    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • fredo6F
      It looks like there is a problem to create files by program (to store some parameters of LibFredo6) in the directory: C:/Users/Adam/AppData/Local/LIBFREDO6_DATA_Dir. This may be due to some security settings, but normally AppData/Local is precisely the place where programs store data.
      First time I see that. I'll be able to provide a workaround in a next version of LibFredo6.
      For the time being, try to see how you can twek the Windows security settings for this directory and subfolders.
        adamebeck
        Fredo -
        Thank you for the quick reply. Everything is now working normally, including reinstalling additional extensions to test (curviloft, fredotools, etc.)
        I went to the folder you mentioned - C:/Users/Adam/AppData/Local/LIBFREDO6_DATA_Dir
        All of the security permissions were already allowed. But, I made sure that the folder and all subfolders/ files were not hidden and unchecked all of the read-only boxes. I'm not sure I completely understand why that worked, but I hope that helps trouble shoot the code. I am running windows 7 if that makes a difference.
        Thanks again for your help and creating the great extensions. I will let you know if I notice any conflicts with updates in the future.
        Adam
        • B
          billb2014
          i have downloaded the latest library and also 3 of the related plugins but I am still not getting a toolbar to enable me to use the software?
          what am I doing wrong?
          Many thanks
          billb2014
            @billb2014 said:
            You say you downloaded them. Did you install them, too? If so, how? Where did you put the files?
            • P
              pabloalonso
              Hello everyone:
              I'm using Sketchup Pro 2016.
              I installed SCF Pluging Store tool for installing extensions.
              I installed Fredo 6.9 using SCF Pluging Store tool. I can see Preferences Fredo in menu and it shows LibFredo 6.9
              I installed FredoTools from SCF...
              ... but I can't see Fredo's plugings in the menu.
              What can I do? Could you help me?
              Pablo
                Pablo
                Probably look in the right place for Fredo Tools. It appears in the Tools menu.
                If it doesn't show up in Tools, go to Preferences>Extensions and make sure Fredo Tools is enabled.
                There's also a toolbar with a single button for Fredo Tools. You can turn it on from View>Toolbars.
                • P
                  pabloalonso
                  Hi, Dave. Thanks for your help.
                  Something is wrong. FredTools is checked on Window->Preferences->Extensions but there isn't Fredotools menu under "Tools".
                  What's your opinion about this?
                  Pablo
                    jose_luz
                    Amazing, very good!
                      max2grand
                      Did you ever get yours fixed? I'm having the same problem. I've installed the plugin, it shows that it's enabled, but there's nothing in the tools menu.
                      Any ideas?
                      Pablo
                        Step one.
                        Download/Install the LibFredo RBZ...
                        http://sketchucation.com/pluginstore?pln=LibFredo6
                        This Lib is needed by virtually all of Fredo's tools.
                        Step two.
                        Download/Install the desired Fredo extension's RBZ.
                        His tool have different usage, so read there individual guides...
                        In the case of Fredo's Tools...
                        http://sketchucation.com/pluginstore?pln=FredoTools
                        It has a toolbar which you might need to activate, and it also should have a submenu under:
                        'Tools > FredoTools'...
                        Also check that its Extension is activated - otherwise these will not show up.
                        PS:
                        Install the RBZ files using the native:
                        Preferences > Extensions > Install Extension... button
                        Or install and use the SketchUcation Toolset > ExtensionStor³ ...
                        which sidesteps the download, and auto-installs any extensions directly...
                        • fredo6F
                          NEW RELEASE: LibFredo6 v7.2a - 20 Oct 16
                          LibFredo6 7.2a is a release mainly dedicated to the beta program of Animator. It also includes bug fixes and adjustments for FredoTools
                          See main post of this thread for Download of LibFredo6.
                          • N
                            Netka
                            I really need some help with solving instalation problem LibFredo6 v7.2a. After succsesful instalation and restarting SU pro 2013 I've got the following message:
                            It seemed to be properly installed in the su folder:
                            I don't even know where to search for solution. please help.
                              @Netka
                              Older Ruby versions can break if there are accents in file-paths.
                              Usually this is due to ill-advised accented Windows User-names, but in your case the 'Programs' folder itself also has an accent in its name !
                              What is your language ?
                              Newer Ruby versions now shipped with >=v2014? have the ability to re-encode file-paths into UTF-8 [without BOM] so they are then compatible...
                              Unfortunately you have v2013, which is barely supported, and will soon be unsupported by its owners...
                              Can you try a newer version of SketchUp ? - this might well fix you issue...
                              • chriC
                                chri
                                Same message for me with SKETCHUP 8 and SKETCHUP 2013
                                Works with SKETCHUP 2014
                                ( windows XP )
                                chri
                                • N
                                  Netka
                                  hi again
                                  thank you very match for a quick response. I just installed SU 2014 and everythimg is finally working ❗ - problem fixed.
