    [Plugin][$] Vertex Tools
    667 Posts 92 Posters 655.9k Views 92 Watching
      Select the verts you want planar and use the Gizmo scale handle to make them planar in the axis of choice.
      Just be sure to hit 0 and enter after dragging the handle to scale them planar.
        In VT2 the scale will stop at 0 - making it easier.
          Ah...VT2.
          #waitingpatientlyforthat
          • P
            Pherim
            @escapeartist said:
            Great looking plugin!
            May I make a suggestion that may provide additional usefulness to the plugin? I have no idea how easy it would be to implement, I don't know darn thing about Ruby. How about different profiles or wave forms used to calculate the shape of the deflection? I notice that the deflection when push/pulled is very smooth, but would it be possible to get different results by selecting a "profie shape", changing the rate and direction (positive or negative displacement) of deflection change across distance selected? Pictures:
            [attachment=0:2jjdgjng]<!-- ia0 -->profiles.jpg<!-- ia0 -->[/attachment:2jjdgjng]
            Possible? Not worth it?
            (Original Post)
            As this post is now six years old and it looks like there are still only two choices for this (linear and cosine), will this possibly be added at some point? It would be great to be able to manipulate the curve myself, but the pinched shape from the image would already be a wonderful addition. I am thinking about buying the plugin and this would certainly have an impact on my decision. πŸ˜‰
              http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=29636%26amp;p=600137#p599939 πŸ˜„
              • P
                Pherim
                Oh, I didn't see that! And it even is on the last page of the topic... I'm sorry, I just saw it was not yet implemented and did not want to read through all 15 pages, I hope you don't mind.
                Sounds great, though, I am looking forward to it.
                  No worries πŸ˜„ I'm not even able to keep up with these threads.
                    mannybmanago
                    Upon purchasing the vertext tools, can I run it on multiple computers I have log-in as sketchup-user?
                    BR,
                    Manny
                      The Vertex Tools license is per-user - to use on all your computers.
                        johnnypage
                        Hello Thom,
                        I've just purchased the Vertex tool plugin. I loaded in SU with the Sketchucation importer and....it doesn't work! I close nd re open SU and it appears to me a loading error message on screen. How can I fix it? Please help me to find a way to fix it
                        I have SU 2015 and Windows 8 pc and various other plugins loaded. Maybe something incompatible?
                          It would be useful if you share the exact error message.
                            What is the Sketchucation Importer?
                            • T
                              thirdleft
                              hi all! just started using this tool and am LOVING it! one thing though. is there any way to enter a scale or distance factor when in gizmo mode? the advantage of this would be that i could scale by half in just one axis rather than all at once. thanks in advance for your tips and this excellent resource!
                                hm... this should be working... but something seems to be broken.. 😞 I need to file this as a bug and investigate. Sorry. 😞
                                  alpro
                                  thomthom, I was trying to update my version of vertex tools by downloading the latest version from your site and it keeps getting flagged as a virus.
                                  Mike
                                    Achk! This is Windows Defender, right? Windows 10?
                                    Had this issue a couple of releases ago. I submitted the false positive to Microsoft and they updated their definitions.
                                    For some reason Defender freaks out about a JS file used for the webdialogs. It's bogus though.
                                      I submitted new reports to Microsoft; https://www.microsoft.com/en-us/security/portal/submission/submit.aspx
                                      I also asked if they could provide any info to why Defender keeps freaking out.
                                        alpro
                                        thomthom, Windows 7 Professional and Microsoft Security Essentials, if it makes a difference.
                                          Can you try downloading from Extension Warehouse? http://extensions.sketchup.com/en/content/vertex-tools
                                          I'm curious if Defender reacts differently depending on what site the file is downloaded from.
                                            alpro
                                            No issues downloading through the extension warehouse
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 33
                                            • 34
                                            • 22 / 34
