    [Plugin Library] LibFredo6 - v15.9b - 21 Apr 26
    2.2k Posts 578 Posters 4.5m Views 580 Watching
    • fredo6F Offline
      @rstanley,
      You seem to have a possible mess in the Plugins directory, as the footprint for LibFredo6 is not correct.
      Did you install manually?
      It would be good that you show the content of the Plugin directory so that we can help
      • TampaPowersT Offline
        TampaPowers
        Error Loading File !AdditionalPluginFolders.rb
        uninitialized constant AdditionalPluginFolders6;;SketchupExtensionError Loading File C;/PROGRA~2/Google/GOOGLE~1/Plugins/SketchUcation/SCF_loader.rb
        (eval);324;in `log_setup'; uninitialized constant SCF;;SCF;;TEMPDIRError Loading File SketchUcation.rb
        Getting this now when loading existing projects. What do I do to fix it?
        Sketchup Community Discord
          The error is not relating to this plugin per se.
          It is simply reporting an error loading the SketchUcation Toolset.
          It's because you have a very old version of SketchUp.
          The current Toolset is written/encrypted to suit newer versions of SketchUp, and signed for full compatibility with v2016.
          I have sent you an alternative loader file that will work...
          Look in your Private Messages and follow the instructions I give there...
            patricknormand
            Bonjour,
            Je cherche désespérément le lien pour télécharger la version v6.9b de la librairie.
            Pouvez vous m'aider à la trouver ?
            Merci par avance,
            Patrick !
              @patricknormand
              Please learn to use the SketchUcation PluginStore Search tool...
              S'il vous plaît, apprendre à utiliser le SketchUcation PluginStore outil de recherche...
              SketchUp Plugins | PluginStore | SketchUcation
              SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
              (sketchucation.com)
                cocotier
                T
                  adamebeck
                  Hello, I am having the same problem as coasterinc first posted on Dec. 11, 2015. All of my fredo plugins have stopped working. The tool icons show up but when I click them the "in work window menus/ toolbars" no longer appear for any of the plugins.
                  I have gone back and forth deleting the plugins and cleaning out the plugin directory folders and then redownloading them through the Sketchucation Extension Store, but I cannot figure out what is wrong. I am currently testing things with only:
                  Fredo Lib 6.9 and Round Corners
                  I am using the current version of Sketchup Pro 2016. I know the plugins have worked for me in the past and I was previously using Sketchup Make 2015, but I am not completely sure at what point in upgrading this issue started.
                  Below, if it helps, is the Ruby Console window message when I try to use round corners:
                  Error: #<Errno::EACCES: Permission denied - C:/Users/Adam/AppData/Local/LIBFREDO6_DATA_Dir/LibFredo6_all_defaults.dat>
                  C:/Users/Adam/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Registry.rb:145:in initialize' C:/Users/Adam/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Registry.rb:145:in open'
                  C:/Users/Adam/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Registry.rb:145:in write_to_file' C:/Users/Adam/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Registry.rb:128:in store'
                  C:/Users/Adam/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1102:in usage_use' C:/Users/Adam/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1090:in command_invoke'
                  C:/Users/Adam/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1073:in block (2 levels) in build_config_commands' C:/Users/Adam/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:1154:in call'
                  C:/Users/Adam/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:1154:in block in add_command' SketchUp:1:in call'
                  Thank you for any help you can provide.
                  Adam
                  • fredo6F Offline
                    It looks like there is a problem to create files by program (to store some parameters of LibFredo6) in the directory: C:/Users/Adam/AppData/Local/LIBFREDO6_DATA_Dir. This may be due to some security settings, but normally AppData/Local is precisely the place where programs store data.
                    First time I see that. I'll be able to provide a workaround in a next version of LibFredo6.
                    For the time being, try to see how you can twek the Windows security settings for this directory and subfolders.
                      adamebeck
                      Fredo -
                      Thank you for the quick reply. Everything is now working normally, including reinstalling additional extensions to test (curviloft, fredotools, etc.)