                                  and the language I use is polish.
                                  warm regards
                                  Neta
                                  • T
                                    Treadshot A1
                                    Hi fredo6,
                                    I'm getting the same error message from v7.2 regarding its corresponding folder.
                                    The folder appears to be there (the .rbz was installed through Sketchup's Extension Manager).
                                    I see other users found workarounds through using 2014 or newer versions of Sketchup (apparently to bypass Ruby issues with accents); is this confirmed necessary? I'm running Sketchup 8 Free, on a Windows 8 machine (upgrading to a newer Sketchup is extremely undesirable), which previously was running LibFredo6 v4.7a (very very old version, I'm aware) with FredoScale/RoundCorner successfully. I've checked the file path to my Sketchup Plugins folder; no accented characters as far as I can tell. Is there a way to make this version of the library work on SU8, especially so I can test Animator's beta release?
                                    Thanks for all the great plugins. 😄
                                    • fredo6F
                                      @treadshot A1
                                      There is general problem for SU versions prior to v2014, running Ruby 1.8. I thought it was in Windows XP only, but since you have Windows 8, this may be more general. The issue is that I don't have the problem in my environment (Win 7, 64 bits), so I am a little bit blind.
                                      • T
                                        Treadshot A1
                                        @fredo6
                                        Thanks for the quick reply, and the alternative file. I've tested the new file on the same machine (Win 8, 64 Bit, SU8Free) as before, unfortunately it's not working.
                                        That said, it did improve somewhat. Previously, once I removed the old LibFredo6, none of the Fredo plugins worked. This time, the error message on startup mentioned "traductor" (either traductor.rb, or "uninitialised constant traductor" or variations thereof). I found a "traductor.rb" in my plugins, which was NOT put there by LibFredo6 v7.2, instead traductor.rb was there from the old v4.7 installation of LibFredo6. I don't know what traductor.rb does, but I tried deleting it, which had the side effect of making Joint Push Pull's toolbar show up again (sloppily highlighted below). I'm not sure why JointPushPull showed up but none of your other plugins did.
                                        Side note: I tested the new encrypted version of LibFredo6 v7.2 on a different machine (Win10, 64Bit, SU8Free), with a fresh install of Win10 and SU8 (so no Plugins other than LibFredo6 v7.2 and whatever example/default plugins that come with SU8). Error Message shows Traductor as an uninitialised constant (I do NOT have the "traductor.rb" file on this machine, that the first machine had), and there is no LibFredo6 Settings option in the Tools nor Window menu in Sketchup.
                                        Hope this information is in some way helpful. Thanks again. 😄
                                        • T
                                          topbobster
                                          Hello, Please help, Rob.
                                          I recently purchased Sketchup Pro 2016 and would love to use Round Corner and Tools but keep getting the error message: 'You must install LibFredo version 6.9 ot higher to run Fredo6_RoundCorner'
                                          I then get the message:
                                          Error Loading File C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/top_LibFredo6.rbe
                                          Failed to read RBE/RBS file.
                                          Error Loading File Fredo6_!LibFredo6.rb
                                          Error: #<NameError: uninitialized constant LibFredo6_Loader::LibFredo6>
                                          C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:59:in process' C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:66:in module:LibFredo6_Loader'
                                          C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:28:in <top (required)>' Error Loading File Fredo6_FredoTools.rb Error: #<TypeError: can't convert nil into an exact number> C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:75:in -'
                                          C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6.rb:75:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require'
                                          C:/Program Files/SketchUp/SketchUp 2016/Tools/RubyStdLib/rubygems/core_ext/kernel_require.rb:45:in require' C:/Users/User/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_FredoTools.rb:25:in <top (required)>'
                                          In the following folders:
                                          C:\Users\User\AppData\Roaming\SketchUp\SketchUp 2016\SketchUp\Plugins
                                          C:\Program Files (x86)\Google\Google SketchUp 8\Plugins
                                          I have the follwing folder/files:
                                          Fredo6_FredoTools (folder)
                                          Fredo6_FredoTools.rbx
                                          Fredo6_RoundCorner (folder)
                                          Fredo6_RoundCorner.rb
                                          Fredo6_RoundCorner.rbx
                                          All installed 1st time manually, 2nd time via Windows>Prefeences>Install Extensions and latest effort using SketchUcation ExtensionStore 3.0
                                            @topbobster, I expect you copied an old version of LibFredo6 from your ancient SU8 Plugins folder to the SU2016 Plugins folder when you "installed it manually" and at least some of those old files are still resident in the Plugins folder. Go to that folder and delete anything and everything related to LibFredo6. Then reinstall it using the ExtensionStore.
                                            Did you copy Round Corner, too? If so, delete it and reinstall it fresh.
                                            It's unwise to copy plugins from an old SketchUp version to a new one. Changes to the Ruby code are common and installing old versions creates problems.
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 115
                                            • 116
                                            • 55 / 116
