    SubD examples and models
    renderpluginsextensions
    1.7k Posts 81 Posters 2.1m Views 79 Watching
    • Z
      ZahariStoyanov
      Rather than using sandpaper you could scramble it with sand in a box(not tested though - the plastic might snap :/) ❓
      • BoxB
        Yes, a tumbler might work nicely, abs is so soft it takes very little to smooth it.
        You could wipe it with acetone or hit it with a gentle flame, you could paint it or give it a thin coat of filler, the method you use pretty much depends on the finish you want.
        In this case I've just given it a rub over with an emery sponge to smooth off the outside faces. The inside can stay raw.
        This is just a handy demo of the results you can expect from a mid range domestic printer.
        Black is so difficult to photograph, plus the camera shows far more detail that the eye sees.
        You can see how on the corner my light sanding went through the shell. I printed it on the shell setting so the whole thing is actually hollow.
        It is remarkably strong and nicely tactile.
        • cottyC
          cotty
          VERY NICE!
          Thank you for sharing. After the support structure image, I didn't expect such a clean result. πŸ‘
          my SketchUp gallery
          • BoxB
            Yes Cotty, this printer has a very clever system of support. They break away very easily and the 'raft' somehow just pops off.
            • cottyC
              cotty
              I think "little" is the wrong word here...
              πŸ‘
              my SketchUp gallery
              • BoxB
                Since there was a little interest in printing results I did a quick cube SUbD box like the one I posted two pages back and printed it.
                This is straight out of the printer. The rough bit on the top is where I pulled it off the raft, it will clean off. You can see the little gap created by JPP around the lid, but a quick sand and it should fit snugly. The faceting will also smooth off, you could subd further if you wanted it smoother. The smaller things are the more the facets show.
                In case anyone is wondering, it's not some weird photoshoped image, it's just the physical model sitting on a tablet screen.
                • BoxB
                  Little is all relative, a few people hitting the thumbs up button is pretty big on the forum.
                  And as such I took it as interest. FB on the other hand can lead to expectations of hundreds or thousands of reactions, and if you don't get them it is a sure sign of little interest.
                  Interesting how the same word can mean different things depending on context.
                  • BoxB
                    Here we go, a bit of sanding and a wipe with acetone, then another light sand and a buff.
                    The tiny tassel hinges took a bit of fiddling.
                      That's a great finish. what printer you use?
                      • BoxB
                        It's an Up Mini that I picked up used for next to nothing. The guy bought it new but never learnt to model so he got bored with it and basically gave it away. It's my home one, I have access to a bunch of much larger ones at work.
                          I'm astonished at the surface finish you got.
                          • BoxB
                            What can I say, elbow grease and a gentle touch.
                            • BoxB
                              Just a quickie. The combination of SUbD, Vertex and Quad face tools makes it so easy to shape, manipulate and select everything.
                                UV mapping in Wrap-R?
                                  Some licorice? 😎
                                  • BoxB
                                    No, by using quad face tools I easily selected the edges to create the various faces and manually painted them with the old bucket. So the colours are actual geometry.
                                    • cottyC
                                      cotty
                                      lovely mesh...
                                      my SketchUp gallery
                                      • BoxB
                                        Here's a little example of how I did the colours. Not the same model but a similar process.
                                        http://i.imgur.com/zt35J6t.gif
                                        A very quick render for reference.
                                        • cottyC
                                          cotty
                                          "Soften" is a custom toolbar or an available plugin?
                                          my SketchUp gallery
                                          • BoxB
                                            It's a plugin Cotty, one I always use.
                                            It's ancestry is a bit muddled, but you'll find it in the store as Soften/Unsoften by CadFather.
                                            I'm very happy to point it out for you as a thankyou for showing me Anton's Fixit101 a long time back.
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 83
                                            • 84
                                            • 29 / 84
