    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.3k Posts 587 Posters 11.0m Views 589 Watching
      @in2 said:
      Thanks guys.
      Have to say nicely hidden though about the smallest text on the page....
      All that large bold print is too small? Maybe Fredo will have to make it larger.
      • TampaPowersT
        TampaPowers
        I keep getting the same Message: LibFredo6 will be updated at the next startup...
        I have already changed the permissions and took ownership of the whole Sketchup folder. After that message the SketchUcation Toolset one appears. The extension and plugins manager won't open, but the store was updated properly. LibFredo seems to be up to date as well and I can open its windows. I am still on Sketchup 8 btw.
        Sketchup Community Discord
        • C
          cxerach
          Please. I installed the libfredo6 in 2016 sketchup correctly, I have long been trying to use it, but I can not open tools, how can you open?, Is there tutorial ?.
            What tools are you trying open? Please be specific. LibFredo6 is a package of support files that many of Fredo6's tools are dependent upon but it isn't useful by itself.
            • TampaPowersT
              TampaPowers
              I reinstalled the whole set after manually removing them from the plugins folder, same message pops up, but now the tools do not work, non of the windows open. What am I doing wrong?
              • Z
                zak1974
                thx
                • K
                  karlicamel
                  hola esta biblioteca no es gratis?
                    Why do you think it is not free?
                    There is no charge for this although you can make a donation to Fredo6 for his hard work.
                      rstanley
                      Dear Fredo ,
                      I have tried to upgrade to libfredo6 - v6.9b and although it appears to work I get this message upon opening my skp(pro15):
                      /Users/richard/Desktop/Screen Shot 2016-02-29 at 3.12.28 PM.png
                      What does it mean: What am I missing?
                      Thanks in advance,
                      Richard
                      • fredo6F
                        @rstanley,
                        You seem to have a possible mess in the Plugins directory, as the footprint for LibFredo6 is not correct.
                        Did you install manually?
                        It would be good that you show the content of the Plugin directory so that we can help
                        • TampaPowersT
                          TampaPowers
                          Error Loading File !AdditionalPluginFolders.rb
                          uninitialized constant AdditionalPluginFolders6;;SketchupExtensionError Loading File C;/PROGRA~2/Google/GOOGLE~1/Plugins/SketchUcation/SCF_loader.rb
                          (eval);324;in `log_setup'; uninitialized constant SCF;;SCF;;TEMPDIRError Loading File SketchUcation.rb
                          Getting this now when loading existing projects. What do I do to fix it?
                            The error is not relating to this plugin per se.
                            It is simply reporting an error loading the SketchUcation Toolset.
                            It's because you have a very old version of SketchUp.
                            The current Toolset is written/encrypted to suit newer versions of SketchUp, and signed for full compatibility with v2016.
                            I have sent you an alternative loader file that will work...
                            Look in your Private Messages and follow the instructions I give there...
                            • P
                              patricknormand
                              Bonjour,
                              Je cherche désespérément le lien pour télécharger la version v6.9b de la librairie.
                              Pouvez vous m'aider à la trouver ?
                              Merci par avance,
                              Patrick !
                                @patricknormand
                                Please learn to use the SketchUcation PluginStore Search tool...
                                S'il vous plaît, apprendre à utiliser le SketchUcation PluginStore outil de recherche...
                                404 Not Found
                                (sketchucation.com)
                                • C
                                  cocotier
                                  T
                                    adamebeck
                                    Hello, I am having the same problem as coasterinc first posted on Dec. 11, 2015. All of my fredo plugins have stopped working. The tool icons show up but when I click them the "in work window menus/ toolbars" no longer appear for any of the plugins.
                                    I have gone back and forth deleting the plugins and cleaning out the plugin directory folders and then redownloading them through the Sketchucation Extension Store, but I cannot figure out what is wrong. I am currently testing things with only:
                                    Fredo Lib 6.9 and Round Corners
                                    I am using the current version of Sketchup Pro 2016. I know the plugins have worked for me in the past and I was previously using Sketchup Make 2015, but I am not completely sure at what point in upgrading this issue started.
                                    Below, if it helps, is the Ruby Console window message when I try to use round corners:
                                    Error: #<Errno::EACCES: Permission denied - C:/Users/Adam/AppData/Local/LIBFREDO6_DATA_Dir/LibFredo6_all_defaults.dat>
                                    C:/Users/Adam/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Registry.rb:145:in initialize' C:/Users/Adam/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Registry.rb:145:in open'
                                    C:/Users/Adam/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Registry.rb:145:in write_to_file' C:/Users/Adam/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Registry.rb:128:in store'
                                    C:/Users/Adam/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1102:in usage_use' C:/Users/Adam/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1090:in command_invoke'
                                    C:/Users/Adam/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Plugin.rb:1073:in block (2 levels) in build_config_commands' C:/Users/Adam/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:1154:in call'
                                    C:/Users/Adam/AppData/Roaming/SketchUp/SketchUp 2016/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Traductor.rb:1154:in block in add_command' SketchUp:1:in call'
                                    Thank you for any help you can provide.
                                    Adam
                                    • fredo6F
                                      It looks like there is a problem to create files by program (to store some parameters of LibFredo6) in the directory: C:/Users/Adam/AppData/Local/LIBFREDO6_DATA_Dir. This may be due to some security settings, but normally AppData/Local is precisely the place where programs store data.
                                      First time I see that. I'll be able to provide a workaround in a next version of LibFredo6.
                                      For the time being, try to see how you can twek the Windows security settings for this directory and subfolders.
                                        adamebeck
                                        Fredo -
                                        Thank you for the quick reply. Everything is now working normally, including reinstalling additional extensions to test (curviloft, fredotools, etc.)
                                        I went to the folder you mentioned - C:/Users/Adam/AppData/Local/LIBFREDO6_DATA_Dir
                                        All of the security permissions were already allowed. But, I made sure that the folder and all subfolders/ files were not hidden and unchecked all of the read-only boxes. I'm not sure I completely understand why that worked, but I hope that helps trouble shoot the code. I am running windows 7 if that makes a difference.
                                        Thanks again for your help and creating the great extensions. I will let you know if I notice any conflicts with updates in the future.
                                        Adam
                                        • B
                                          billb2014
                                          i have downloaded the latest library and also 3 of the related plugins but I am still not getting a toolbar to enable me to use the software?
                                          what am I doing wrong?
                                          Many thanks
                                          billb2014
                                            @billb2014 said:
                                            You say you downloaded them. Did you install them, too? If so, how? Where did you put the files?
                                            • 52
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 113
                                            • 114
                                            • 54 / 114
