    [Plugin] Make Unique Texture ++
    19 Posts 12 Posters 37.9k Views 12 Watching
      That's a clever tool. Thanks.
        driven
        Looks great,
        What's the game plan for those with 'ImageMagick' installed on their mac.
        [OK, maybe I am the only one at the moment, but...]
        I assume it's more than sips can bear.
        • bigstickB
          bigstick
          What if you don't have Imagemagick installed on your Mac?
          The Mac port installs automatically, and by the look of it, somewhere other than where this plugin expects it...
            driven
            I could ONLY get it to work by completely removing all traces of MacPorts, which had also screwed up my 'system ruby path'.
            I then installed Homebrew, in the correct path, usr/local/bin and then
            brew install magicks [check first...]
            in Terminal...
            more details dotted in this thread.
            http://forums.sketchucation.com/viewtopic.php?f=323&t=40720&hilit=texture+resizer&start=15#p362895
            However, if you type which convert into 'Terminal.app' it should return a path [if your MacPort worked] and that can be added in the ruby manually or by navigating from the Path to IM dialog [just ignore the file tag]
            It is working here on OSX 10.5.8
            test_on _mac
            Standard SU material
            • EdsonE
              Edson
              sorry, guys, but you totally confused me. ๐Ÿ˜• could anyone do a step-by-step explanation on how to install it on mac?
              edson mahfuz, architect| porto alegre โ€ข brasil
              http://www.mahfuz.arq.br
                driven
                @edson said:
                sorry, guys, but you totally confused me. :? could anyone do a step-by-step explanation on how to install it on mac?
                It is confusing...
                You needApple Developer Tools, if you have them or are happy to install them read on.
                Having tried lots of installs of this type, the easiest route IMO is via Homebrew http://mxcl.github.com/homebrew/
                Click on 'Install Homebrew Today' it takes you to a 'Read Me', read the guidance there. They explain it well, follow their advice.
                once you have it installed, adding other stuff become easier,
                but not plug and play.
                • demD
                  dem
                  its a great tool!
                  but does not work with big size textures ๐Ÿ˜ž
                  maybe its because of imagemagic?
                    stubbs
                    Hi guys
                    I don,t know if there are a lot of mac user using Make Unique Texture++ I think it is a great tool for hanling textures in sketchup. By the way lot of tks to Aerilius Sad that he is not a mac user, because it is a little complicated to make it run. I follow the tips of driven thanks also to you. The tool works on flat faces as espected but on curved faces i do not get the results like you did in your examples(pipes) above.
                    If someone is intrested in my experience with the mac implementation I will add tips and Screenshots
                    Michael
                      driven
                      @stubbs said:
                      Hi guys
                      I can't remember how I did it either...
                      When I finally got this all running, I was also playing with TT's quad face tools and Fredo's bender from Scale Tools.
                      No matter how good I got it to look in SU, tubes still appeared 'torn' when rendered. Using Make Unique Texture ++ after them fixed the issue, but I didn't make any notes for recreating the steps needed.
                      Michael
                      If you write up your process it may encourage myself and others to do the same...
                      I was thinking I was the only 'mac' user so there was little point writing it up...
                      glad you got it working, do you also use Texture Resizer? I find it really useful.
                        asd123
                        That's a good tool. Thanks.
                          saldstudio
                          hi guys, becouse of export sketchup files into another software, i was glad to find this plugin.
                          but when i try make few faces unique, sketchup show me error: Windows script Host, Script: C:\Users....\Local\Temp\temporary.vbs, system cant find file.
                          mostly, sketchup crash over this. any ideas?
                          • sicksickisckS
                            sicksickisck
                            this tool don't work any moree
                              It'd hard to offer any help unless you are more descriptive to what doesn't work. If you can elaborate on what is happening and you expected to happen that would help. Also, include any error message you might see.
                              • sicksickisckS
                                sicksickisck
                                ok sorry;
                                first the ruby concsole:
                                Error #<NoMethodError:undefined method `+' for nil:NilClass.>
                                second:
                                allways ask for ImageMagick/convert.exe ;
                                I choose that file and nothing happened ;/ just that console information
                                • sicksickisckS
                                  sicksickisck
                                  some news?!!
                                  • sicksickisckS
                                    sicksickisck
                                    anybody...?
                                    • P
                                      pipinek
                                      Greetings,
                                      It simply does not work at all. Nothing's been changed.
                                      I have tried to make a several faces texture unique as on the picture.
                                      The only way is to make each piece/surface texture unique.
                                      I would appreciate any suggestion how to create one cropped texture (unique)as we see on the example.
                                      Thank you in advance.
                                      https://i.postimg.cc/xd9DQKg5/Screenshot-2021-10-01-195753.jpg
