    [Plugin][$] S4u_Slice
    48 Posts 23 Posters 74.8k Views 23 Watching
    • hdpvH
      hdpv
      Hi John!
      Sorry,link on SketchUcation store had expired.
      You have to install (trial or purchase) direct from Sketchup: Menu - Windows -> Extension WareHouse
      http://extensions.sketchup.com/en/content/s4u-slice
      Suforyou
      http://www.sketchupforyou.com
      • B
        bsfranza
        awesome plugin!!!!
        keep up the great work!
        • E
          Esense3d
          Hello
          Can not try (expired) but Translate to German
          German Language File
          • cottyC
            cotty
            Very nice plugin!
            One suggestion: a one-click-undo for the slicing would be nice.
            my SketchUp gallery
            • hdpvH
              hdpv
              I use Ctrl_Z for undo.
              Suforyou
                French version! πŸ˜‰
                Fr.zip
                • hdpvH
                  hdpv
                  Thanks Mo!
                  purchase here: http://extensions.sketchup.com/en/content/s4u-slice
                  Suforyou
                    Sure i can make an horizontal Detach or cut more! but... πŸ˜„
                    • hdpvH
                      hdpv
                      my slice is very sharp,it can detach a face to 2 faces. πŸ˜„
                      This is special case.I will try fix it.
                      Suforyou
                      • Bob JamesB
                        Bob James
                        S4USlice is enabled and activated but when I try to use it I get the License Expired error.
                        Extension Warehouse lists it in my extensions as enabled.
                        This is the second time I've gone through this rain dance 😞
                        What's wrong this time?????
                        Purchased From:
                        Trimble Navigation Ltd.
                        TIN# 94-2802192
                        Netherlands VAT # NL003257447B01
                        Billed to:
                        Robert James
                        4159 Constellation Road
                        Lompoc
                        CA, 93436
                        United States
                        Order Details:
                        Order Confirmation Number: 636688
                        Transaction Date: July 2, 2015 3:08:30 AM EDT
                        Vendor Web Store: HUYNH DUONG PHUONG VI
                        Your order includes the following items:
                        Qty Item No. Description Unit Price
                        1 x ea643527-4b89-45da-a8f6-c79994cd15e3 s4u Slice 3.3.1 $9.00 US
                        • hdpvH
                          hdpv
                          Sorry! Sketchup checks the license.
                          I don't know this error.
                          Suforyou
                          • Bob JamesB
                            Bob James
                            Are you going to attempt to find out? It would be nice if an extension I paid for would not be identified as expired.
                            • hdpvH
                              hdpv
                              You try uninstall then reinstall.
                              http://help.sketchup.com/en/article/3000264
                              Your licenses is not expired.
                              or If you want install and active by manual(not on Extension WareHouse) i will send the file *.rbz to you.
                              Suforyou
                              • Bob JamesB
                                Bob James
                                Extension Warehouse identifies Slice as enabled, but when used Slice is shown as expired.
                                Seems like the only thing left to do πŸ˜„
                                  rv1974
                                  Hdpv, would it be possible to add a 'multi-point' (not just by 2\3 points we have now) cutting mode?
                                  • ithilI
                                    ithil
                                    Hello!
                                    Many thanks for your plugin.
                                    I'm just happy with him πŸ˜ƒ
                                    My work accelerated even more.
                                    • srxS
                                      srx
                                      Hi. Congratulation on making one of the most useful Sketchup plugins.
                                      I have an idea to make it twice time useful πŸ˜„...simply by adding inverse function. So it could not only trim SU geometry, but also extend it using the same logic in picking 2 point lines, faces or 3 point faces...
                                      Even more useful would be possibility to select a few faces, or curved surface as an "edge" for trimming, or extending.
                                      It would be powerful feature.
                                      www.saurus.rs
                                        makro88
                                        Hi, I've just purchased this extansions but after 3-4 inputs where it works correctly, it says "S4u_slice is not yet Activated. Do you have the Activaiton file?"
                                        Any solution?
                                        edit:
                                        I'm in touch with the developer, he's being super helpful.
                                        Apparently it's an issue linked to the extension warehouse, as I cannot use it within sketchup (it appears to be offline)
                                        • hdpvH
                                          hdpv
                                          Suforyou
                                          • K
                                            KikoIta
                                            Hi, I just purchased the slice extension and I love it, I was wondering if you have an extension that can cut components base on a shape. For example, if I do a house siding made of components and then I need to cut the holes for the doors and windows
                                            • 2 / 3
