slice is shown as expired.
              Seems like the only thing left to do πŸ˜„
                rv1974
                Hdpv, would it be possible to add a 'multi-point' (not just by 2\3 points we have now) cutting mode?
                • ithilI
                  ithil
                  Hello!
                  Many thanks for your plugin.
                  I'm just happy with him πŸ˜ƒ
                  My work accelerated even more.
                  • srxS
                    srx
                    Hi. Congratulation on making one of the most useful Sketchup plugins.
                    I have an idea to make it twice time useful πŸ˜„...simply by adding inverse function. So it could not only trim SU geometry, but also extend it using the same logic in picking 2 point lines, faces or 3 point faces...
                    Even more useful would be possibility to select a few faces, or curved surface as an "edge" for trimming, or extending.
                    It would be powerful feature.
                    www.saurus.rs
                      makro88
                      Hi, I've just purchased this extansions but after 3-4 inputs where it works correctly, it says "S4u_slice is not yet Activated. Do you have the Activaiton file?"
                      Any solution?
                      edit:
                      I'm in touch with the developer, he's being super helpful.
                      Apparently it's an issue linked to the extension warehouse, as I cannot use it within sketchup (it appears to be offline)
                      • hdpvH
                        hdpv
                        Suforyou
                        • K
                          KikoIta
                          Hi, I just purchased the slice extension and I love it, I was wondering if you have an extension that can cut components base on a shape. For example, if I do a house siding made of components and then I need to cut the holes for the doors and windows
                          • 3 / 3
