    MSPhysics 1.0.3 (16 October 2017)
    929 Posts 172 Posters 1.3m Views 173 Watching
    • MALAISEM Offline
      MALAISE
      Hi Faust07
      I effectively saw some strange behavior without finding the origine. Many thanks
      having answered. For your, It's a part of an Diffractometer linked with automation process. (Echantillon means sample)
      Cheers.
      Pierre
      • MALAISEM Offline
        MALAISE
        Hallo Guys
        Good to know ( on SketchUp2015 or 2016 /windows 32 bit), It seems that only the 60 first
        pictures are exported. Perhaps, it's matter of Windows Version.
        Pierre
        • F Offline
          faust07
          Here the little corrected model. Works flawlessly. The original animation comprises approximately 950 individual images.
          cinématique D4 B_2.skp
            SynSuka3D
            fr: je voudrais faire pivoté un solide dans un groupe please !
            eng: I would like to rotate a body found in a compossent !!
              Anton_S
              You can't rotate body inside components. You can however make the body to rotate with respect to the parent component using joints. This can be done by creating s joint inside s component. Then use the joint connection tool to connect the parent component to the other components.
                SynSuka3D
                thanks Anton_S. I would like to select a body which is in a group !!
                and implement action (rotated, hide, change color ....)
                  Anton_S
                  You can do this with MSPhysics but fredoa animation tool would be a lot more suitable for your purpose.
                    SynSuka3D
                    I did it! Here is my model
                      bambutec
                      Hey Guys,
                      just dowloaded MSPhysics. Using a model like ray_test_0.9.skp , for me any change of properties like friction coefficients resp. change of materials do not reflect in how body´s behave. What could be the reason ?
                      My platform is a mac on OS X 10.11.4 with SketchUp Pro 2016 16.0.19913.
                      My intend is to simulate slide configurations and other attractions in Play and Leisure applications. Close to reality behavior is essential.
                      Would be so great if this works, it is very promising !!
                      Regards
                      Uli
                        realkim0123
                        There is the only install program for Window environments.
                        How can I install MSPhysics in Mac OS X?
                          cristyan
                          Hello !! Can someone tell me if an object can change his density if touched by another object ?? as in this file from metal to wood and from wood to metal ..
                          1.skp
                          • andreyshellA Offline
                            andreyshell
                            Hi Anton!
                            Thank you for your work! It helps me start doing things, I never did before!
                            Testing plugin I repeat chain, like this one.
                            https://youtu.be/AewFaqurPgc
                            I know, it's a SkethcyPhisics, I follow an approach.
                            But my chain brakes! I use different material, no result. Could you help me, what's wrong?
                            Chain brakes in MSPhysics - wrong parameters (?)
                              cristyan
                              Hello !! andreyshell - Simulation > Update Timestep > set to x 1/6 (1/360) or more if is needed... hope that will help you .
                              • F Offline
                                faust07
                                The Twilight renderer (Free) now supports MSPhysics simulations. However, there seems to be a conflict if you have installed both Physics plugins (MSPhysics and Sketchy Physics). Sketchy Physics replay data will be ignored.
                                During the rendering of frames of the MSPhysics simulation there also seems to be a conflict with the simultaneously running scene animation in the background.
                                This should be possible to turn off in the preferences, if the MSPhysics camera is used.
                                • N Offline
                                  NikolayTheM
                                  How to make hole into a gear?
                                  https://s16.postimg.org/d06n06dat/Screenshot_9.png
                                  Here is problem with shape.
                                    andreyshell
                                    Wow! Great, it, works!
                                    How to interpreter this parameter? How to understand it and use in modeling?
                                      count_olaf
                                      @anton_s said:
                                      TIG, yes, the error occurred while loaded main.rb, which occurs during registration, and I was able to fix it through trial and error.
                                      ... I will upload it soon. Once again thanks for reporting.
                                      Anton
                                      Hi Anton
                                      I have tried installing MSPhysics 0.9.3 in Sketchup Pro 2015 64 bit and get the same errors as reported in this string before your response. Is a fix for this still in the pipeline or is it in release 0.9.3? If the latter, I'm afraid error persists, for me.
                                        surfmike
                                        Hi!
                                        An absolutely amazing plugin!!! 😄
                                        However my groups are falling in the static surface when "toggle play". See attached pics and file.
                                        How do I do to avoid this?
                                        //Mikael
                                        • chrisjmitchellC Offline
                                          chrisjmitchell
                                          Hi All,
                                          I just installed MS Physics from the Extension Warehouse and when I run the simulation nothing happens. The only thing that does happen is the right click context menu stops working. I tried this with two cubes hinged. Any suggestions? This is running on Sketchup 2016 Win10 64.
                                          Also forgot to mention starting a new file from the current Sketchup session does not fix it. I have to actually close it and restart Sketchup.
                                          • F Offline
                                            faust07
                                            As always, it would be great to post the offending model. Then we can help you better.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 46
                                            • 47
                                            • 21 / 47
