    Animator: Parametric Animation plugin - Discussion
    223 Posts 55 Posters 118.8k Views 55 Watching
    • fredo6F Offline
      @usen said:
      Every common program has the timeline at the bottom, will you keep it on the left?
      • JQLJ Offline
        JQL
        LOL!
        The main mistake is confusing Fredo6's work with common programs!
        www.casca.pt
        Visit us on facebook!
          Fredo President! ☀
            New round of donations for Fredo - anyone?
            • fredo6F Offline
              @pilou said:
              Sorry where is the plugin ? 😳
              It's only for happy fews ? 😄
              I am still resolving some basic issues with the animation representation framework. So there is some delay, again and again.
              • duanekempD Offline
                duanekemp
                I too am a Mac user as well as PC. I'd be more than willing to be your guinea pig for test on both.
                Duane Kemp
                Kemp Productions
                Puidoux, Switzerland
                Gallery:
                https://duanekemp.artstation.com/
                • EarthMoverE Offline
                  EarthMover
                  Fredo, I see you've released 6 beta tutorial videos on your youtube channel. I hope that means something is coming soon. 😄
                  Content Creator at Skapeup
                    driven
                    fredo,
                    you can bundle 64-bit ffmpeg binary with your plugin for use on Snow Leopard, Lion, Mountain Lion, Mavericks, Yosemite and El Captain.
                    it eliminates the need to download, instal, look for, etc...
                    • fredo6F Offline
                      @driven said:
                      fredo,
                      John,
                      Not sure it's a feasible idea:
                      • I don't know if I have the right to distribute it.
                      • The exe file is roughly 40 Mb, so not light
                      • I would have 2 distributions, one for Windows (maybe 2 if 32bits is still around), one for Mac
                      If there is a right to redistribute, the solution would be to put it on the PluginStore. But again, it's an Exe file on Windows (and similar on Mac), so it's never simple to download such files by program.
                      • MALAISEM Offline
                        MALAISE
                        And I missed that. What a tool for animated explanations. I can't wait..
                        As Pilou said, Fredo President !
                          gio
                          [RV444.1442] Thea for SketchUp - NEW
                          New: Support for Fredo's Animator plugin added
                          Ciao,
                          Gio
                          • ntxdaveN Offline
                            ntxdave
                            Ciao,
                            Gio
                            How about showing some examples......
                            Press F1...thank me later
                            • F Offline
                              Falstaff
                              I'm trying to animate movements with both translation and rotation and am finding that they interfere with one another, the object gets additionally displaced while rotating, ending up in the wrong spot / pivot point. In that model the components are nested, is there something with how the plugin interprets nested components that would cause that weirdness?
                              Also how does the positioner option work on the back end? It seems like I have functions that gets locked into place which make it impossible to modify a beginning position, in other words, I want to have my object have a new starting point and even though I set a new position through Positioned Load the plugin queue's back in time and my object jumps back to where I originally had it. It would be helpful to be able to delete Positions or access the coordinates manually somehow to wipe that information.
                                RichardPMuller
                                Thanks for sharing this Beta version. First results: Animation double canal lock (school project daughter) Great plugin and lots off fun to work with. https://youtu.be/aO1PnfoDu2g
                                • ntxdaveN Offline
                                  ntxdave
                                  Can you post an animation so we can see your problems?
                                  • F Offline
                                    Falstaff
                                    Attached are two videos of my biking guy. I've got this component organized so that his foot rotates with the pedal component, and now I am manipulating the rotation of his "leg" component and the rotation of his "calf" group within the leg.
                                    I noticed the knee keeps shifting i.e. becoming unattached. The only clue that I have are in the videos below (which show the 360 rotation to emphasize). When I play in isolation mode the leg rotates the way I need it to with the knee intact. However, when I play the entire clip together the movement is wrong.
                                    My guess is either its somehow being influenced by another recorded movement for some reason. Or the plugin is misinterpreting the axis.
                                    3 pos left leg.mov
                                    3 pos left leg2.mov
                                    • ntxdaveN Offline
                                      ntxdave
                                      Nice animation. I am curious about how you accomplished the water level changes. It comes across very smoothly. 👍
                                        duanekemp
                                        Very well done. Bravo.
                                        Duane Kemp
                                        Kemp Productions
                                        Gallery:
                                        • ntxdaveN Offline
                                          ntxdave
                                          First off, this is an animation that can better be done with a tool that supports "bones" which this version of Animator does not currently do. However, below you will see a very crude attempt to show you the steps that could currently need to be done (many more of them obviously). I did not animate the pedal, just the foot and lower leg. I also left a kind of reference (circle) to give you an idea. I also color coded the sequences to show you which one related to which object in the animation.
                                          You mill notice that there are multiple animation sequences for each object. So what you are doing is rotating, spinning, and translating all at the same time.
                                          Click to play........
                                          For the foot, there are two sequences. One is a rotation based on the reference circle below it and the other is a spin to adjust the ending position of the foot.
                                          Tor the lower leg, there are three sequences. One is a translation that moves the leg to the left and the second is a translation that moves the leg down to match the position of the foot. The third sequence for the leg is a spin that adjust the angle of the leg and would occur in the pedaling action.
                                          To complete the full rotation of the pedaling motion, you would have to perform multiple sets like these.
                                          I did not use the save position anyplace in my animation. I generally only use that tool when I think I am going to make a bunch of revisions and may need a clean starting point.
                                          Hope this helps you...............
                                            RichardPMuller
                                            Thanks, simple, the water is just a flat face moving up and down. Move the water in the lock and the boat at the same time and duration up or down the Z-axis. You have to soften some outlines off the water face were they come together, so they look one peace when the doors slide away.
                                            Nice animation. I am curious about how you accomplished the water level changes. It comes across very smoothly. 👍[/quote]
                                            • 11
                                            • 12
                                            • 5 / 12
