    [Plugin] Selection Toys
    594 Posts 121 Posters 381.1k Views 121 Watching
      Doh! You got it from PluginStore, right?
      I just realized I'd forgotten to hit Publish when I was updating the extension - so it was still version 2.3.8 that was available in the PluginStore.
      Just updated it - try that one.
        AcesHigh
        yes, it was 2.3.8 πŸ˜„
        thanks ThomThom. Anyway, there are a few other plugins that are giving me errors too since Sketchup moved its plugin folders to appdata.
        so I will try to change my username profile path following this tutorial
        http://www.ghacks.net/2011/03/28/how-to-change-a-windows-account-name-and-user-profile-folder-name/
        • gonashviliG Offline
          gonashvili
          @thomthom said:
          http://www.sketchucation.com/forums/scf/download/file.php?id=17957&mode=view
          [attachment=4:q89dnyc9]<!-- ia4 -->loop_sphere.png<!-- ia4 -->[/attachment:q89dnyc9]
          Hey there sir Thom, this is highly off-topic, but whats the plugin that divides a box into segments like here on this pic?
          Well, I take it you didn't do it by 'hand', manually..
            No plugin for that - I just copied and pasted.
              SplitUp to the rescue.... 😳
                or maybe this last one! πŸ˜‰
                Minute 3.23
                  bsfranza
                  hi there together...
                  i have a suggestion for a real good addition to this plugin πŸ˜ƒ
                  SELECT EDGES WHICH ARE PARALLEL
                  why would one need that?! after importing a cad drawing where the hatch is exploded and oall of the lines happen to be on one layer πŸ˜•
                  could be really handsome πŸ˜ƒ
                  thanks for your consideration on adding this option
                  EDIT
                  jim has answered my request here with a simple one liner πŸ˜„
                  http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=64523%26amp;p=591916#p591916
                  • romboutR Offline
                    rombout
                    Im on mac and nothing happens when i use the selection methods, i dont see any ouput in the ruby console or a error.
                    Im using latest version 2.2.2 on SU215 osx 10.11.5
                    • Dan RathbunD Offline
                      Dan Rathbun
                      No you're not. Latest (as of this reply) is 2.3.9.
                      http://sketchucation.com/pluginstore?pln=tt_selection_toys
                      or
                      http://extensions.sketchup.com/en/content/selection-toys
                      or
                      https://github.com/thomthom/SelectionTools/releases
                      I'm not here much anymore.
                      • romboutR Offline
                        rombout
                        Now using 2.3 nothing happens on mac. Any one here with same issues on mac?
                        I see no error in the console nothing
                          I just checked it on my Mac. It works for me. Are you sure you're using it correctly? Try making a cube, select it all by dragging a selection fence around it. Then click the green Edges button in the toolbar. Does it change the selection to only the edges?
                            There are many functions on Selection Toys - can you elaborate on what you do and how you do it?
                            • coulteriC Offline
                              coulteri
                              I am having problems with loading Selection Toys. I am using Sketchup 2016 on Windows 10.
                              Any tip for solution?
                                It appears it has to do with the accented characters in your username. Which version of Selection toys are you trying to install?
                                • coulteriC Offline
                                  coulteri
                                  I have the newest tt_selection_toys_v2.3.9
                                  Also the newest TT_Lib_v.2.10.6
                                    I uploaded a new patch to try to fix this. I'm not sure if it worked, so please post back with your results. (Remember to restart SketchUp).
                                    SketchUp Plugins | PluginStore | SketchUcation
                                    SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                    (sketchucation.com)
                                    • coulteriC Offline
                                      coulteri
                                      thanks a lot for your help!
                                      There is still one error (picture 1).
                                      Right mouse menu I use most works fine! (picture 2).
                                      But standalone menu doesnΒ΄t work correctly.
                                      All I need is OK. Where was the problem? In my user account name?
                                        Yea, Ruby have problems (some bugs) when it comes to non-English characters in filenames under Windows. There are some workarounds though.
                                        That remaining error is strange though... it's missing the backtrace.
                                        Can you try something for me?
                                        1. Download the RBZ for Selection Toys
                                        2. Close SketchUp.
                                        3. Remove Selection Toys.
                                        4. Start SketchUp
                                        5. Open the Ruby Console (Window > Ruby Console)
                                        6. Window > Preferences > Extensions > Install Extension. (Pick the Selection Toys RBZ)
                                        Do you get a longer error message in the Ruby console then?
                                        • coulteriC Offline
                                          coulteri
                                          I tried this:
                                          1. I removed selection toys from plugin folder
                                          2. I started sketchup without selection toys installed
                                          3. The prompt was still there (!?)
                                          So I think it does not matter on your plugin πŸ˜„
                                          I have installed more plugins these days. There is word "eval" in the prompt - I have evaluation version of Artisan installed so this could be a problem (maybe).
                                          πŸ˜„
                                            Hm.. yea, it's quite likely other extensions also will run into problems.
                                            As for Selection Toys. So it's installed and you see the menus? But the Settings dialog is blank?
                                            • 29
                                            • 30
                                            • 2 / 30
