    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.3m Views 79 Watching
    • BoxB
      Yes Cotty, this printer has a very clever system of support. They break away very easily and the 'raft' somehow just pops off.
      • cottyC
        cotty
        I think "little" is the wrong word here...
        ๐Ÿ‘
        my SketchUp gallery
        • BoxB
          Since there was a little interest in printing results I did a quick cube SUbD box like the one I posted two pages back and printed it.
          This is straight out of the printer. The rough bit on the top is where I pulled it off the raft, it will clean off. You can see the little gap created by JPP around the lid, but a quick sand and it should fit snugly. The faceting will also smooth off, you could subd further if you wanted it smoother. The smaller things are the more the facets show.
          In case anyone is wondering, it's not some weird photoshoped image, it's just the physical model sitting on a tablet screen.
          • BoxB
            Little is all relative, a few people hitting the thumbs up button is pretty big on the forum.
            And as such I took it as interest. FB on the other hand can lead to expectations of hundreds or thousands of reactions, and if you don't get them it is a sure sign of little interest.
            Interesting how the same word can mean different things depending on context.
            • BoxB
              Here we go, a bit of sanding and a wipe with acetone, then another light sand and a buff.
              The tiny tassel hinges took a bit of fiddling.
                That's a great finish. what printer you use?
                • BoxB
                  It's an Up Mini that I picked up used for next to nothing. The guy bought it new but never learnt to model so he got bored with it and basically gave it away. It's my home one, I have access to a bunch of much larger ones at work.
                    I'm astonished at the surface finish you got.
                    • BoxB
                      What can I say, elbow grease and a gentle touch.
                      • BoxB
                        Just a quickie. The combination of SUbD, Vertex and Quad face tools makes it so easy to shape, manipulate and select everything.
                          UV mapping in Wrap-R?
                            Some licorice? ๐Ÿ˜Ž
                            • BoxB
                              No, by using quad face tools I easily selected the edges to create the various faces and manually painted them with the old bucket. So the colours are actual geometry.
                              • cottyC
                                cotty
                                lovely mesh...
                                my SketchUp gallery
                                • BoxB
                                  Here's a little example of how I did the colours. Not the same model but a similar process.
                                  http://i.imgur.com/zt35J6t.gif
                                  A very quick render for reference.
                                  • cottyC
                                    cotty
                                    "Soften" is a custom toolbar or an available plugin?
                                    my SketchUp gallery
                                    • BoxB
                                      It's a plugin Cotty, one I always use.
                                      It's ancestry is a bit muddled, but you'll find it in the store as Soften/Unsoften by CadFather.
                                      I'm very happy to point it out for you as a thankyou for showing me Anton's Fixit101 a long time back.
                                      • cottyC
                                        cotty
                                        @box said:
                                        Anton's Fixit101
                                        It's a very underrated plugin, isn't it?
                                        Thanks for sharing the name of the soften plugin!
                                        my SketchUp gallery
                                        • BoxB
                                          @cotty said:
                                          @box said:
                                          Anton's Fixit101
                                          One of the best ever written.
                                            Damned! Why I never seen this FixIt! A big miss one! ๐Ÿ˜ฎ
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 83
                                            • 84
                                            • 29 / 84
