    [Plugin] QuadFaceTools
    680 Posts 116 Posters 771.9k Views 116 Watching
      If you enter this into the Ruby Console and restart - does that fix things?
      TT;;Plugins;;QuadFaceTools.settings[;uv_u_scale] = 1.0
      TT;;Plugins;;QuadFaceTools.settings[;uv_v_scale] = 1.0
      • tuna1957T
        tuna1957
        Thomas, The help you gave me on my pillow model over on the SubD forum got me thinking. I have run the sandbox to quads function on proxies after doing various adjustments. I'm now wondering if I'm using the tool correctly. ( I'm sure I forgot or didn't think I needed to do it to the pillow ) I've been triple clicking to select all in the group or component then clicking the sandbox to quads button. Is that correct ? Also I've noticed there is no outward indication it's doing anything. For example some plugins will turn the curser into the spinning beachball until the've done their thing. Short of running the analyze color to quads is their another indication it's done the job that I'm just missing. ?
          I'm afraid there is not other indication right now. I have been toying with the idea of making a function that will update the face color based on whether its a triangle, quad or n-gone.
          • tuna1957T
            tuna1957
            Thomas , thanks for the quick response and I'll keep forging ahead and try and learn from my mistakes. ๐Ÿ‘
              I plan to make improvements to this - but I probably won't get around to do anything until after the summer.
              • tuna1957T
                tuna1957
                ๐Ÿ‘ It's all good Thomas. Amazed you do all the stuff you do. You must have some hidden super powers ! Definitely making progress with your tools. Heck messing about late last night and figured out how to get rid of the triangles I always end up with in the corners of those pillows. ๐Ÿ˜ฎ
                • tuna1957T
                  tuna1957
                  Thomas, Geez I feel like I'm turning into a pain in your arse. Started to get this load error tonight. Only pops up if I open a fresh SU window. Tried a few times , the error popped up every time. Opened a couple of existing models and didn't get the error? Any idea what this is about ? What did I break ? ๐Ÿ˜ฒ
                    That's a pesky bug I've not been able to squash yet: https://bitbucket.org/thomthom/tt-library-2/issues/18/tt-settings-with-length-cause-errors
                    Try this in the Ruby Console as a workaround:
                    • tuna1957T
                      tuna1957
                      ๐Ÿ‘ ๐Ÿ‘
                        I'll try to find a fix that doesn't break other extensions. The challenge with this is that is happening inside of TT_Lib2 - which is shared my most of my other extensions. ๐Ÿ˜•
                          Hi everyone
                          I have uploaded a new version of QFT - 0.10.0. It doesn't have new end-user features, but I implemented the error handler which Solid Inspector, SUbD and Vertex Tools already use. This means that if you run into Ruby errors you will get a dialog that let you submit it back to me.
                          Please upgrade and make sure you hit submit when you run into errors. I'm trying to map out the various bugs in the extension. "Got to catch them all!" ๐Ÿ˜›
                          • plot-parisP
                            plot-paris
                            Hey guys,
                            I run into this problem quite often, where I model a shape, making sure, every surface is a quad.
                            But when I use SUbD to subdivide, it looks wrong.
                            When I then use the "Flip Triangulation Tool" of QuadFaceTools, I can see that some faces (marked red in the model below) are not being recognized as quads.
                            Does any one know how this happens? And more importantly, how to fix it?
                            Cheers,
                            Jakob
                            QuadProblem_v01.skp
                            • BoxB
                              Sometimes you just need to tell it to make quads.
                              • plot-parisP
                                plot-paris
                                haha, I could have sworn I tried that. But obviously I didn't. ๐Ÿ˜ณ
                                Thanks a lot
                                  That reminds me - I had this idea for a function that would automatically color the faces as you modelled. I added an issue to track this: https://bitbucket.org/thomthom/quadface-tools/issues/98/live-quad-validation
                                    Just need an icon...
                                      Version 0.11.0 is out.
                                      • N
                                        numerobis
                                        ๐Ÿ˜Ž ๐Ÿ‘
                                        • cottyC
                                          cotty
                                          ๐Ÿ‘ and ๐Ÿ‘
                                          my SketchUp gallery
                                          • pbacotP
                                            Nice!
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 33
                                            • 34
                                            • 24 / 34