                      I went to the folder you mentioned - C:/Users/Adam/AppData/Local/LIBFREDO6_DATA_Dir
                      All of the security permissions were already allowed. But, I made sure that the folder and all subfolders/ files were not hidden and unchecked all of the read-only boxes. I'm not sure I completely understand why that worked, but I hope that helps trouble shoot the code. I am running windows 7 if that makes a difference.
                      Thanks again for your help and creating the great extensions. I will let you know if I notice any conflicts with updates in the future.
                      Adam
                        billb2014
                        i have downloaded the latest library and also 3 of the related plugins but I am still not getting a toolbar to enable me to use the software?
                        what am I doing wrong?
                        Many thanks
                        billb2014
                          @billb2014 said:
                          You say you downloaded them. Did you install them, too? If so, how? Where did you put the files?
                            pabloalonso
                            Hello everyone:
                            I'm using Sketchup Pro 2016.
                            I installed SCF Pluging Store tool for installing extensions.
                            I installed Fredo 6.9 using SCF Pluging Store tool. I can see Preferences Fredo in menu and it shows LibFredo 6.9
                            I installed FredoTools from SCF...
                            ... but I can't see Fredo's plugings in the menu.
                            What can I do? Could you help me?
                            Pablo
                              Pablo
                              Probably look in the right place for Fredo Tools. It appears in the Tools menu.
                              If it doesn't show up in Tools, go to Preferences>Extensions and make sure Fredo Tools is enabled.
                              There's also a toolbar with a single button for Fredo Tools. You can turn it on from View>Toolbars.
                                pabloalonso
                                Hi, Dave. Thanks for your help.
                                Something is wrong. FredTools is checked on Window->Preferences->Extensions but there isn't Fredotools menu under "Tools".
                                What's your opinion about this?
                                Pablo
                                  jose_luz
                                  Amazing, very good!
                                    max2grand
                                    Did you ever get yours fixed? I'm having the same problem. I've installed the plugin, it shows that it's enabled, but there's nothing in the tools menu.
                                    Any ideas?
                                    Pablo
                                      Step one.
                                      Download/Install the LibFredo RBZ...
                                      http://sketchucation.com/pluginstore?pln=LibFredo6
                                      This Lib is needed by virtually all of Fredo's tools.
                                      Step two.
                                      Download/Install the desired Fredo extension's RBZ.
                                      His tool have different usage, so read there individual guides...
                                      In the case of Fredo's Tools...
                                      http://sketchucation.com/pluginstore?pln=FredoTools
                                      It has a toolbar which you might need to activate, and it also should have a submenu under:
                                      'Tools > FredoTools'...
                                      Also check that its Extension is activated - otherwise these will not show up.
                                      PS:
                                      Install the RBZ files using the native:
                                      Preferences > Extensions > Install Extension... button
                                      Or install and use the SketchUcation Toolset > ExtensionStor³ ...
                                      which sidesteps the download, and auto-installs any extensions directly...
                                      • fredo6F Offline
                                        NEW RELEASE: LibFredo6 v7.2a - 20 Oct 16
                                        LibFredo6 7.2a is a release mainly dedicated to the beta program of Animator. It also includes bug fixes and adjustments for FredoTools
                                        See main post of this thread for Download of LibFredo6.
                                        • N Offline
                                          Netka
                                          I really need some help with solving instalation problem LibFredo6 v7.2a. After succsesful instalation and restarting SU pro 2013 I've got the following message:
                                          It seemed to be properly installed in the su folder:
                                          I don't even know where to search for solution. please help.
                                            @Netka
                                            Older Ruby versions can break if there are accents in file-paths.
                                            Usually this is due to ill-advised accented Windows User-names, but in your case the 'Programs' folder itself also has an accent in its name !
                                            What is your language ?
                                            Newer Ruby versions now shipped with >=v2014? have the ability to re-encode file-paths into UTF-8 [without BOM] so they are then compatible...
                                            Unfortunately you have v2013, which is barely supported, and will soon be unsupported by its owners...
                                            Can you try a newer version of SketchUp ? - this might well fix you issue...
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 110
                                            • 111
                                            • 55 / 111
