    Personal test
    renderpluginsextensions
    37 Posts 6 Posters 21.4k Views 6 Watching
    • chriC Offline
      chri
      hi
      here an example with combine movements
      [highlight=#ffff00:9n2ne5dy]click on the GIF picture to animate.[/highlight:9n2ne5dy]
      Chri
      ROTATEANDFOLLOW.skp
        It's a simulate "follow" ? 😉
        • chriC Offline
          chri
          yes , it look like a simulate "follow"
          Really , it's a translation then a rotate then a new translation.
          The important tric is to choose the good pivot.
          Oui , en apparence
          Dans la réalité, c'est une translation puis une rotation puis une nouvelle translation .
          Le truc important est de bien déterminer le pivot.
          Chri
            Yes all that is the normal way! 😉
            Fredo use them in its videos !
            Does they indispensable ?
            (save position of objects, load and set position of objects)
            Have you use it in the videos above ?
            • fredo6F Offline
              These 2 icones are for positioners. Not strictly related to Animation, but useful to store and retrieve positions of objects, especially if ever the model is messed up.
              @chri: for editing a clip element, you can also double-click on it
              • chriC Offline
                chri
                c'est noté , merci.
                Chri
                • chriC Offline
                  chri
                  HI
                  a more simple example of "follow me" like movement
                  un exemple , plus simple , de mouvement type "suivez la trajectoire"
                  Chri
                  FOLLOWMELIKE.skp
                    Exactly! 😄
                      For simulate the follow of a longer piece 😄
                      Make first a translation (here front to the middle of the piece) then rotate!
                      Press image for see animation!
                      A same Movement can be reused! Here the rotation!
                      (of course an only 270° can be also work! )
                      • chriC Offline
                        chri
                        a trick
                        in the next example the three box 4 rotate arround the box 1 (with orange frame).
                        if the box 1 move , the three box 4 rotate ... and follow the box 1 .
                        ( parts and pivot are attached during all movements )
                        Un truc
                        Dans l'exemple suivant les trois boîtes 4 tournent autour de la boite1 (avec cadre orange).
                        Si la boite 1 se déplace , les trois boîte 4 tournent ... et suivent la boite 1.
                        ( les pièces et le pivot sont liés pour tous les mouvements )
                        Chri
                        • chriC Offline
                          chri
                          Pour simuler le "suivez-moi" d'une piéce longue , faire en premier , une translation ( ici , jusqu'au milieu de la piece ) , puis une rotation !
                          • chriC Offline
                            chri
                            HI
                            Another one to check the methodology
                            it take me about 30 minutes.
                            Thanks Fredo for this great present 👍
                            Chri
                            CUBE COLORE.skp
                              Rotative indeed! ☀
                              • chriC Offline
                                chri
                                hi
                                Some explanations in pictures about ROTATE MOVEMENT
                                1 To modify somethink , click on the BAR
                                the BAR became blue , the part orange
                                2 Select the "properties" icon
                                3 The part appear
                                4 Select "In Context Mode" icon
                                5 Select "Modify Pivot / Axe" icon
                                6 Select axe and pivot
                                ( note that frame became orange to show the reference part for pivot )
                                Bonjour
                                Quelques explication en images a propos des modifications ( MOUVEMENT DE ROTATION )
                                1 Pour modifier quelque chose , cliquer sur la barre
                                La barre devient bleu , la pièce se colore en l'orange
                                2 Sélectionner l'icone "properties"
                                3 La pièce apparaît
                                4 Sélectionner l'icone "In Context" pour effectuer un changement de repère.
                                5 Sélectionner l'icone "Modify Pivot" / Axe , pour pouvoir modifier les paramètres
                                6 Sélectionner axe et pivot
                                ( notez qu'un cadre orange apparaît pour montrer la pièce qui sert de pivot )
                                • chriC Offline
                                  chri
                                  New test
                                  ROTATEANYWHERE.skp
                                    I am right if i want object invisible during this little sequence?
                                    • ntxdaveN Offline
                                      ntxdave
                                      Yes, you can do it. See below:
                                      Click to play
                                      However, if there is going to be an overlap, you will need to capture the layer visibility at the beginning and end of each sequence.
                                      Hope this helps........
                                      Press F1...thank me later
                                      • chriC Offline
                                        chri
                                        [attachment=2:23mm6v40]<!-- ia2 -->no_visibility.jpg<!-- ia2 -->[/attachment:23mm6v40]
                                        Same as ntxave
                                        • ntxdaveN Offline
                                          ntxdave
                                          Chris, our responses overlapped. If you look at mine, you will see that you can also do it the way Pilou was asking about as long as there is no overlay with other visibilities.
                                          BTW: You and Pilou have give me some feedback on another thread where I was trying to rotate and object (garage door) but I still cannot find a way in that situation that works correctly (where panels follow the "track" for the garage door). See this thread: How to rotate better
                                            I have clicked this last icon first! 😳
