    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
      Anton_S
      You can do this with MSPhysics but fredoa animation tool would be a lot more suitable for your purpose.
        SynSuka3D
        I did it! Here is my model
        • B
          bambutec
          Hey Guys,
          just dowloaded MSPhysics. Using a model like ray_test_0.9.skp , for me any change of properties like friction coefficients resp. change of materials do not reflect in how body´s behave. What could be the reason ?
          My platform is a mac on OS X 10.11.4 with SketchUp Pro 2016 16.0.19913.
          My intend is to simulate slide configurations and other attractions in Play and Leisure applications. Close to reality behavior is essential.
          Would be so great if this works, it is very promising !!
          Regards
          Uli
            realkim0123
            There is the only install program for Window environments.
            How can I install MSPhysics in Mac OS X?
            • C
              cristyan
              Hello !! Can someone tell me if an object can change his density if touched by another object ?? as in this file from metal to wood and from wood to metal ..
              1.skp
              • andreyshellA
                andreyshell
                Hi Anton!
                Thank you for your work! It helps me start doing things, I never did before!
                Testing plugin I repeat chain, like this one.
                https://youtu.be/AewFaqurPgc
                I know, it's a SkethcyPhisics, I follow an approach.
                But my chain brakes! I use different material, no result. Could you help me, what's wrong?
                Chain brakes in MSPhysics - wrong parameters (?)
                • C
                  cristyan
                  Hello !! andreyshell - Simulation > Update Timestep > set to x 1/6 (1/360) or more if is needed... hope that will help you .
                  • F
                    faust07
                    The Twilight renderer (Free) now supports MSPhysics simulations. However, there seems to be a conflict if you have installed both Physics plugins (MSPhysics and Sketchy Physics). Sketchy Physics replay data will be ignored.
                    During the rendering of frames of the MSPhysics simulation there also seems to be a conflict with the simultaneously running scene animation in the background.
                    This should be possible to turn off in the preferences, if the MSPhysics camera is used.
                    • N
                      NikolayTheM
                      How to make hole into a gear?
                      https://s16.postimg.org/d06n06dat/Screenshot_9.png
                      Here is problem with shape.
                      • andreyshellA
                        andreyshell
                        Wow! Great, it, works!
                        How to interpreter this parameter? How to understand it and use in modeling?
                        • C
                          count_olaf
                          @anton_s said:
                          TIG, yes, the error occurred while loaded main.rb, which occurs during registration, and I was able to fix it through trial and error.
                          ... I will upload it soon. Once again thanks for reporting.
                          Anton
                          Hi Anton
                          I have tried installing MSPhysics 0.9.3 in Sketchup Pro 2015 64 bit and get the same errors as reported in this string before your response. Is a fix for this still in the pipeline or is it in release 0.9.3? If the latter, I'm afraid error persists, for me.
                            surfmike
                            Hi!
                            An absolutely amazing plugin!!! 😄
                            However my groups are falling in the static surface when "toggle play". See attached pics and file.
                            How do I do to avoid this?
                            //Mikael
                            • chrisjmitchellC
                              chrisjmitchell
                              Hi All,
                              I just installed MS Physics from the Extension Warehouse and when I run the simulation nothing happens. The only thing that does happen is the right click context menu stops working. I tried this with two cubes hinged. Any suggestions? This is running on Sketchup 2016 Win10 64.
                              Also forgot to mention starting a new file from the current Sketchup session does not fix it. I have to actually close it and restart Sketchup.
                              • F
                                faust07
                                As always, it would be great to post the offending model. Then we can help you better.
                                • chrisjmitchellC
                                  chrisjmitchell
                                  Here is the sample of one. I tried it on others and got the same result. Sometimes it also disables my keyboard shortcuts.
                                  Thanks for checking it out!
                                  MS Physics Sample.skp
                                    surfmike
                                    Here's the file concerning objects sinking in the ground.
                                    Thx for assisting! 😄
                                    MSP test.skp
                                    • F
                                      faust07
                                      First step is to define the bottom face as Static Mesh. Then the model works without problems.
                                      • chrisjmitchellC
                                        chrisjmitchell
                                        Still dead on my end. It's like it partially locks up. Once I click the play button it starts acting weird. When I try to push things around all it does is try and draw a selection box.
                                          Anton_S
                                          @surfmike In case you're dealing with tiny objects in your model, you need to adjust some world parameters. For your model, changing gravity to -1.0 and setting world scale to 20 prevents the penetration. Furthermore, In order to get the servo to interact with objects A and B, more precisely have the servo rotate object B with respect to object A, you should group the servo joint with object A and then, use the Joint Connection Tool to connect the servo with object B. The connection can be done by activating the Joint Connection Tool, selecting the servo joint, holding down the control or shift button, and then selecting a desired group (object B in your case).
                                          @chrisjmitchel, I don't know what may be causing the error. What you can do is open Ruby Console, press Toggle Play, and then try clicking on the objects. If there's an error it might be outputted in the console.
                                            Anton_S
                                            @bambutec said:
                                            Hey Guys,
                                            Regards
                                            Uli
                                            My apologies for not responding, bambutec. I didn't see your post. I can indeed reproduce the friction bug on my Windows platform. I will notify you once it's fixed. Thanks for the report!
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 46
                                            • 47
                                            • 21 / 47
