    [Plugin] Make Unique Texture ++
    19 Posts 12 Posters 37.5k Views 12 Watching
    • EdsonE Offline
      Edson
      sorry, guys, but you totally confused me. ๐Ÿ˜• could anyone do a step-by-step explanation on how to install it on mac?
      edson mahfuz, architect| porto alegre โ€ข brasil
      http://www.mahfuz.arq.br
        driven
        @edson said:
        sorry, guys, but you totally confused me. :? could anyone do a step-by-step explanation on how to install it on mac?
        It is confusing...
        You needApple Developer Tools, if you have them or are happy to install them read on.
        Having tried lots of installs of this type, the easiest route IMO is via Homebrew http://mxcl.github.com/homebrew/
        Click on 'Install Homebrew Today' it takes you to a 'Read Me', read the guidance there. They explain it well, follow their advice.
        once you have it installed, adding other stuff become easier,
        but not plug and play.
        • demD Offline
          dem
          its a great tool!
          but does not work with big size textures ๐Ÿ˜ž
          maybe its because of imagemagic?
            stubbs
            Hi guys
            I don,t know if there are a lot of mac user using Make Unique Texture++ I think it is a great tool for hanling textures in sketchup. By the way lot of tks to Aerilius Sad that he is not a mac user, because it is a little complicated to make it run. I follow the tips of driven thanks also to you. The tool works on flat faces as espected but on curved faces i do not get the results like you did in your examples(pipes) above.
            If someone is intrested in my experience with the mac implementation I will add tips and Screenshots
            Michael
              driven
              @stubbs said:
              Hi guys
              I can't remember how I did it either...
              When I finally got this all running, I was also playing with TT's quad face tools and Fredo's bender from Scale Tools.
              No matter how good I got it to look in SU, tubes still appeared 'torn' when rendered. Using Make Unique Texture ++ after them fixed the issue, but I didn't make any notes for recreating the steps needed.
              Michael
              If you write up your process it may encourage myself and others to do the same...
              I was thinking I was the only 'mac' user so there was little point writing it up...
              glad you got it working, do you also use Texture Resizer? I find it really useful.
                asd123
                That's a good tool. Thanks.
                  saldstudio
                  hi guys, becouse of export sketchup files into another software, i was glad to find this plugin.
                  but when i try make few faces unique, sketchup show me error: Windows script Host, Script: C:\Users....\Local\Temp\temporary.vbs, system cant find file.
                  mostly, sketchup crash over this. any ideas?
                  • sicksickisckS Offline
                    sicksickisck
                    this tool don't work any moree
                      It'd hard to offer any help unless you are more descriptive to what doesn't work. If you can elaborate on what is happening and you expected to happen that would help. Also, include any error message you might see.
                        sicksickisck
                        ok sorry;
                        first the ruby concsole:
                        Error #<NoMethodError:undefined method `+' for nil:NilClass.>
                        second:
                        allways ask for ImageMagick/convert.exe ;
                        I choose that file and nothing happened ;/ just that console information
                          sicksickisck
                          some news?!!
                            sicksickisck
                            anybody...?
                              pipinek
                              Greetings,
                              It simply does not work at all. Nothing's been changed.
                              I have tried to make a several faces texture unique as on the picture.
                              The only way is to make each piece/surface texture unique.
                              I would appreciate any suggestion how to create one cropped texture (unique)as we see on the example.
                              Thank you in advance.
                              https://i.postimg.cc/xd9DQKg5/Screenshot-2021-10-01-195753.jpg
